High Lifter Forum
Forum Navigation
 Make a list of common numbers we need
Change Page: < 1234567 > | Showing page 3 of 7, messages 61 to 90 of 208
Author Message
Crazy Louie
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Wednesday, September 06, 2006 12:00 PM ( #61 )
Thanks for the reply. I will check on my buddies 800. Or I mite find a pure polaris header and pipe and put that on. Thanks and have fun!!!
jimmypsp700
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Monday, September 11, 2006 10:38 PM ( #62 )
I have the 800 dual header as many do on the sp700, not many want the extra weight of the dual silencers.
just go with a single like the PP/White Bros. silencer.
see picts here...
http://photobucket.com/albums/y148/jimmypsp700/800%20pipe%20-snorkle/
<message edited by jimmypsp700 on Monday, September 11, 2006 10:39 PM>
2002 Sportsman 700
-800 mods
-PP/White Bros. silencer
-DU Wetlands on Vison 160
2000 Scrambler 400 2x4
-Trail ported & modded
-Wiseco .040 over
-RcR /HPD Pipe etc...
Crazy Louie
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Thursday, September 14, 2006 8:10 PM ( #63 )
Did the 700 get more power with the 800 snokle and the 800 head pipe? Does the efi require a different map setting? Thanks for the pics to they are a lot of help!!
jimmypsp700
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Friday, September 15, 2006 12:32 AM ( #64 )
Not a lot IMO but it helps.
Others have claimed a much noticable difference.
You will need to rejet for optimal performace & Re mapp for the EFI units.
Jim
2002 Sportsman 700
-800 mods
-Wiseco .040 over
SLEDHEAD
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Wednesday, October 04, 2006 5:47 PM ( #65 )
hello. my fan was noisey so i removed the blade and everything under it.i then carefully pryed the case appart. make sure the magnets do not get mixed up as the fan may spin backwards if you do. the bearing is a common bearing used in many roller blade wheels. my local hardware store had a box in the bolt aisle with only 4 different sizes. one of the 4 was the same size, and even had heavy duty seals. the other end of the shaft is a bushing and was in great shape. i then packed the bushing with some good synthetic grease,and now the fan motor is smooth as silk. also the fan blade fit loose over the drive pin. i coated the notch in the blade, and the shaft with heavy duty black gasket maker.  installed the fan and clip and coated the end of the shaft and fan with the same sealer.  let it set up over night. the fan was never as quiet as it is now, and the gasket maker acts as a shock absorber between the steel drive pin and the plastic blade. the sealer i used should allow the blade to come free if it should ever need to come appart again.  the best part was the bearing was only 2.85 and the sealer i had kicking around the garage.  sure beats 250.00 from polaris.
mandylink
  • Reward points : 0
RE: Make a list of common numbers we need - Wednesday, October 11, 2006 4:35 PM ( #66 )
I dont know about the 700 sportsman but the 400 sportsman hub bearing race number is made buy timken L44610 The bearing is L44649 And the Strut bearing is L44643.
 If anyone knows the Timken number for the strut race it would be greatly appreciated.
mandylink
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Wednesday, October 11, 2006 4:50 PM ( #67 )
I need the number for a 400 sportsman strut bearing race from Timken. The bearing number is L44643 Also the hub bearing is L44649 and the hub race is L44610. But i dont know the strut bearing race number need help on that one
mandylink
THE maniac mechanic425
  • Reward points : 0
  • Location: MINNESOTA,But Currently Stationed in San Diego, CA
RE: Re: Make a list of common numbers we need - Thursday, October 12, 2006 8:06 PM ( #68 )
for those that do not want to pay 20 bucks a gasket, there is a NAPA gasket from idk what that fits your exhaust gaskets. (those donut things) it is
NAPA part # 31360
PROUD RIDER OF THE DARKSIDE
2004.5 SPORTSMAN 600 TWIN hunter edition (LIMITED EDITION)heated hand and thumb grips, hand guards, 2.5ci winch, OUTLAW MST's :), brush guard, double tube bumper, K&N filterS, HL temp gauge, semi lifted ... for now...
big ole lifted F-150
03 Ninja ZX-6R
www.myspace.com/navykid627
LOUD PIPES SAVE LIVES
FREEDOM ISN'T FREE, BUT IT'S WORTH FIGHTING FOR
PROUD TO BE A U.S. NAVY ENGINEMAN
chvylac
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Sunday, October 29, 2006 5:46 PM ( #69 )
anybody have a part number for ball joint for the front struts??
roade
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Sunday, December 10, 2006 5:37 PM ( #70 )
Dayco HPX Extreme Duty belt for 05 700 efi is part number hpx2204
oem belt is 3211091
pimp800
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Friday, January 05, 2007 11:41 AM ( #71 )
i know that a 700 belt part #3211091, will work in the 800's, polaris dealer said the 700 belt would not work, but i tried it anyway and no problems, actually i think it pops out of the hole a little better.. the 700 belt is $49 dollars and the belt for the 800 is $90.. so u do the math[:D][:D][:D]
08 RZR-pimp'd editon (black betty)
07 can-am 400 XT(lil red)
http://www.creekbottomtrailrides.com/teamcreekbottom.html
http://www.facebook.com/photo.php?id=609012570&pid=2928673#/album.php?aid=83496&id=609012570&ref=nf
TEAM CREEK BOTTOM
#8 Doug Popham
Creek Bottom trail rides
Moremudd.com
OPS tifton
Wobble
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Saturday, January 06, 2007 10:53 PM ( #72 )
Great thread guys, helped me find front and rear drive shaft UJ's for a buddies SP 600 on a saturday night, just got done putting them in. Polaris price $45 each, O'reilly #12 for their precision brand part number 338.
It was a PIA job, but what are you going to do when a buddies bike is down?
Mark
Killed - 2002 Grizzly, DIY Fully Snorkeled, K&N, Gorrila axles, 28x12.5x12 Outlaws, Dynojet with 165main jet. Kimpex Type 3 bumpers, Warn winch in the trash, 3000lb Harbour freight atv winch , Dual Batteries.
2009 Can-am Outlander xt 800R Camo, Running strong
prairedogg650
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Monday, January 08, 2007 7:36 AM ( #73 )
any numbers on rear diff bearings on the 04 700's? i saw someone posted axle bearings but those where wheel bearing #'s
07 800 Outlander
09 800 RZR
nuff said.......
my pics
TEAM CREEKBOTTOM #16
SemperVigilo
  • Reward points : 0
RE: Re: Polaris, Super Strength Tie Rod Ends report - Monday, January 08, 2007 8:19 PM ( #74 )
ORIGINAL: Godfather
This is the parts I just used in order to rebuild a rear end on a 2003 Sportsman 600.
Jew your parts dealers for the best prices. I rebuit this one for less than $90.
Beware that if you Penion and Ring gear is bad the best deal I found is $250.00 from Polaris. (Just in case)
2) Bearings - 6010-2RSC3 SRI-2 The brand is KYK
1) Bearing - 6306-2RSC3 SRI-2 The brand is KYK
2) Seals - Polaris PN 3233878
1) Seal - Polaris PN 3233785
1) Bushing - Polaris PN 3233577
1) Qt 90w Gear Oil
Praire ^^ should be the same for yours
Mud Mafia
We're in tha trash talkin business...... and business is good
"DaButcher"
06 800 Sportsman
a few goodies
Pics
redrockmudder
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Monday, January 15, 2007 6:35 PM ( #75 )
ORIGINAL: SLEDHEAD
i have an 06 sportsman 700 and my fan is also very loud. is this something covered under warranty or not?
WINDROCK ATV CLUB MEMBER
ROYAL BLUE RANGER MEMBER
07 Red Yamaha Grizzly 700 FI with Power Steering, Warn 2500, Ricochet skids, Blinkys, UNI, exaust tip, ITP SS 108 and 26" Swamplites, Kimpex rear box with top rails, Kimpex front box, Truck Nutz
http://community.webshots.com/user/redrockmudder
xpldavid
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Tuesday, January 16, 2007 1:05 PM ( #76 )
Will the Napa #338 U-Joint fit the front prop shaft?  If not, Does anyone have a part # for it?
08 Polaris RZR Snorkel, 3" Lift
Polaris 700 28" Outlaws, Home made lift kit, rejet carb, modified airbox, K&N, front & rear steel bumpers, 3000 Ramsey Winch, Rack mount radiator/fan, rear light etc. (The official get everyone out of trouble vehicle)
Hrdrck12
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Sunday, January 21, 2007 3:28 PM ( #77 )
What is the part number for a front wheel bearing in a 06 sp 500 H.O.?
06 sportsman 800EFI warn 2.5, K&N, front brushguard, rear bumper, front & rear rack extenders, handguards, & oury grips,3-way headlight kit, & 26in 589's .06 sportsman 500HO warn 2.5, K&N, front brushguard, rear bumper, front & rear rack extenders, handguards, longer wheelstuds, 800 rims, & 3-way headlight kit.
redrockmudder
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Friday, January 26, 2007 1:43 PM ( #78 )
well the dealer is replacing my radiator fan
gotmuddy
  • Reward points : 0
RE: Re: Make a list of common numbers we need - Friday, January 26, 2007 9:47 PM ( #79 )
ORIGINAL: xpldavid
Yes.  However I suggest the neapco version.  I went to a driveline shop and asked for a spicer version but he told me the neapco is better because the spicer has fewer needle bearings, and they are bigger.  The neapco has more of them, and they are smaller, so the trunion is larger.  I believe the part number is 5-170x for the neapco.
Ask me about 300trx gear reductions.
WTB/WTT:  9.9hp outboard, preferably merc, preferably electric start.
bookum
  • Reward points : 0
RE: Make a list of common numbers we need - Wednesday, February 07, 2007 8:12 PM ( #80 )
Just to confirm an earlier post.  The exhaust seal from NAPA #31360 Fit my 02, 700 sp.  I was $6.90+tax from NAPA.  $18.00 from the dealer
New polaris rider
Mad Mike
  • Reward points : 0
RE: Make a list of common numbers we need - Sunday, February 25, 2007 7:23 AM ( #81 )
any 1 have a # for the front strut for a 97 500 after market that is
DaButcher
  • Reward points : 0
RE: Make a list of common numbers we need - Thursday, March 01, 2007 5:40 AM ( #82 )
http://www.a-1injectors.com/fuel-pumps/buynow/e8198.htm
unconfirmed EFI fuel pump replacement
06 800 Sportsman
G O R I L L A lift
29.5 Outlaws
holdenfrickenon
  • Reward points : 0
RE: Make a list of common numbers we need - Sunday, March 11, 2007 11:21 PM ( #83 )
Mobil One has a filter for the twins. M1-110   One of there best oil filters. i run one on my 800. I have a filter cutter and I cut all filters apart after an oil change to look inside. Also I determine how well the filter has been made. This is the first Mobil filter I hae run on the 800 and will let everyone know what I think of it after I cut it apart. The stock Polaris filters are made quite well.
05 Sportsman 800, Mudlites, ITP Rims
06 Outlaw 500
MRMARIO2U
  • Reward points : 0
RE: Make a list of common numbers we need - Sunday, April 08, 2007 6:35 PM ( #84 )
STICK TO YOUR GUNS....
HONESTY ALLWAYS PROVELS
http://bricks4x4farm.com/ A PLACE TO DEFFINATLY CHECK OUT
http://s194.photobucket.com/albums/z120/MRMARIO2U/
http://youtube.com/profile?user=MRMARIO2U
http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=210811036 < local place to play
SOMEBODY HOLD MY BEER EZ IS COMEING TO HELP :)
TEAM WWMD?!!!!!
PolarisTodd
  • Reward points : 0
RE: Make a list of common numbers we need - Monday, April 16, 2007 11:42 AM ( #85 )
Sportsman Fan Replacement.. Polaris Part # 2410383  230.00 from Dealer
made by SPAL fans. at 1-800-345-0327  their part # is 30100411 for 79.95
Fits the following Applications:
2004 Sportsman 400
2004 Sportsman 500
2005 ATP 500 4X4
2005 Sportsman 400
2006-07 Sportsman 450
2005-07 Sportsman 500 H.O. and EFI
2006-07 Sportsman X2 500
You will have to use your existing shroud.
Polaris 500H.O.
Heel Clicker
Supertrapp IDSX Full System
DynoJet Kit
K&N
Warn 2.5ci
Synthetic Rope
Highlifter Lift Springs
Swamp Witch 28's
Vision Wheels with 1.5" spacers all around.
Lot's of MONEY on Polaris required maintenance
MRMARIO2U
  • Reward points : 0
RE: Make a list of common numbers we need - Wednesday, May 02, 2007 5:22 PM ( #86 )
TEAM WWMD?!!!!!
Mexican Mudder
  • Reward points : 0
RE: Make a list of common numbers we need - Thursday, May 03, 2007 9:22 AM ( #87 )
Anyone know of a belt for a 600??
PolarisTodd
  • Reward points : 0
RE: Make a list of common numbers we need - Thursday, May 03, 2007 3:13 PM ( #88 )
use the polaris belt
Polaris 500H.O.
Heel Clicker
DynoJet Kit
K&N
Warn 2.5ci
Synthetic Rope
Swamp Witch 28's
Mexican Mudder
  • Reward points : 0
RE: Make a list of common numbers we need - Thursday, May 03, 2007 3:37 PM ( #89 )
ORIGINAL: PolarisTodd
Yeah I just won't have much money right now to get one. I was looking for a cheap replacment for now..
gotmuddy
  • Reward points : 0
RE: Make a list of common numbers we need - Monday, May 14, 2007 1:54 PM ( #90 )
The cheap replacements aren't but about $10 cheaper.  I have found that OEM belts are the best to buy.
Current active users
Icon Legend and Permission
  • New Messages
  • No New Messages
  • Hot Topic w/ New Messages
  • Hot Topic w/o New Messages
  • Locked w/ New Messages
  • Locked w/o New Messages
  • Read Message
  • Post New Thread
  • Reply to message
  • Post New Poll
  • Submit Vote
  • Post reward post
  • Delete my own posts
  • Delete my own threads
  • Rate post
