Need Help
dom
2019/05/21 17:25:56 (permalink)
Need Help
I would like to put 34” outlaws on my RZR 1000 Highlifter Edition. What is needed to make these fit the front with no issues?
I’m trying not to go with a lift, I don’t like when it’s real high.
Thanks
9 Replies Related Threads
    Re: Need Help 2019/05/21 22:33:12 (permalink)
    Man unfortunately your gonna have to get a good size lift so you can have the suspension travel in order not to bottom out on the tires themselves.
    Grant@HighLifter
    Employee
    Re: Need Help 2019/05/22 09:50:30 (permalink)
    If you do the 3-5" Bracket lift and the Front Forward arms they should clear.  We have done 34.5's on a number of bikes with that setup without issue.
    post edited by Grant@HighLifter - 2019/05/22 09:51:45
    Grant Perkins
    High Lifter Products
    Grant@highlifter.com
    Re: Need Help 2019/05/22 13:47:42 (permalink)
    There you go a highlifter expert to lend a helping hand. Good work Grant!!!!
    dom
    Re: Need Help 2019/05/26 20:02:33 (permalink)
    Thanks Grant,
    can I just go with the forward front A arms with no lift, the front is where I need clearance from the floor pans. I have lots of clearance on my Highlifter edition in the rear. It also has helped springs in the front and rear. The rear has lots of clearance. I will not be running this hard in order to bottom it out, I just want clearance for about 6” or travel
    In short, the front is the only issue.
    Re: Need Help 2019/05/27 20:32:42 (permalink)
    Hey Dom give Grant or Dan a call at highlifter. Super great guys and will help you on the spot and give you the best deal possible!!!
    dom
    Re: Need Help 2019/05/28 07:12:39 (permalink)
    Thanks, I will today!!
    Cheers
    Grant@HighLifter
    Employee
    Re: Need Help 2019/05/28 08:37:29 (permalink)
    It MIGHT fit because you have the upgraded tender springs  "They give around 2" of lift" but I wouldn't bet on it.  You could try it but don't be surprised if you still need to do the lift.  I wouldn't just crank down on the pre-load to make them fit either, if you do that it's just going to ride terrible.
    Grant Perkins
    dom
    Re: Need Help 2019/05/29 07:57:42 (permalink)
    Grant@HighLifter
    Thank you Grant!!! it is nice to talk with people that know the answers. Just another reason why I think Highlifter is #1
    Grant@HighLifter
    Employee
    Re: Need Help 2019/05/29 09:43:35 (permalink)
    No problem man!  If you need anything else just let us know!
    Grant Perkins
