LockedOIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION
DWM
2009/11/08 13:07:47 (permalink)
My mudd truck in my sig is starting to smoke and use oil the motor still has very good oil pressure. Do any of you know of an oil additive that really works to stop oil consumption and smoking? Just trying to put off building another motor until after the first of the year. Yes I run the crap out of this little 350 in a heavy truck it has had a drink more than once.
THANKS
DWM
06 Arctic cat 700 efi  4.0s green secondary lightened rollers 31 outlaws highlifter lift springs and 2 in lift snorkeled. Polaris RZR 4 900 stock for now! but not for long.
17 Replies Related Threads
    4x4rancherr
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/08 16:18:36 (permalink)
    During the summer I saw a product that you put into your oil that did just what you where looking for, I cant remember the name, but it was kinda like the stuff they put in gas to make it better, but this stuff went in the oil. Good luck finding it.
     BlAcK 06 Honda Rancher AT
    26" MudLites
    HMF (ReD)
    UNI
    2" Lift on Front (more like 1.5 ha)
    1.5" Snork
    Myspace
    FaceBook
    My Youtube
    Sandy Bottom Boys
    of
    NC
    rancherkid33
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/08 17:48:41 (permalink)
    Boy i need some of that stuff then even if it don't stop it just helps any.
    04 Arctic Cat 400 manual
    28s, supertrapp
    08RancherES (GONE)
    a little of this and a little that
    CAJUNMUDDER
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/08 18:15:55 (permalink)
    marvel mystery oil and sea foam
    "TEAM WHISKEY TANGO"
    Powered by B.C. POWERSPORTS
    "THE CAT"
    2010 mudpro 700
    speed werx exhaust
    welded sld
    sold
    "Da Can-Am"
    08 can-am outlander 800
    "2SMALL"
    03 rancher
    stock
    "LUCKY"
    80'somethin suzuki quad-runner
    bored to the max
    black spray painted rims
    25" swampers
    duct tape
    jb weld
    rope
    DWM
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/08 18:44:54 (permalink)
    CAJUNMUDDER
    Both these products thin the oil and would make smoking and oil consumption worse
    suzuki14258
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/08 19:01:33 (permalink)
    Lucas makes a heavy duty oil stabalizer, ive heard good and bad things about it. Its extremly thick. Its suppost to help with both of your problems. I dont know what grade of oil your running but you could go up to a 20w50 if your not already.
    09 POLARIS 850 xp
    Pure Polaris Front and Rear bumper
    Polaris 3500 pound rope winch
    Axitech Lx4 lights
    Pure Polaris Head Light Bulbs
    System
    K&N filter
    Winch saver
    15 inch platinum ss 212 wheels/ 28 inch bf goodrich km2s
    The Trucks are Fords and the Tractor is Green.
    H-town offroad supporter
    zillad3004x4
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/09 01:55:56 (permalink)
    pull your plugs out, put a table spoon of marvel mystery oil in EVERY cylinder. put plugs back in, let it sit for a botu 2 hrs. then bust er off. it will help reseat your rings if they arent too far gone. you will get a few more hours out of the motor. Ive done it several times. my chevy small block 400 started smokin in my 86 chevy. did this trick and it lasted 4 more rides....
    14 ranger 900: backwoods forward arms, roof,29.5 swamplites, little LED lighting, viper 5k, custom bumper
    CTownForeMan
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/09 19:03:31 (permalink)
    Mechanic in cans do not work.  Fix it right or don't fix it at all.
    DWM
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/10 17:25:57 (permalink)
    CTownForeMan
    I am currently building another motor I will not have the money to finish it until after the first of the year as I have other priorities wife and kids christmas ect.
    Trying to get by a couple months that way I can just pull old smokey out and drop in the new motor. Not trying to fix it just bye some time.
    Thanks for the tips
    zillad3004x4
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/10 19:02:06 (permalink)
    DWM, where you from? name? got any pics of your truck? I may have rode with ya a time or two and not known it. lol
    merco
    Mud Slinger
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/10 23:19:24 (permalink)
    round here all the farm tractors as well as about everything else gets rotella 15/40,we got a ezgo golf cart and it was using lots of oil and since it has been switched it has been cut in half if not more.we use to run straight 30w in all the tractors and then my daddy started using the rotella and it made a big difference in oil consumption.it has some type of additive in it ,i think zinc ,,that makes it work the way it does.it also happens to be in my 450foreman also.
    zillad3004x4
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/10 23:40:04 (permalink)
    rotella-t is made to be used in a diesel engine which requires thicker oil due to the compression being much greater. I run rotella-t on a gasoline engine when it starts smoking. but most of the time marvel mystery oil dumped straight into the cylinder will help reseat the rings if they are savable... heck man, if your running a 350, just getcha a rebuild kit and rebuild it one night... i know i can get a rebuild kit for a 350 for about 180 bucks... just a thought, and if its carb'd its real simple but im sure you already knew that.
    DWM
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/11 16:42:37 (permalink)
    zillad3004x4
    I live in longview. dont know how to post pics but the truck is a tan crewcab. I ride with codys offroad this was the first crewcab we built. Its the smallest truck in our group. I will try to get some pics on here soon.
    Damon
    joshua99ta
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/11 16:49:48 (permalink)
    I wouldnt do it at all man... that stuff can be more harmful than good.... thicker oil is twice as hard on an engine on cold starts... I haven seen it but I have heard of engines snapping oil pump shafts in half running 20-50 in cold weather.  So imagine adding a 140 weight oil to it.... thats just about all the oil addatives are.  Being your already have problems I wouldnt try to make it any worse
    Team Outta Kontrol
    09 Renegade X
    FCP, ///Airdam and some Wild Boar love
    08 Rzr-beer mobile
    DWH 11 LOST BUT NEVER FORGOTTEN
    zillad3004x4
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/12 00:49:40 (permalink)
    ah... i know cody was at river run for the labor day ride. were ya there with him? I run with brian, kenny, JD, keith, little mike, lee, that crowd for the most part. workin on makin my truck a little bit bigger now. I was informed 3 days ago that I have to have it goin for the christmas parade... joy joy. i prob dont see that one happening. lol
    DWM
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/12 06:13:24 (permalink)
    No I had to work that weekend
    CTownForeMan
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/12 06:41:46 (permalink)
    It was an alright weekend but everything was too thick.  I would just get it fixed right before doing anything else but thats what I do for a living is work on engines so thats my mind frame now days.
    Get that little green thing ready.  The "DONK" will be there bling blinging!
    DWM
    Re:OIL ADDITIVES TO STOP SMOKE AND OIL CONSUMPTION 2009/11/12 17:06:06 (permalink)
    I work on engines every day for a living also just trying to put it off until its replacement is finished. But most of the time when i get home I dont want to turn them on my own stuff.
