LockedNeed Help Grizzly 600 wont start
TGD600
2010/06/14 12:35:47 (permalink)
My grizzly 600 barely started a couple days ago and now it wont even start by electric start. the only way it will start is if i pull start it. does this mean the starter motor is out? or could it be something easier to fix. another weird thing is i pull started it to ride and ran out of gas so i kicked it over to reserve and pressed the start button and it kicked it over! however, i tried to do it again and it would'nt start. if yall could help id appreciate it.
2007 Grizzly 700 EPS
29.5 Laws
SS212's
Snorkeled
PCIII
Axia Alloys 2" tip
/// Airdam Stage 3
Wild Boar Radiator kit
Viper Max 3000
HID 10,000K High kit
Angel Eye Low Beams
Aluminum Products A-Arm Guards
2001 Grizzly 600 (Sold)
2' Lift
2' spacers
White Secondary
Competition Stall Springs
12 gram weights
28' silverbacks
Snorkeled
2001 Ford F-150
3' lift and 35' Grapplers
28 Replies Related Threads
    08GeorgiaBrute
    Re:Need Help Grizzly 600 wont start 2010/06/14 14:05:26 (permalink)
    Might be a bad battery. I just put a new one in mine yesterday.
           RIP
    08 Brute Force 750 EFI (stolen)
    - 28" Maxxis Zillas
    - 12" ITP SS212
    - EHS Racing Vented Air Box Lid
    - EHS Racing EFI Programmer
    - Xtreme 3000lb winch
    - LouderVisions Custom Fender Flairs
    - Carbonfiber Shift Knob
    - Custom Warning Plates (just for kicks)
    - Full Alumnium Products Skids And Stick Guards
    - 8K HIDs
                       More to come soon
    TGD600
    Re:Need Help Grizzly 600 wont start 2010/06/14 14:31:31 (permalink)
    well the lights and everything work and i can hear a switch clicking when i hit the start button so i wouldnt think it to be the battery
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    Mrmojorisan
    Re:Need Help Grizzly 600 wont start 2010/06/14 14:50:18 (permalink)
    battery could have a bad cell allowing enough juice for some things but not enough to turn over the starter.  Test the voltage on it, or better yet, pull it out and take it to your local autoparts store and have them put it on a tester
    '10 Ranger Crew 800 with stuff and plenty of boom (family wagon, aka the party bus)
    '08 Rhino 700 EFI, with stuff (my personal ride - which I think I'm going to sell)
    (2) '07 Arctic Cat 250 - My two daughter's rides
    Dezz
    Re:Need Help Grizzly 600 wont start 2010/06/14 15:15:28 (permalink)
    By what do you mean that it won't start with the electric starter? Does the motor crank over but will not start? Or do you mean that nothing happens when you press the start button? Do you hear a clicking sound coming from the soleniod?
    On the "reserve" question, what do you mean here as well? The engine just wouldn't start up OR would not crank over?
    If you mean the engine does not turn over at all when you press the starter button, then you could have a loose battery terminal, a bad battery, a bad solenoid, or a bad starter motor.
    The first thing to check is your battery terminals for tightness. If they are tight, then keep reading. If they are loose and after you tighten them you still have the problem, thne kepp reading. If you tighten them and your problem goes away, thne stop reading.
    Since it happened all of a sudden, I do not suspect your battery is the problem. Not saying that is is not. But most of the time batteries don't just die all of a sudden. They slowly die over time and get weaker and weaker with use. It usually will give you indications that it will be needing replacement soon. Clicking or buzzing noises coming from the solenoid is one of those indications.
    Since you said it just happened all of a sudden, I suspect your starter motor is to blame. But you should first check your solenoid for operation, since they can and do often fail suddenly...like most electrical devices. This can be done very easily with a volt meter of ohm meter. If you do not have one of these, you can purchase a cheap multimeter at just about any hardware store, autoparts store, etc.
    The starter solenoid on the 600 Grizzly's is located under the left rear fender. It will have a red wire from the battery on the far back post, and a black wire on the forward post. It will also have a black connector. Since the red wire is connected directly to the battery then you should have constant voltage supplied to it (Atleast 12.5 or more volts with a good, charged battery). Turn on the key ignition and press and hold the starter button. With the button held down, check for voltage on the black wire. There should be voltage. If not, more than likely the solenoid os the problem.>>>BUTU thne you could also have a bad starter switch. I am not going to get into troubleshooting that now. Do these checks first.
    If there is voltage present, then this means everything up to the starter motor is working properly and the starter motor is the problem. They can be reuild with new brushes if they are not in that bad of shape internally. You can also do another check with this as well. Again tunr on the ignition switch and again press and hold the starter button. Then take a hammer and tap on the starter motor. DO NOT hammer it hard. Just slightly tap it. If the engine turns over, then you have worn starter motor brushes and they need to be replaced.
    Now this is just a guide line for help with troubleshooting your atv. If indeed your negine is turning over when you are pressing the starter button but will not start, then all the typing I just did was for nothing because you have a separate problem. If again this is indded the problem, then let us know and we can help steer you in the right direction of what your problem is.
    Dezz
    2003 Yamaha Grizzly 660
    Dalton Clutch Kit
    2500 lbs. WARN
    High Strength Axles
    - SOLD - But not Forgotten
    1998 Grizzly 600
    ITP Delta Black Chrome Rims
    4 - Kodiak 450 Clutch weights
    Uni Air Filter
    Warn A2000 Winch
    Oxlite CV joint protectors
    TGD600
    Re:Need Help Grizzly 600 wont start 2010/06/14 16:30:53 (permalink)
    thanks dezz for writing all that, im sure that wasnt any fun. I have trouble clarifying when i ask questions sometimes thats my bad. ok let me try again, the only problem i have is the electric starter, i can pull start the bike just fine and the motor will run fine. the starter motor will not turn over at all.
    All the battery terminals are tight
     i dont have a volt meter but i think theres voltage coming through because i can hear the solenoid clicking when i press the electric starter
    Let me know if that is enough to know that its not the solenoid or if i should get a volt meter to check.
    Also, if it is the starter motor, how hard is it to take off?
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    Dezz
    Re:Need Help Grizzly 600 wont start 2010/06/15 03:04:02 (permalink)
    The starter motors are not that hard to remove. It is located in front of the engine, close to the bottom. You will have to remove one of the black fenders to get a good access to it. I would remove the Right Front since the bolts for the starter are on that side.
    BUT.....I don't think your starter motor is the problem. Now that I got more information, I think your battery is done and needs to be replaced. There are a couple ways to make sure. One is to have a multimeter and check for voltage. If the battery voltage is less than 12.5 volts (with no load), then its done and needs replacement. But since you don't have a meter, just use a set of jumper cables and hook up to another vehicle and boost it. Just like boosting a dead battery on a car. If your machine starts, then the battery is gone. This is a easy and quick way to troubleshoot a dead battery.
    Keep us posted.
    Dezz
    post edited by Dezz - 2010/06/15 03:05:03
    Dalton Clutch Kit
    2500 lbs. WARN
    High Strength Axles
    1998 Grizzly 600
    Uni Air Filter
    Warn A2000 Winch
    TGD600
    Re:Need Help Grizzly 600 wont start 2010/06/15 10:33:24 (permalink)
    ok thanks i will do that as soon as i get home
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    helmut
    Re:Need Help Grizzly 600 wont start 2010/06/15 14:25:04 (permalink)
    If it's not the battery, it might be the solenoid. Make sure you have a good battery and make sure it's charged. Now, take an old screwdriver and jump the two terminal posts on the solenoid. If the starter turns, the solenoid is bad.
    TGD600
    Re:Need Help Grizzly 600 wont start 2010/06/15 18:04:52 (permalink)
    I tried it and it still didnt turn. i tried jumping it and also didnt turn so i guess at this point the only other thing it could be is the starting motor so if yall have any advice from here id love it guys
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    helmut
    Re:Need Help Grizzly 600 wont start 2010/06/15 18:41:47 (permalink)
    Take a set of jumper cables and hook one end of the cables to a known good battery. I would hook them to a good car battery. Next, hook the other end directly to your starter. Hook the ground to the starter casing, itself, and touch the hot to the hot terminal or post on the starter. If the starter doesn't turn, then the starter is bad.
    TGD600
    Re:Need Help Grizzly 600 wont start 2010/06/15 19:17:43 (permalink)
    also i dont remember if it usually does this but when i try to start my bike the oil light comes on does that mean anything to yall i just cant remember if it normally does that.
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    TGD600
    Re:Need Help Grizzly 600 wont start 2010/06/15 19:20:46 (permalink)
    helmut, by terminal do you mean the black wire to the solenoid?
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    helmut
    Re:Need Help Grizzly 600 wont start 2010/06/15 19:26:39 (permalink)
    TGD600
    Yeah, hook the ground to the starter casing, itself and touch the hot to the post on the starter that the black wire from the solenoid hooks to. By doing this, you are sending power straight from the battery to the starter. If the starter don't turn, then the starter has to be bad.
    That oil light is supposed to come on for a few seconds and then go back off. That is just to let you know that the oil light circuit is working properly.
    TGD600
    Re:Need Help Grizzly 600 wont start 2010/06/15 19:43:37 (permalink)
    i hate to ask but what is the starter casing? is it the outside of the starter motor?
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    helmut
    Re:Need Help Grizzly 600 wont start 2010/06/15 19:52:27 (permalink)
    TGD600
    Yeah, that's what it is. You could ground it anywhere on the engine, but I always ground them directly to the starter, so I can have the best ground possible.
    TGD600
    Re:Need Help Grizzly 600 wont start 2010/06/15 20:29:15 (permalink)
    ok thanks well ill try that tomorrow and ill tell you guys what hapened and we'll go from there
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    hillbillybengreen
    Re:Need Help Grizzly 600 wont start 2010/06/19 18:42:21 (permalink)
    its your raticifer mine did that when i first got it changed it and never had a problem since but also go ahead clean all connections
    No More Atvs
    high center
    Re:Need Help Grizzly 600 wont start 2010/06/19 20:33:34 (permalink)
    hillbillybengreen
    Don't call me stupid but what's a raticifer? Is that a pacifier for baby rats?
    2008 Brute Force 750
    PCIII
    MIMB Snorked with 3" intake
    Full HMF Utility
    K&N Air Filter
    Gorilla Rad Relocated
    Pro Mark 3K lb winch with blue rope
    29.5 Laws on SS212's Skinny Wides
    Xtreme 2" lift
    EPI Almond Primary Red Secondary
    DOM over stock tie rods
    2006 Yamaha Grizzly 660
    Reapers on 14's
    1.5mm shim
    2007 Honda Recon
    25" Black Rocks
    #19
    TGD600
    Re:Need Help Grizzly 600 wont start 2010/06/21 22:51:00 (permalink)
    yea high center is right, i have no clue what that is?
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    #20
    high center
    Re:Need Help Grizzly 600 wont start 2010/06/22 16:11:54 (permalink)
    Maybe he means voltage regulator or rectifier?
    PCIII
    Full HMF Utility
    K&N Air Filter
    Xtreme 2" lift
    Reapers on 14's
    1.5mm shim
    2007 Honda Recon
    25" Black Rocks
    #21
    4wheeln96
    Re:Need Help Grizzly 600 wont start 2010/06/22 16:29:17 (permalink)
    I don't pretend to know everything but I had the same problem on my kodiak and could pull start it but just get a "clicking" sound when I pushed the start button.  When I got it home, I started pulling all the fuses and electrical connections to clean and put dielectric grease on them.  Well, my starter solenoid is built with a bracket and fuse connection on top, when I pulled it loose, the whole thing broke in half.  Apparently 4 years of playing in the mud corrodes them right through.  $45 later, I'm back in business.  So my solenoid was good, just the connections corroded in half.  Good luck...
    '05 Kodiak 450
    26" Mudlites
    2" Highlifter
    2500# Warn
    Custom "Yield Sign" skidplate
    #22
    AlaskaGrizz
    Re:Need Help Grizzly 600 wont start 2010/06/22 17:06:49 (permalink)
    Forget the rectifer, that's not the problem. Jump the starter like they told ya BUT they are wrong saying it's bad if it don't turn over. IF YOUR VALVES ARE TOO TIGHT and the piston is on the compression stroke to TDC the starter motor will not have the power to turn the engine over and THIS makes you think the starter is BAD. All you will hear is the selonoid click.
    Now you said when it ran out of gas and you tried it the starter  WORKED. This is why I'm mentioning this. Play with the rope starter, pull it some to get the piston in different positions while trying the starter button.
    09 Polar Bear HO 700
    modded out
    2005 660 Grizz
    HMF
    Dynojet
    Warn 2500
    Setxatv snorkles
    Steel skidplates and A-arms
    HL Super Duty Clutch kit
    HL Triple Flow Rad/ stock position
    #23
    TGD600
    Re:Need Help Grizzly 600 wont start 2010/06/24 10:26:18 (permalink)
    Sorry i haven't check highlifter in a little with work and everything but i will do both of those things and see what happens. again thanks for the brainstorming yall!
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    #24
    TGD600
    Re:Need Help Grizzly 600 wont start 2010/07/05 13:06:13 (permalink)
    Hey guys here is just an update I took off the starter and cleaned it and made sure the brushes were fine. then i put it back on and it still didnt start. I started the bike up via the pull start and then tried to press the starter and it didnt even wind up. so i guess im gonna go and buy a new soleniod because thats pretty much the only other thing i havent checked.
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    #25
    TGD600
    Re:Need Help Grizzly 600 wont start 2010/07/06 11:32:13 (permalink)
    Good thing i didnt buy a soleniod because i finally got my hands on a voltage meter and the solenoid works! now i guess its definitley the starter but i have no clue what it could be? any ideas? i took it apart once already and the brushes looked good enough and i also cleaned the whole thing.
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    #26
    hillbillybengreen
    Re:Need Help Grizzly 600 wont start 2010/07/06 19:49:24 (permalink)
    have you pulled your spark plug in a while if not pull it out and try turning it over
    No More Atvs
    #27
    TGD600
    Re:Need Help Grizzly 600 wont start 2010/07/06 21:45:10 (permalink)
    no but from the PM you sent me i turn off my gas every time so the float would not stick and flood the cylinder.
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    #28
    TGD600
    Re:Need Help Grizzly 600 wont start 2010/07/08 11:24:05 (permalink)
    Just thought id give yall an update, Im pretty sure I fixed the problem. I tried jumping the starter again and it didnt turn so i opened it up again and really cleaned the brushes good because apparently one of the brushes was not hitting so it wasnt spinning. well now it turns like a champ and hopefully this mess is done with! thanks guys for yalls help
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    #29
