Hot!New Winter Project
johngolds43
2019/09/08 12:13:52 (permalink)
New Winter Project
I got a 2007 ranger 700xp.  I will add photos as I get into the project. Does anyone have any suggestions of things I need to check for, replace ect.  This is my first side by side, I really dont know much about them. I am the second owner, and know how the utv has been used.  Oils, Bearings, belts, upgrades, any advise would be much appreciated.
john
1 Reply Related Threads
    Re: New Winter Project 2019/09/08 18:00:07 (permalink)
    Man it's really jack it up and start turning and checking wheel bearing and CV shafts for torn boots and or clicking noises. If it can pull itself through mud or with a load belt should be fine unless you see some cracking on it. Man Google is your friend. There is a bunch of accessories for these things but what is the best ones for your use is all up to you.
