LockedMy Foreman on 31s
mspuddlejumpers
2013/01/03 12:16:31 (permalink)
My Foreman on 31s
I need some opinions on this. I know there's a few members on here running 31s on their foremans, not 2012+, but the carb ones. I ordered a 450 swing arm and drive shaft yesterday and I have the secondary GR, .50 over P&P head, and small stuff like pipe and filter. Would it be worth it to swap from my 30 inch mud lites(pontoons) to 31 s/w laws? Would a primary be necessary? I'm just tossing ideas around because these mudlite a float insanely, it's either 29.5 terms, 31 laws, or 29.5OL2
******2011 850xp ******
31" Skinny Wide outlaws
3" lift
Big Gun Eco
Msa Kores
Snorkeled
10" single row light bar
6000K 55w HIDs
4' Red Tribal whip
3000LB KFI winch
Wetsounds Stealth 6
CVTech
19 Replies Related Threads
    WeGetOurs
    Re:My Foreman on 31s 2013/01/03 15:05:30 (permalink)
    I vote 29.5 OL2 because my bike pulls the heck out of them, and they fit nicely with the 450 swingarm swap.
    This is mine with 450 swjngarm swap, 2" lift in front, sitting next to a 6" lifted 2wd 300
    one big ol' foreman
    and one little ol' 300
    mspuddlejumpers
    Re:My Foreman on 31s 2013/01/03 18:49:31 (permalink)
    HOLY SHAT!!!! Your bike sits so high in The rear. I did the math and a set of 31 skinnies only weighs 11lbs per all 4 tires than my s/w mud lites
    3" lift
    Big Gun Eco
    Msa Kores
    Snorkeled
    6000K 55w HIDs
    4' Red Tribal whip
    3000LB KFI winch
    Wetsounds Stealth 6
    CVTech
    WeGetOurs
    Re:My Foreman on 31s 2013/01/03 18:57:43 (permalink)
    Correction. My bike SAT so high in the rear. Where it sits now makes that pic look like a tonka toy haha.
    in that pic all I had was a 450 swing arm swap with my shock mounts relocated as high as possible without putting my u joint in a bind. It did alot.
    one big ol' foreman
    mspuddlejumpers
    Re:My Foreman on 31s 2013/01/03 22:32:29 (permalink)
    Haha I forgot you lifted it. Can you post some pictures of exactly how you relocated
    Your shocks, and of your u-joint angle
    3" lift
    Big Gun Eco
    Msa Kores
    Snorkeled
    6000K 55w HIDs
    4' Red Tribal whip
    3000LB KFI winch
    Wetsounds Stealth 6
    CVTech
    WeGetOurs
    Re:My Foreman on 31s 2013/01/04 07:11:22 (permalink)
    I bought the swingarm with the shock mounts already extended. They arent relocated but just made taller pretty much.
    Here's the shock mounts. They aren't the prettiest in the world, but they got the job done.
    Here's the bike up on the jack after the 450 install. You can get a good idea of what angle the rear driveshaft was at. Kinda steep for me, but the U-joint wasnt in a bind so I was good with it.
    one big ol' foreman
    hondarider3
    Re:My Foreman on 31s 2013/01/04 07:18:55 (permalink)
    Is that one of my spacers laying on the ground? Lol
    2015 rubicon 500 foot shift
    30" interforces
    ss112
    snorkel
    soon to come:
    29.5 outlaws
    ss108's
    radiator relocation
    hmf
    arched arms
    08_Foreman
    Re:My Foreman on 31s 2013/01/04 11:10:08 (permalink)
    Install the 35 primary. Trust me, either tire you pick, it'll do better
    The secondary isn't enough for 31s
    2008 Foreman 500ish
    Xtreme Double GR
    Ported & Polished
    10mm Stroker
    Bigger Valves
    Spool Locker
    Gorilla Axles
    Big Bore Kit
    HL Springs
    Hot Cam
    Snorkel
    7" IRS
    Winch
    HMF
    32s
    honda maniac
    Re:My Foreman on 31s 2013/01/04 11:28:24 (permalink)
    andrew im tellin u listen to me and 08_foreman we both have run them and no what we are saying u should still try them this weekend.
         2013 rzr 900xp (black)    (the cruiser)
    34.5x10.5x16 OL2S 16x7 msa vibes  S3 front/rear bumpers and cage, Highlifter arched suspension, Rhino axels, turner cycles HD reverse chain/gear reduction, Airdam/// clutching, KMS 3in intake, Bling star doors, Pro armour seats, Wetsounds audio... and so much more
        2011 "420ish" rancherFM (white)
    -31x11 laws, Sti hd5 beadlocks, 50% of reduction BPC 6inch lift(voodo blue), center axel paddle... and alot more
          2010 ranger 800 HD (tow hoe) "got hoe will tow"
    3inch catvos, Sti HD beadlocks, 30in outback maxes
    custom flat bed with tow boom, warn12k on bed, warn 4k on boom...
    WeGetOurs
    Re:My Foreman on 31s 2013/01/04 11:38:11 (permalink)
    Tyler no those are hunters spacers
    one big ol' foreman
    mspuddlejumpers
    Re:My Foreman on 31s 2013/01/08 13:41:21 (permalink)
    Bump. Can anyone else post some pictures of how they did their shocks on their 450 swap? I'm trying to get an idea of exactly how I want to do it
    3" lift
    Big Gun Eco
    Msa Kores
    Snorkeled
    6000K 55w HIDs
    4' Red Tribal whip
    3000LB KFI winch
    Wetsounds Stealth 6
    CVTech
    WeGetOurs
    Re:My Foreman on 31s 2013/01/08 15:46:42 (permalink)
    quick google search:
    one big ol' foreman
    CRSBear400
    Re:My Foreman on 31s 2013/01/08 15:55:45 (permalink)
    Other than a shock relocation,  what all is required to do this swap?  Thanks in advance
    ~ Cale Sanders
    '11 RZR 900XP LE White Lightning
    HL 5" lift, 28" OL2's & MSA Crushers, EMP 2" receiver hitch, EMP half windshield, OSS loaded roof, GORILLA/DHT AXLES, LTE full system, Dobeck Gen III, 5" cage chop, Polaris OEM doors, CRS snorkels
    SOLD!!!
    '14 Kawasaki Teryx 4 800
    CATVOS 3" Lift w/+2" F&R stretch, 31x9.5 Outlaws, MSA Beadlocks, 5" cage chop, flush steel roof, 2" bed lift, half windshield, Wetsounds 10 Sound bar, CRS LED Snorkels, LED underglow, 30" Rigid l
    WeGetOurs
    Re:My Foreman on 31s 2013/01/08 15:57:16 (permalink)
    450 swingarm and driveshaft. That's it. Gives you just enough stretch and lift to fit 29.5's or 30's nicely under the fender, as you see in my pics, Run a 2" lift up front to even it out.
    EDIT: The swingarm mounts where it attaches to the right side axle tube is slightly wider on the 450 than the 500. This requires one of two things, bending the swingarm in slightly with a hammer so it will mount up, or cutting, repositioning, and rewelding as my swingarm was done (see pics)
    post edited by WeGetOurs - 2013/01/08 15:58:45
    one big ol' foreman
    mspuddlejumpers
    Re:My Foreman on 31s 2013/01/08 19:09:09 (permalink)
    I think i'll just weld a lift piece like yours on it. Looks easy enough
    3" lift
    Big Gun Eco
    Msa Kores
    Snorkeled
    6000K 55w HIDs
    4' Red Tribal whip
    3000LB KFI winch
    Wetsounds Stealth 6
    CVTech
    CRSBear400
    Re:My Foreman on 31s 2013/01/09 10:59:49 (permalink)
    WeGetOurs
    Good info.  Thanks!  I was curious about the brake cables.
    ~ Cale Sanders
    SOLD!!!
    WeGetOurs
    Re:My Foreman on 31s 2013/01/09 12:04:12 (permalink)
    ahhh, I did a brake delete at the same time I did the 450 swingarm. I'm sure the brake cables will need to be longer, I removed mine.
    one big ol' foreman
    mspuddlejumpers
    Re:My Foreman on 31s 2013/01/12 09:22:52 (permalink)
    Well my parts finalt came in yesterday, so it looks like imabout to throw them on!
    3" lift
    Big Gun Eco
    Msa Kores
    Snorkeled
    6000K 55w HIDs
    4' Red Tribal whip
    3000LB KFI winch
    Wetsounds Stealth 6
    CVTech
    Part time professional
    Re:My Foreman on 31s 2013/05/08 07:27:34 (permalink)
    How much did the swingarm and driveshaft cost?
    #19
    Honda_PWNS
    Re:My Foreman on 31s 2013/05/08 08:01:36 (permalink)
    Got this off the honda Foreman forum
    Swing-arm Conversion 450 arm on a 500
    Foreman & Rubicon
    98 to 04 450 arm and drive shaft, the 450 arm
    is 2 1/2" longer then the 500 arm the u-joints
    are the same so you can use your stock u-joint
    the 450 arm is about 1/4" wider where it bolts
    on between the differential an the brake drum
    Pivot Bolts: left side is a 17mm allen bolt
    right side is a lock nut on a 17mm allen bolt
    this requires a special tool to remove
    some use a steel punch to remove the lock nut
    which can mess-up the lock nut and if you hit
    wrong can also mess-up the treads, be very
    careful doing this, I made a tool to do this
    Pivot bearings: there are to different part #'s
    on these bearings this does not make a difference
    1 set of bearings are ball & the other set are needle
    bearings they will both work
    Swing-arm: where the arm bolts up to the differential
    the O-ring on the 450 arm is smaller then the 500
    when you take the 500 arm off the O-ring should stay
    on the differential leave it on there and the 450 arm
    the O-ring should still be on it as well use them both
    this will make for a tighter seal
    450 to 500 rear-end mounting: loosen the right side
    alxe tube from the differential, do not take these nuts
    all the way off, where the arm bolts to the tube by the
    brake drum, you will take a hammer and slightly bend
    the tab to the right, this will give it an angle/taper
    this will help on mounting the 450 arm on the 500 rear-end
    it's still a tight fit, once you get it together place the
    bolts in the bent tab and snug them up as well as the nuts
    on the differential
    Shocks/Lift: some cut the top of the shock off and take a
    piece of pipe and weld it to the shock to extend it to makeup
    for the the difference in the arm's but this puts your shocks
    at a bad angle and will make it ride like a tank
    I designed my on lift to move the bottom of the shocks forward
    which makes for a nice ride
    Torque Specs: Pivot Bolts
    left side 83 ft lbs
    right side 3 to 7 ft lbs
    right side lock nut 83 ft lbs
    Foreman 500ish
    32.Five mambas coming soon!
    2011 Gade
    Dirty2s
    6mill stroker
    bla bla bla its fast
    Team Viagra...We play hard all day
    (I'm drunk and I'm proud of it!)
    #20
