LockedNeed help
MWParker4348
2018/04/18 22:21:35 (permalink)
Need help
I have a stock 04 Suzuki Eiger 400. I put 28” mudzillas on it and surprisingly it doesn’t rub. I have a 2” lift coming for it and as I got to looking at the front end I noticed the bar that mounts to the frame from the front footboard is just below the centerline of the tire. Once the lift is on it’ll be about dead center of the tire and will probably rub. I’m wondering if anyone else has ran into this problem and what the did to resolve it. I also ordered an HMF slip on and an UNI air filter with the jet kit. Just wondering what jet size people were running with the HMF.
1 Reply Related Threads
    Re: Need help 2018/04/19 07:19:04 (permalink)
    Can you post pictures of the issue your talking about. Might be able to give you a few pointers.
