atv gooroo
- Reward points: 0
- Status: offline
Re:Make a list of common numbers we need
2010/04/15 20:46:49
(permalink)
I didn't like the skf because they are little big and hard to install. The skf ones are only a single lip seal vs the triple lip seal from polaris. The polaris ones are about 9 dollars each. Polaris size 50x68.95x8; skf 50x70x8.
04 Sportsman 500HO 2 inch lift, 26 inch mud lites, Black and white primary spring, K&N filter.
H20
- Reward points: 0
- Status: offline
2010/05/25 09:15:02
(permalink)
What about wheel bearings on a 2008 Ranger crew? Pivot works has bearing for @ $54.95 for a pair. This is the number that is on the bearing: ZWBE-031. If anyone has a Timken or Bower bearing number please share it.
H20
- Reward points: 0
- Status: offline
2010/05/28 08:39:21
(permalink)
510013 bearing works on the rear of a Ranger Crew NAPA #338 u-joint fits also and has a zerk fitting. When installing this joint be sure to put the zerk fitting toward the shaft. No need to unbolt the diff. just remove the emergency brake and cotter pin and slide the shaft back. The zerk fitting being toward the shaft will not hit the diff input shaft.
cooter1j
- Reward points: 0
- Status: offline
cooter1j
- Reward points: 0
- Status: offline
2010/05/29 17:47:42
(permalink)
H20
- Reward points: 0
- Status: offline
2010/06/01 15:55:36
(permalink)
Does anyone have another number for the TPS for a 500 Ranger EFI?
99 popo500
- Reward points: 0
- Status: offline
Re: Make a list of common numbers we need
2010/06/01 17:29:49
(permalink)
i got a popo 500 could i run 32 backs with 2"lift stock for now still to come 32 backs ss312s wise co gorilla axles
H20
- Reward points: 0
- Status: offline
2010/06/09 15:30:58
(permalink)
Has anyone found a replacement for the upper and lower motor mounts on a Ranger and Sportsman?
lxman88
- Reward points: 0
- Status: offline
2010/06/11 13:19:11
(permalink)
anyone have a part number for a TPS sensor for a 06 polaris 800 efi or do you have to get it from the dealer 147 bucks thats quiet pricey for that little sensor second time its went bad
2006 sportsman 800 efi 9 inch lift all gorilla axles gorilla prop shaft customs built speaker box with snorks bigger injectors viper #4500 winch heated hand grips 29.5 outlaw2s on crushlocks gear reduction epi clutch kit blue metallic painted frame and silver a arms stainless steel air box 2013 sportsman 800 bone stock not for long
PhilipTX
- Reward points: 0
- Status: offline
2010/08/03 14:19:08
(permalink)
Need parts numbers for a 2007 Polaris Ranger 700 EFI - CV boots. (rear, outer, driver's side) Are these the same as the 4-wheeler Sportsman's cv-boots? Ford 85 Escort? Precision P/N? Thanks
post edited by PhilipTX - 2010/08/03 22:44:55
manxman
- Reward points: 0
- Status: offline
2010/08/30 21:30:19
(permalink)
2002 Sportsman 500 universal joints Car Quest 1-0170 I with grease fitting.Is this correct please let me know if so are alll the u-joints the same on this model.
H20
- Reward points: 0
- Status: offline
2010/09/03 08:03:46
(permalink)
The fuel pump for a 92 ford ranger works perfect in an EFI Ranger 500 700 and 800.
DaButcher
- Reward points: 0
- Status: offline
2011/01/20 06:32:10
(permalink)
H20 The fuel pump for a 92 ford ranger works perfect in an EFI Ranger 500 700 and 800. Good info
06 800 Sportsman G O R I L L A lift 29.5 Outlaws
PeoBey
- Reward points: 0
- Status: offline
2011/03/22 14:17:15
(permalink)
Polaris 2007 Sportsman Front Differential w/o ADC Bearings: 3x SKF 16006 Seals : 3x 25326-DL DAG (?) (on my bearing shop bill) Pinion Self Lubricating Bronze Bushing: 1x AAM 2532-20 (Although this part is too long I cut mine to fit) http://www.asbbearings.com/Products/specs/ZM_Metric_Oil_Impregnated_Bronze_Bearings.html ZM2532-20 ID: 25mm OD: 32mm Length: 20mm Whereas the model in the diff is 9mm in length Next time it fails, ill try changing it to a needle bearing...
james2007755
- Reward points: 0
- Status: offline
2011/05/07 09:43:04
(permalink)
does anyone have the part # for the rear diff bearings and seals for a 08 ranger 700 xp. will the u joints list above for the ranger crew work on the ranger xp? thnx in advance
seaark17
- Reward points: 0
- Status: offline
2011/05/07 10:42:28
(permalink)
How about those little plastic caps that fall of the Polaris bumpers? I am having a hard time finding them.
2009 550 XP EPS MOSSY OAK BREAK UP
mikemokas
Dirt Monster
- Reward points: 0
- Status: offline
2011/06/06 20:09:54
(permalink)
I bit the bullet and bought a factory polaris thermostat for my 800 yesterday.. when it arrives ill try and take it to napa and see if i cant get you guys a number thats less than 40 bucks!
12 Sportsman 800 EFI Pure Polaris Winch kit 28" Vamp EDL's on all skinny wheels 1.5" wheel spacers 06 Sportsman 800 EFI Highlifter Reduced Radiator Relocate Homegrown Snorks 28" Vamp EDL's 01 Sportsman 500HO -Traded- 2in front 26in PXT's Silverstar Pod Bulb
TRX300man
- Reward points: 0
- Status: offline
2011/06/13 22:13:30
(permalink)
I see lots of parts for the thermal fan sensor for the radiator. What about the other thermal sensor that goes on the side of the engine and causes the hot light to come on?
mikemokas
Dirt Monster
- Reward points: 0
- Status: offline
2011/06/16 17:06:33
(permalink)
got my thermostat in the other day from cheapcycleparts... got my dial indicator and read all of the dimensions to my local napa and they were unable to find an automotive match... I tried!
HIGHOCTANE
- Reward points: 0
- Status: offline
2011/11/12 11:13:13
(permalink)
Anyone found a cross for the newer Sportsman XP wheel bearings? Polaris went to these starting with March 2010 builds.. Polaris part number 3514699 I think maybe they had an oddball size made specifically for them..they seem to love to corner the market on replacement parts lol. Wouldnt be so bad if they weren't made in China bearings. Measurements on the package say its 44x72x33.1 These bearings are also used on the XP900 all 4, and the front of the 2011 / 2012 Rangers IIRC.
2011 RZR XP LE 2010 KT Turbo RZR (SOLD) 2010 Camo Outlander 800 Max-XT(Sold) 2009 Sportsman 850XP (sold) 2008 Sportsman 800(sold)
Brandon Broussard
Dirt Monster
- Reward points: 0
- Status: offline
2012/04/12 11:12:45
(permalink)
Looking for bearing and seal part numbers for 2008 700 ranger crew rear differential. pm me if you have em! Thanks!
04dak
Mud Slinger
- Reward points: 0
- Status: offline
Re: RE: Make a list of common numbers we need
2012/07/11 12:03:41
(permalink)
can i get a confirmation on a fuel pump for a 05 800 sportsman? Airtex E8198?
2005 sportsman 800 niteshaded head and tail lights. 12" RZR rims 26" Bearclaws 2500lb polaris winch polaris windshield supertrapp mudslinger slip-on ceramic coated exhaust
Micflynn
- Reward points: 0
- Status: offline
Cheep Version of the Expensive Polaris Cylinder Head Tempature Switch.
2012/07/31 10:00:26
(permalink)
This is a Cheep Version of the Expensive Polaris Cylinder Head Tempature Switch for Over Heating! I'v Cross checked Alot of Switches and this one seem to be a Winner. Specs are as Follows: It's for a 1997 Sportsman 400 - 4X4 - 2 cycle. But it was used on a lot of Polaris, Check original part number to cross to your Machine. ----------- NAPA Part# ECH FS111 Attributes: # Switch Terminals : 1 Coolant Fan Switch Temp Rating : On At 204-220 Deg. F. Coolant Fan Switch Thread Size : 3/8" x 18 Terminal Type : Round Female Warranty: 36 Months or 36,000 Miles Whichever Occurs First --------------------------------------- FS111 Switch cost $6.99 as of 7-26-12 Napa Switch Plug cost $13.00 as of 7-26-12 Napa Total cost $20!!! Original Polaris Switch $76.00 7-26-12 Ebay ---------------------------------------- Make sure to Purchase the NAPA plug that goes with this switch as you will have to have it to plug the switch into your electrical. Some modification is Required by cutting off the Switch wire you purchase with it and soldering a MALE plug with heat shrink onto the wire so it can plug into the wiring harness of your Polaris, unless you just want to cut the plug off your Polaris and wire them directly to each other! Thanks, Mike
tdhzx14
- Reward points: 0
- Status: offline
2012/12/22 19:52:54
(permalink)
New to the forum. I have a 99 Polaris 500 6x6. I have been looking for the front wheel and hub strut bearings. I have found the hub strut bearing at O Rileys part A4 (race and cone) for 6.59 (masterpro brand). The wheel bearings are A14 and run about the same price. I have used the wheel bearings and they are fine. Going tomorrow get the A4's and try them out. Does anyone know of a cheap place to get the Hub Coil (2201313) and the armature plate (511148). Also need a half shaft for the front. Thanks.
CajunZ71
Mud Slinger
- Reward points: 0
- Status: offline
2013/03/18 09:42:04
(permalink)
looking for replacement front diff seal for a 07' sportsman 500 efi.... ASAP if possible thanks guys
2007 Polaris Sportsman 500 EFI, Camo, 1.5 Lift on Front and Rear, Highlifter Hd Springs Powdercoated Black, Front brushguard and Rear Double Bar Bumper,29.5's x10 outlaws on ss212 rims, Triangle Stealth Snorkel, Home made Audio Pipe For the Zune, Hsp Exhaust, Hid's, and 3 light mod with relay ---Krewe Outta Control--- "We Like To Party"
Cole Boatright
- Reward points: 0
- Status: offline
2013/03/19 11:07:51
(permalink)
Any one know the part numbers for the U-Joints in the rear axles of a 96 Sportsman 500? Polaris shows 2 different part numbers for em.
09 Thundercat Snorkeled Radiator Racked 2.5" Lift B&J Tie Rods Spring Spacers 30" Backs 14" ITP Type 7's G-Axles Gorilla Prop Shaft HID's 3.0 Warn Gauges Coming Soon!!! 98 Foreman 400 4x4 AKA " THE SUBMARINE"
Jonathanfl
- Reward points: 0
- Status: offline
2013/07/24 19:25:53
(permalink)
Ive gone through every page in this thread and could not find anything about the front dif output shafts. OEM p/n is 3233953 and there is no way im shelling out $230+ per output shaft out of the two you need. Any help would be awesome.
Black Beast
- Reward points: 0
- Status: offline
2013/10/06 10:51:44
(permalink)
looking for crossing Polaris oil seal 3234300 to another seal from auto parts. its the seal for rear differential 850 xp. problem is shipping cost more than the actual part cost. would be nice to find a seal at a local parts house.
09 850 xp stealth blk with 31" outlaws 2003 polaris sportsman 700 28" swamp lites 2001 polaris sportsman 500 ho 28" swamp lites 1997 polaris explorer 400 26" stock tires 2005 artic cat 650 v2 28" swamp lites
Dezz
- Reward points: 0
- Status: offline
2013/10/06 17:32:37
(permalink)
Black Beast
Your best bet is too remove the seal and bring it with you to a bearing/seal dealer. They might be able to match it up then by measuring it, or at the very least tell you seal manufacturer part numbers for it or if they can even get it at all. Most times the manufacturer of the seal is written on the side of the seal with the their part number. You can also use this information to get a seal at a bearing/seal supply store.
2003 Yamaha Grizzly 660 Dalton Clutch Kit 30" S/W Maxxis Zilla's on 14" Vision wheels 2500 lbs. WARN High Strength Axles - SOLD - But not Forgotten 1998 Grizzly 600 27 x 11 - 12 Maxxis Zilla- Back Tires 27 x 10 - 12 ITP Mudlite XL - Front Tires ITP Delta Black Chrome Rims 4 - Kodiak 450 Clutch weights Uni Air Filter Warn A2000 Winch Oxlite CV joint protectors Detroit Gearless Locker - Best $ Spent
