LockedLacquer thinner for Carb cleaner?
Orangehonda01
2011/11/21 02:14:18 (permalink)
I got my carb rebuild kit today and also noticed that I had forgot to take the primer pump off the carb bowl during my earlier cleaning.  Well after taking the primer off, there was a bunch of junk sitting in the bottom.  So after a quick spray of carb cleaner it cleaned it out.   And there is a passage in that same hole that the primer covers, I sprayed into it and it came out of top of the bowl, where some funny looking brass piece is stuck into the bowl, maybe a weight or needle valve?  It appears clean.  However the same looking piece that goes directly behind the primer is completely stopped up.
I was wondering if i can fill the bowl with lacquer thinner and let it sit for a while????  Just the bowl and nothing more.  Of course the drain screw will be in but I have a new o ring to fit it.
Here is a picture of what is stopped up.  Either air or gas flows around ????? that piece.
Attached Image(s)
2001 Honda Rancher 350 4x4
-Warn 4-2-4 Select
-Trail Tech Stealth Vapor
-Savant Floorboards
3 Replies Related Threads
    gotmuddy
    Re:Lacquer thinner for Carb cleaner? 2011/11/21 08:29:29 (permalink)
    get a can of chem dip and use that.  make sure there are no rubber parts on the carb when you dip it.
    Heftysmurf
    Orangehonda01
    Re:Lacquer thinner for Carb cleaner? 2011/11/24 07:45:41 (permalink)
    Ok.  Well after reading your post I went and looked and found that Autozone sells it with a dipping basket.   I was wondering after i get a can about how long should i dip the bowl?  Any tips or Ill just follow the directions on the can.
    -Warn 4-2-4 Select
    -Savant Floorboards
    BridelessRacing
    Re:Lacquer thinner for Carb cleaner? 2011/11/24 11:26:39 (permalink)
    Follow directions on can
    Don Oglesby on facebook
    usefull
    420 gr
