This is the parts I just used in order to rebuild a rear end on a 2003 Sportsman 600.
Jew your parts dealers for the best prices. I rebuit this one for less than $90.
Beware that if you Penion and Ring gear is bad the best deal I found is $250.00 from Polaris. (Just in case)
2) Bearings - 6010-2RSC3 SRI-2 The brand is KYK
1) Bearing - 6306-2RSC3 SRI-2 The brand is KYK
2) Seals - Polaris PN 3233878
1) Seal - Polaris PN 3233785
1) Bushing - Polaris PN 3233577
1) Qt 90w Gear Oil
These are just some other parts that may help you.
U-joint for 2002 700 sp rear prop shaft - 1-0170 this is a SFK brand
U-joint for 05 700 sp rear prop shaft - 338 this is a Precision brand may be the same a 02 model??
Rear axle bearings for nearly all sportsmans that I'm aware of - 510013 this is a Federal-Mogul Bearing
CV Boot kit for the front of 05 model sportsmans - 8409 this is a Precision brand
CV Boot kit for the rear of all 600-800 model sportsmans that I'm aware of - 7427 this is a Precision brand
I hope this helps everybody out there save some money.
This post has help me quite a bit and I just wanted to give some back.
Thanks to
SemperVigilo for getting this post started and everyone else involved so far. Great job!!!
<message edited by Godfather on Sunday, May 21, 2006 11:02 AM>
