Change Page:
< 1234567 > | Showing page 4 of 7, messages 91 to 120 of 208
alwaysbroke
Total Posts
1074
Reward points
RE: Make a list of common numbers we need
Wednesday, May 30, 2007 9:36 AM
( #91 )
Two things I've recently replaced in my 2005 500H.O. Spal fan #3 0100597. You will have to use your shroud and blade. The plug and motor are exactly the same as what comes with the bike. $74.96 plus shipping. Only took 10 minutes to swap the blade and shroud over to the new motor. No cutting or splicing any wires. Spal Phone # 1-800-345-0327 Spal Website: http://www.spalusa.com/ The people at Spal are great. Easy to talk to and soooooooooooo helpful. [:)] Rear Wheel Bearings: Federal-Mogul Bearings 510013 Thanks to polaristodd for the help and info. [;)]
mud baron
Total Posts
90
Reward points
Friday, June 08, 2007 2:44 PM
( #92 )
anyone come up with a thermo-stat for a 05 400........mine keeps getting hung up (i think its warped)....$57from polaris...thats a ripoff....
yellow06700
Total Posts
28
Reward points
Tuesday, June 19, 2007 9:39 AM
( #93 )
in case you need anything to do with boots or CV joints or anything of that nature American CV has all of it the # is 1-866-288-3003
2006 Polaris 700 Twin (Yellow) 2" Highlifter Lift Kit AAEN Mega Power Exhaust K&N Air Filter 27" Mud Bugs on ITP 7 Series Chrome
DaGrizz
Total Posts
20
Reward points
Monday, June 25, 2007 9:44 AM
( #94 )
ANYONE have a number for a fuel filter for 05-700 Polaris EFI. Local dealer wants $40
If your goon be a bear, be a GRIZZLY!
DOZER77
Total Posts
384
Reward points
Thursday, July 26, 2007 10:11 AM
( #95 )
2009 Rhino S/E Black Tunes on TOP Laws on Bottom Piped and cooled high and Blink Blink 2005 Sportsman 800 a couple of bumpers a pull you out thang Bling Bling wheels and mud slinging tires
bamakc
Total Posts
2
Reward points
Monday, August 13, 2007 5:02 PM
( #96 )
guyroy
Total Posts
1
Reward points
Monday, August 13, 2007 8:00 PM
( #97 )
what about oils? should i keep buying the expensive polaris oils for difs, tranny and engine or is regular oil OK?
PolarisTodd
Total Posts
838
Reward points
Monday, August 13, 2007 8:13 PM
( #98 )
For front diff...YES. On all other as long as it meets minimum requirements you are OK.
Polaris 500H.O. Heel Clicker Supertrapp IDSX Full System DynoJet Kit K&N Warn 2.5ci Synthetic Rope Highlifter Lift Springs Swamp Witch 28's Vision Wheels with 1.5" spacers all around. Lot's of MONEY on Polaris required maintenance
KSCFIRE
Total Posts
33
Reward points
Wednesday, August 15, 2007 12:50 PM
( #99 )
It was time for me to replace my front and rear diff seals for my axles. I bit the bullet and purchased Polaris ones. I then took them down to my local seal and bearing shop, Miller Bearing. The guy at the counter measured them and found matches for the front and rear axle seals and the front shaft seal. I didn't have a rear shaft seal with me. The seals are Chicago Rawhide and the part #'s are: Rear axle- 19630 @ $7.14, Front axle- 692461 @ $4.53 and Front shaft- 692321 @ $ 4.04. I forgot to ask if they were single, double or triple lip seal. As for the flat lipped o-rings for the front that were in the seal kit from polaris, I was refered to a local hydralic shop. I was told there they could probably match up those, but would have better luck if I were to bring in the case so they could get a more accurate measurement off the groove in the case. I haven't got a chance to place these next to the Polaris seals yet to compare, but I hope to soon. If they are the same, what a savings. I should also mention this is for my 04' SP700.
<message edited by KSCFIRE on Wednesday, August 15, 2007 12:56 PM>
2004 Polaris Sportsman 700 3.0 Warn 26" MudLites My other ATV is a tank.
KSCFIRE
Total Posts
33
Reward points
Friday, August 17, 2007 6:12 PM
( #100 )
I got the seals today, matched them up at the counter with the parts guy. They're a match. Only one difference is they are single lip not triple. I ask him straight up "Will this make a difference"? He stated that the specs from Chicago Rawhide say the single one is equal. I asked him why the Polaris ones are triple, and he said he believes it's just an extra dust seal. If I get time next week I'm going to tear into my diffs and replace the seals. I'm going to go with the Chicago ones first to give them a try. If them don't work out I'll still have the Polaris ones in reserve. Cross you fingers we might have another $$$ saver.
Dirtbmw20
Total Posts
3893
Reward points
RE: Re: Make a list of common numbers we need
Saturday, August 18, 2007 10:16 PM
( #101 )
ORIGINAL: chvylac anybody have a part number for ball joint for the front struts?? Anybody ever get any info on this ???? I too would love some aftermarket part numbers on some ball joints.
05' Sportsman 500 H.O. Rubber Down 3" Lift Lots of "goodies" I couldn't afford Dirtbmw20's Pics
ouch1175
Total Posts
124
Reward points
Monday, August 20, 2007 8:03 PM
( #102 )
Not likely to find one but what about the coil/plug wire assembly for an 06 500 EFI? Gonna go check the parts store tomorrow.. There has to be a replacement for something (I hope) OEM is 150 bucks?
green700efi
Total Posts
130
Reward points
Tuesday, August 21, 2007 9:16 PM
( #103 )
oil filter for the 06 700 popo wix 51356 but if you get in a bind its the same filter that the 02-06 grizz uses its just a little longer the number on the grizz is 51358 but they are interchangeable
The Bourbon Legends 07 800 sportsman 6" modified monkey lift 25% gear reduction 1.5" pucks on all 4 h.o. headers heelclicker clutch kit jams snorkeled through the box HL temp guage 29.5x12's on visions 1.5" spacers on all 4 hid lights blinky blinky lights powered by jack daniels Snappin' necks and cashin checks
BigAl
Total Posts
398
Reward points
Tuesday, August 21, 2007 9:23 PM
( #104 )
The output seals measure 40X52X8, A 7 WILL WORK TOO. The input seal measures 25X47X8, A 7 WILL WORK TOO. The output bearings are 6008-2RS, ORS brand and the input bearing is 6306-2RS, ORS brand. 2005 and up front diff's
2005 500 POPO Relocated Radiator 28 Laws, spacers 06 EFI Drive Clutch
PolarisTodd
Total Posts
838
Reward points
Wednesday, August 22, 2007 5:51 AM
( #105 )
ORIGINAL: Dirtbmw20 ORIGINAL: chvylac anybody have a part number for ball joint for the front struts?? Anybody ever get any info on this ???? I too would love some aftermarket part numbers on some ball joints. Anybody on Tie Rod ends??
old ranger
Total Posts
102
Reward points
Thursday, August 30, 2007 11:34 AM
( #106 )
Any numbers for water pump seals for a 500?
DOZER77
Total Posts
384
Reward points
Thursday, August 30, 2007 10:01 PM
( #107 )
Newfie Polaris
Total Posts
28
Reward points
Monday, September 03, 2007 7:04 PM
( #108 )
Has any one found a part replacment for the front bearings yet???
PolarisTodd
Total Posts
838
Reward points
Monday, September 03, 2007 7:13 PM
( #109 )
ORIGINAL: Newfie Polaris Has any one found a part replacment for the front bearings yet??? Search this post. there is plenty of info.
223s
Total Posts
91
Reward points
Friday, September 14, 2007 6:57 PM
( #110 )
Has anyone find a source for the Tranmission Switch. Mine is showing a E show I guess it a Error. I can pull the plug out and put it back in and it works for a while but starts messing up when I start shifting again.
ouch1175
Total Posts
124
Reward points
Saturday, September 29, 2007 7:16 AM
( #111 )
Need a starter replacement and avoid that 300$ OEM? I got a starter for my 06 500 EFI with a one year warranty for like 80 bucks shipping and all and it is a 100% match to the OEM one. Apparently this model starter has been used on hundreds of applications. Anyways if you need a starter search for DB Electrical on google and you should find the place no problems or you can call 800-753-2242.. You can also get rebuild kits and all that but just buying the starter was like 15 bucks more.[;)]
polarisgirl400
Total Posts
4
Reward points
Monday, October 01, 2007 12:50 PM
( #112 )
What are the tie rod ends that I would get for an 2000 -500?
Rebel64
Total Posts
2924
Reward points
Saturday, October 06, 2007 8:52 AM
( #113 )
Ring, spring (for front half shaft assembly) # 7710581 Anybody know of an exact match to this? Neither popo dealer around me has this in stock, and that's all I need to get my bike running.
07 800 Stealth Lifted, Lawed, Turners, Triangle snorked, Dirts Rad Bracket, OffRoadSoundSystems split jams...and other stuff.
mud_duck
Total Posts
3381
Reward points
Monday, October 08, 2007 9:59 AM
( #114 )
Sportsman 700 2004.5 fan from Spal, $127.95 You will use only the motor and have to use your original waterproof plug.
R&R Performance ATV Texas Mud Hole Patrol 2009 Renegade '04.5 Polaris CLICK My Pics ______________________________________________ I may be old, but I'm not boring
DaButcher
Total Posts
276
Reward points
EFI fuel filter
Wednesday, October 10, 2007 5:23 PM
( #115 )
EFI fuel filter NAPA #3199 will work, but is some smaller.
06 800 Sportsman G O R I L L A lift 29.5 Outlaws
223s
Total Posts
91
Reward points
Monday, November 05, 2007 12:05 PM
( #116 )
I need fan motor or fan for a 2003 Sportsman 700. Anybody know a # for it. Thanks
popotoys
Total Posts
104
Reward points
Monday, November 05, 2007 12:22 PM
( #117 )
GARYK2303
Total Posts
38
Reward points
Thursday, November 15, 2007 7:19 AM
( #118 )
Hi everyone can anybody tell me where i can get a coil for an SP800. My coil wore through and started shorting out on the frame where it is mounted. In my opinion this part is very poor, i sealed it up with silicone and am currently using it. Prior to sealing it up when it got wet my bike would run terribly without any power. I am thinking about buying a new coil and the spacer that they now are using. Thank you.
2005 Polaris Sportsman 800 , Warn winch , 28" ITP 589's
Crash99
Total Posts
1
Reward points
Thursday, November 15, 2007 4:41 PM
( #119 )
I`m looking for a fan/motor for a 500 HO 2005. Do you have any number to help. The number I saw in the common list was non water proof. Thanks!
PolarisTodd
Total Posts
838
Reward points
Thursday, November 15, 2007 4:51 PM
( #120 )
ORIGINAL: Crash99 I`m looking for a fan/motor for a 500 HO 2005. Do you have any number to help. The number I saw in the common list was non water proof. Thanks! Spal fan #3 0100597. You will have to use your shroud and blade. The plug and motor are exactly the same as what comes with the bike. $74.96 plus shipping. Only took 10 minutes to swap the blade and shroud over to the new motor. No cutting or splicing any wires. Spal Phone # 1-800-345-0327 Spal Website: http://www.spalusa.com/ The people at Spal are great. Easy to talk to and soooooooooooo helpful. [:)] Rear Wheel Bearings: Federal-Mogul Bearings 510013 Thanks to polaristodd for the help and info. [;)]
