Hot!Need advice
SouthernMudd82
2020/01/01 22:29:46 (permalink)
Need advice
Hello everyone I'm new to the forum. I'm looking for some advice and options on a build. I've got a bone stock 1992 Honda Fourtrax 300fw that I've got to do some work on. Figured since I've got to go into it to do some clutches and stuff I might as well go ahead and do a gear reduction kit on it. My question is this: If I plan on doing a 54-68% gear reduction would a 317 big bore kit be worth the extra money? I'm planning on upgrading the clutches, exhaust, cam, timing chain, rocker arms, porting the head and doing a 4" lift on front and going to stretch the rear about 4" or so. Any other modifications that I might be missing? Thanks in advance
2 Replies Related Threads
    Re: Need advice 2020/01/02 08:12:36 (permalink)
    Man go with the 54%. Make sure you get a built drive shaft and or make it from high quality steel. Don't just cut it and sleeve it. Go with the 317 kit as it makes a reliable engine and uses all stock Honda parts. Run a big red 250 atc cam. Find you a 350D rear axle assembly and swap out the old 300 rear axle. Also run ebc clothes as well. If you have any other questions hit me back.
    Jeepwm69
    Re: Need advice 2020/01/02 11:10:32 (permalink)
    Agree with everything Nutt said except the gear reduction. What size tires are you going to run?  That will determine what GR % you get.
