Helpful ReplyHot!Lift
HondaBoy01
2017/08/04 01:17:05 (permalink)
Lift
What lift should I run on my rancher 420 for 32 terms
jakem31_
Re: Lift 2017/08/06 20:59:44 (permalink)
probably gonna need bigger than 2 inches unless you want to trim the **** out of your plastics haha
Rebel Redneck
Re: Lift 2017/08/08 10:50:45 (permalink)
Yeah definitely a full suspension but I would do the motor before I did anything to Haven enough HP and gearing to turn those tires
Im Chase.
Current garage:
93 Honda fourtrax 300 4x4, snorkel, 2 inch lift, mudlites (needs rebuild)
92 honda fourtrax 300 "The Basher" 54%GR, 3inch lift, 30in mamba lites, lots of custom work.
2015 Polaris rzr 900 trail edition.
74 cj 5 Jeep. 3 inch lift and 33s.
70s coot utv.
86 Chevy k30 flatbed daily driver and also weekend wheeler.
Dezz
Re: Lift 2017/08/12 06:05:57 (permalink)
Like the guys have said above, you'll need more than just a lift kit to run 32" tires. Depending on what model of 420 you have (IRS or SRA model) will depend on what you'll need to fit those tires.
If SRA, you'll need to extend the rear sway bar to push the axle back. This will have to be a custom thing built by yourself. Then you still need at least 6" or more suspension lift in the front (I think bigger for 32's). A lift this big requires different a-arms, axles, brake lines, shocks, etc....everything is replaced except for the hubs.
If you have a IRS model, you'll need at least a 6" lift (I suspect you'll need bigger than that for 32's) all the around. If you can find a company who makes one for your bike, it will probably be in the $3000 plus range for this kit. If there is no kit made to bolt on, then you'll need to custom make this lift yourself as well.
Then on top of all this, you still got to do a gear reduction in order to turn those tires. Without it, you'll have a dirt road queen as you'll not have enough power or torque to go anywhere else. Put any strain on it and the bike won't move.....it'll just sit there and burn the clutch.
post edited by Dezz - 2017/08/12 06:11:05
2003 Yamaha Grizzly 660
Dalton Clutch Kit
2500 lbs. WARN
High Strength Axles
- SOLD - But not Forgotten
1998 Grizzly 600
ITP Delta Black Chrome Rims
4 - Kodiak 450 Clutch weights
Uni Air Filter
Warn A2000 Winch
Oxlite CV joint protectors
Jeepwm69
Re: Lift 2017/08/14 10:13:52 (permalink)
You're gonna have to do a LOT to a 420 to run those tires.  They will eat your rear end and transmission in short order.
Don Oglesby makes stretches and gear reductions, as do a few other guys.
It's gonna cost you $$$$.
BUSHHOG
Employee
Re: Lift 2017/08/14 12:29:07 (permalink) ☄ Helpfulby Jeepwm69 2017/08/14 13:33:37
Be smart, sell your 32's and buy some 27's. That is the sensible thing to consider. The absolute #1 mistake I see tire buyers doing is buying to much tire for their units.
Dan Doughty
Dezz
Re: Lift 2017/08/16 05:10:45 (permalink)
BUSHHOG
Completely agree.
This is words of wisdom to follow.
Dalton Clutch Kit
2500 lbs. WARN
High Strength Axles
1998 Grizzly 600
Uni Air Filter
Warn A2000 Winch
