High Lifter Forum
Forum Navigation
 Make a list of common numbers we need
Change Page: < 1234567 > | Showing page 5 of 7, messages 121 to 150 of 208
Author Message
Newfie Polaris
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Wednesday, November 28, 2007 1:10 PM ( #121 )
OK, guys ive searched the post about 200 times, im looking for front bearing numbers for an 06 500 efi, if anyone can link me to it if im missing or if anyone knows the actual number off these bearings it would be a big help, a local bearing guy sells em for 5.99 race and cup and seal, he needs the number off the bearing itself to match up,
Are the front bearings the same in the 500, 600, 700 , 800?
PolarisTodd
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Wednesday, November 28, 2007 9:37 PM ( #122 )
ORIGINAL: Newfie Polaris
just search and read this post/topic. bearings are availabe from parts dealers (advance auto etc.) for about 25.00. less than that be leary
Polaris 500H.O.
Heel Clicker
Supertrapp IDSX Full System
DynoJet Kit
K&N
Warn 2.5ci
Synthetic Rope
Highlifter Lift Springs
Swamp Witch 28's
Vision Wheels with 1.5" spacers all around.
Lot's of MONEY on Polaris required maintenance
Newfie Polaris
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Thursday, November 29, 2007 1:34 PM ( #123 )
Well, i dont have Advance auto tech here in the maritimes in Canada, and all i need is a number from one of the bearings to match, and to that, like i asked, are the bearings the same for the different sizes of machine?
Big_T
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Thursday, November 29, 2007 1:50 PM ( #124 )
yes, 500, 700, 800, etc all used the same bearings.
Split audiopipe (self built)
Heelclicker
Newfie Polaris
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Thursday, November 29, 2007 3:41 PM ( #125 )
Thank you Big T
DaButcher
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Sunday, December 16, 2007 9:28 AM ( #126 )
Sportsman 800 fuel pump
Airtex E8198   $79.97
OEM pump  $452
06 800 Sportsman
G O R I L L A lift
29.5 Outlaws
2PO4me
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Friday, December 21, 2007 5:55 PM ( #127 )
oil drain plug for a 05 700 sportsman? want a socket head to replace the allen head
05 Sportsman 700 stock till i get some$$$$$$
00 Explr 400 2 stroke, s. swampers, clutch kit, broke and scratched but still puttin
http://i158.photobucket.com/albums/t115/rek1015/meandsean.jpg
DaButcher
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Saturday, December 22, 2007 8:17 PM ( #128 )
Outstanding 30,000 hits on this thread!!!!!
Hope it has helped others as much as it has me.
DaButcher, formerly  SemperVigilo
06 800 Sportsman
G O R I L L A lift
29.5 Outlaws
Honda_Man_09
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Monday, December 24, 2007 10:59 PM ( #129 )
Is the part # for the front ranger springs you guys are using on atvs to prevent front end sag 7043094-067? Thanks
2008 Polaris Sportsman 800
29.5" laws on chrome Vision 159s
Snorkeled
2" lift up front
Ranger springs on the rear
HL Clutch kit
Front and Rear bumpers
Warn winch
For Sale
2000 Foreman 450
gcharlesadamsjr
  • Reward points : 0
RE: Make a list of common numbers we need - Wednesday, December 26, 2007 9:23 PM ( #130 )
Hello,
Thanks for all the parts subsitutions! Motivated me to quit feeding the Polaris monkey and do a bit of detective work.
I have found a universal joint to add to the ever-growing list. Note: these are smaller than the u-joints listed for earlier in this thread for larger ATV's.
2001 500 Sportsman HO RSE
Polaris part number 2200771
Cost: $72.79 ea. online at World of Powersports (I really hope this was a typo)
I measured my u-joint and went to Advance Auto Parts and found someone who could find the paper catalog that list the size of all available u-joints. Had to order the part and had it the next business day.
Advance Auto part number 1-0121
Brand name: neapco (some Italian flavor U-joint I never heard of previously)
Cost: $16.96 ea.
This part number fits all four locations. Make sure you measure the removed part and the new one. I actually had one of the four that was about .020 too long. Luckily this was the first one I installed so I measured it. All of the others were within spec. ( I took a grinder to the bad one to avoid ordering another and avoided having to walk to my secluded hunting spot again!)
I bought my Polaris used and I have cursed it ever since because I work on it more than I ride it (proven fact). I have to admit that all of the failures to date stem from lack of maintainence. Check your fluid levels especially in the front hubs. If they dry up which causes extreme heat, the garter spring turns into spagetti and it will lock the hub into 4WD when you are at high speed. You will have a wild ride turning hard left or right at best! At worst you will flip.  While I was fixing this issue, I discovered the front diff was almost empty and had water in the gear oil due to a worn and leaking seal. Also noted the u-joints were toast (no grease in them).
Maintain you ATVs! If you don't they might try to kill you.
Hope this helps,
Charles
2001 Sportsman 500 HO RSE (for fun)
1991 Yamaha YFM250B (for when I want to get there)
alivenwellntx
  • Reward points : 0
RE: Make a list of common numbers we need - Monday, January 07, 2008 9:15 AM ( #131 )
I just got off tha phone with tha guys at SPAL and the person i talked to said they dont sell just tha fan motor....i gave them tha part number off tha factory fan that came off my 06 700 sportsman and they gave me a part number of 3010 2022 and told me that was the same waterproof fan that i had in front of me and it cost $173.20......still cheaper then polaris....if anyone knows something or someone at SPAL we need to talk to to get one of those $75 fan motors it would be a big help to me and everyone else im sure
06 700 yellow with some stuff done to it
00 500 army green with a lift and some tires
Gary
brutebog650
  • Reward points : 0
RE: Make a list of common numbers we need - Monday, January 07, 2008 9:29 AM ( #132 )
i got a fan from oreillys for $60 on saturday. one of those "rapid cool" universal 12in fan.  works great so far.
07 Sportsman 700 EFI Red-29.5's-3in lift-HotSeat Dual Pipes-Deepdish Torks-Brushguard-Rear Bumper-Rack Extenders-Backrest-Cupholder-Ice Chest-Triangle Snorkels-Ammo Box-OtterBox Ipod Case/Mount-Speaker Box-HIDs
05 F150 supercrew lariat 4x4 loaded-5.4-Pipes-SCT SFD-HIDs-more to come
MYSPACE
DOZER77
  • Reward points : 0
RE: Make a list of common numbers we need - Monday, January 07, 2008 2:13 PM ( #133 )
This is the one I have on my 800
Had to use the shroud and plug off the old one, but it pulls more air and is a spal fan
http://cgi.ebay.com:80/ebaymotors/11-SPAL-ELECTRIC-PULLER-FAN-1390CFM-SPAL-30102054_W0QQcmdZViewItemQQcategoryZ33600QQihZ020QQitemZ300183755923QQrdZ1QQsspagenameZWDVW
2009 Rhino S/E Black
Tunes on TOP
Laws on Bottom
Piped and cooled high and
Blink Blink
2005 Sportsman 800
a couple of bumpers
a pull you out thang
Bling Bling wheels
and mud slinging tires
alivenwellntx
  • Reward points : 0
RE: Make a list of common numbers we need - Monday, January 07, 2008 6:04 PM ( #134 )
tha one your talking about David is tha one i got on mine now thats going out after three rides....they do ok if your in a bind and just cant wait on tha right one but they aint waterproof and wont last very long .
Gary
DaButcher
  • Reward points : 0
engine mount replacement - Monday, January 28, 2008 5:34 AM ( #135 )
NAPA Part Number is 602-1069, very close motor mount replacement. Appears to be a tiny bit taller. Uncomfirmed, found this on another forum.
06 800 Sportsman
G O R I L L A lift
29.5 Outlaws
RBarnett95
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Saturday, April 05, 2008 2:48 PM ( #136 )
Just another number for ya'll.   Carter fuel pump # E7000 is the same as a 05 700 efi.  I bought it at oriely for 89.99.  The only difference is the strainer that comes with it will not work..  You will have to use your stock or have them find one that will work..
05 PoPo 700 28" Mudlights, Big Radio, Lots of lights, 10K HiD, Triangle Stealth Snorkel, Heelclicker
Sledgehammer
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Friday, April 25, 2008 10:02 PM ( #137 )
Are the federal-mogul 510013 bearings the same ones that fit the 06 polaris 700 efi in place of the rear wheel bearings?
06 Polaris 700 EFI 07 Arctic Cat 650H1 http://www.myspace.com/Sledgehammer1579
RBarnett95
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Saturday, April 26, 2008 7:55 AM ( #138 )
Yes that is the rear wheel bearings..  I got them in mine no problems..
geardoc
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Tuesday, May 06, 2008 7:22 PM ( #139 )
Found the factory cooling fans today for only $61.95. This is the exact fan that came on my 99 Sportsman 500. Its the first (pull version) shown. http://www.jaycorptech.com/showproduct.aspx?productid=9
Sledgehammer
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Wednesday, May 07, 2008 4:53 PM ( #140 )
Put the fed mogul bearings in my 06.  Working great!!!  Thanks for the help.  Now anyone have a match for the front wheel bearings?
DaButcher
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Wednesday, May 07, 2008 5:55 PM ( #141 )
ORIGINAL: Sledgehammer
510014
06 800 Sportsman
G O R I L L A lift
29.5 Outlaws
alforddm
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Monday, May 19, 2008 10:25 AM ( #142 )
We are replacing the front wheel bearings in a 2001 Sportsman 500 ho 4x4.  We have the Timken bearing numbers but when we went to the parts store to get them they didn't have the Timken so cross referenced them to a different brand and the bearing cup weren't included with the bearings.  Do these normally come without the bearing cups?  If so does anyone have parts numbers for the bearing cups?  The bearing numbers are Timken-L44643 and Timken-L44649.
Thanks,
Daylene
jmunson_3
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Tuesday, May 20, 2008 10:43 PM ( #143 )
This is a match for the oil filter on a sportsman 500, the link has other bikes too but I'm not sure about the twin bikes.  I have actually found this filter at my local Wal-mart. Hope this helps someone.
http://www.power-21.com/HoneywellPower21i/RelatedInfo.aspx?b=F&f=FRAM/framrv_atv_1210.pdf
This is the link to the fram parts catalog for atv and pwc.
Sortsman X2 2007-2008 . . . . . . . . . . . . PH6017A
Sportsman 500 1997-1999 . . . . . . . . . . . PH6017A
Sportsman 500, 6x6 2000-2008 . . . . . . . PH6017A
Xplorer 500 1997 . . . . . . . . . . . . . . . . . PH6017A
800cc
Sortsman X2 2007 . . . . . . . . . . . . . . . . PH6017A
07 Sportsman
500 H.O. EFI
3000 Viper Max
29.5's on MSA wheels
stealth snorkel
stereo, backrest and of course CUP HOLDER!
http://www.myspace.com/jmunson3
02POPO
  • Reward points : 0
RE: Make a list of common numbers we need - Saturday, May 24, 2008 7:41 AM ( #144 )
Not sure if this was posted.  700 front wheel bearing specs per BCA.
Ball Bearing Bore=1.378" Outer Diameter=2.5197" Width=1.4567" Inner Race Radius=0.165"
Maybe cross refferance at your local bearing dealer.
bopfly
  • Reward points : 0
  • Status: online
RE: Make a list of common numbers we need - Friday, June 27, 2008 7:09 AM ( #145 )
We started using NGK Iridiums on our machines and so far so good.  We were fouling out the regular NGK's pretty quickly.  I'm assuming the problem was the programmers on our machines.  Anyway here's the ones we're using on our twins, including the RZR.
BKR7EIX - NGK Iridium Spark plug (we're paying 8.69 at Summit Racing)
BKR7E - Regular NGK plug (this one is 1.99 at Summit)
His:
2009 Sportsman XP 850, LE
Hers:
2010 CanAm Outty Max XT 650
tp://www.rockycreekatv.com/
Rebel64
  • Reward points : 0
RE: MV-7 Blackout Lens - Thursday, July 17, 2008 4:49 PM ( #146 )
#2410642  $80 or so.
07 800 Stealth
joejoe1981
  • Reward points : 0
RE: MV-7 Blackout Lens - Sunday, July 27, 2008 9:10 PM ( #147 )
got a 2007 500 ho just replaced the seals and bearing were the front prop shaft goes in the diif and its leaking again, need to know about this speedi sleeve were to get it as well as the other seals and bearings that go with the front prop shaft going into the diff. Thanks!
07 PoPo 500 H.O. EFI
Vision wheels
29.5-10's and 12's
Relocated radiator thanks to dirt bmw20
Custom stereo
Backrest
HSP slip on
**** Lift 2"
Front and rear bumpers
Strobes
Doing everything i can in one day, cause you only live once!!!
J_Fred
  • Reward points : 0
RE: MV-7 Blackout Lens - Sunday, August 10, 2008 7:05 PM ( #148 )
For 1997-2000 Non-HO 500 Sportsmans
Polaris front strut Bearings #3554509  $18 bucks a pop
replaced by:
John Deer JD8935 About $5.00 each
Polaris front wheel hillard hub bearings  #3554506 $18 each
replaced by:
John Deer JD8933 about $5.00
You can carry any style roller bearing found in 96-2004 Sportsman to John Deere dealership, and chances are they will have it, for about a quarter of Pure Polaris' prices.
2001 Polaris 500 H.O.
1.5" RDC lift
29.5's on Douglas Diablos
RDC Assisted Snorkles
K&N Breathing Apparatus
3 Headlight mod
gsbuick65
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Tuesday, August 12, 2008 10:41 PM ( #149 )
you can take out the shielded bearing on the fan motor and replace it with a sealed bearing, then ill be waterproof, i put it on my 97 stopped because of mud, took it off  cleaned it up replaced the bearing put it back on was still working when i sold it.
Mike
97 Xplorer 500 (sold)
04.5 Sportsman 500
06 Sportsman 500
05 Dodge ram2500 4x4 CTD
Southaven Ms.
brewsters brute
  • Reward points : 0
RE: Make a list of common numbers we need - Saturday, September 13, 2008 11:19 AM ( #150 )
DOES ANYONE HAVE A PART NUMBER FOR THE UJOINT ON THE FRONT AXLE SHAFT THE POLARIS ONES ARE 75 BUCKS. AND CAN ANYONE HELP ME WITH ANYINFO AND PICS ON  HOW TO SNORKEL A 500 POLARIS SPORTSMAN HO
Current active users
Icon Legend and Permission
  • New Messages
  • No New Messages
  • Hot Topic w/ New Messages
  • Hot Topic w/o New Messages
  • Locked w/ New Messages
  • Locked w/o New Messages
  • Read Message
  • Post New Thread
  • Reply to message
  • Post New Poll
  • Submit Vote
  • Post reward post
  • Delete my own posts
  • Delete my own threads
  • Rate post
