LockedHow-to #3: Removing those pesky Honda fender clips (with pics)
Guest
  • Status: online
2008/01/28 17:36:46 (permalink)
Ever try to remove the clips that hold the plastic together on your Honda ATV? What a chore. The solution to this problem is to build a pair of pliers specifically designed to remove those fender clips.
To build your clip removal tool, grab an old pair of slip-joint pliers and grind the end into a "claw" that fits in the two notches of a Honda fender clip. Here are some stock slip-joint pliers followed by ones that have been modified.
29 Replies Related Threads
    Guest
    • Status: online
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 17:37:47 (permalink)
    Close-up view of the stock pliers followed by the modified ones.
    Guest
    • Status: online
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 17:39:20 (permalink)
    To remove a clip, simply fit the "claw" into the clip’s notches...
    Guest
    • Status: online
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 17:40:25 (permalink)
    ...and pull. Once the clip is disarmed, you can push it out from behind the fender or pry it out with a flat blade screwdriver.
    Guest
    • Status: online
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 17:41:25 (permalink)
    Or you can pull a little more. If you’re lucky, the clip will pull out in one piece. Like this.
    hondarecon4435
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 17:41:31 (permalink)
    that is a great idea i always just use a flathead scvrewdriver but i will be making a set of these
    2001 yamaha kodiak 400 4x4
    -plow
    -warn rt1500
    Guest
    • Status: online
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 17:42:27 (permalink)
    If the outer section of the clip stays behind, you can push it out from behind the fender or you can use your new clip removal tool to pull it out. You can also use a good pair of needle-nose pliers. Like this.
    Guest
    • Status: online
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 17:43:35 (permalink)
    And that’s all there is to it. Easy peasy, lemon squeezy.
    Not only do these pliers make quick work of fender clips, they allow you to reuse them as the clips are not damaged during removal. I’ve tried every method imaginable to remove Honda fender clips (including automotive trim tools) and these pliers are by far the best and fastest option I have ever come across. They work especially well when removing a large number of clips to perform maintenance/repairs.
    If you’re interested in seeing more of these illustrated how-to’s, I have a lot more and I would be happy to share them with you guys. I have one in particular that gives step-by-step instructions on how to repair leaky Honda carburetors that would otherwise require a replacement carb. That one applies to every carbureted Honda ATV ever built and it could save you guys hundreds of dollars. You won’t find this procedure in any OEM service manual as Honda wants you to buy a new carb instead.
    I hope people can benefit from these tips.
    gmcz71
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 17:46:00 (permalink)
    Thats a good idea, but I have used the wire-cutting plier things.  And they work fine.
    Ive done it about 83 times. [;)]
    sasquatch51
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 18:35:39 (permalink)
    I've heard it's the 84th time that gets 'ya using the wire cutters......
    2007 Rancher 420 ES
    Warn RT2.5 winch
    Bison Front and rear bumpers
    Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside yelling "Man! What a ride!"
    02rancher350
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 18:45:08 (permalink)
    i use the side cutter's also work fine as long as you done sqeeze to hard lol but this setup looks to work just great also [;)]
    2013 Outlander 1000
    31'' outlaws,MSA Kores ,Snorkles, LTE slip on, Dobeck gen 4 tuner,RDC rad relo,RDC Spring spacers,2'' Rox riser
    rubicon_joey
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 19:44:28 (permalink)
    Next time I see some of those cheap-o buy 1, need 10 to replace the broken ones pliers I think I just might pick some up. Good idea, but I won't be cutting up my craftsman pliers for this. I've gotten pretty quick with a flat bladed screw driver, but I've also gotten into the habit of rotating the clips so the little flat spots are easily accessible so I can pry at them with the screw driver.
    sold..(In the market for a new one now)...
    04 Red Honda Rubicon.....28X10 & 28X12 Maxxis Zilla's....Mud Buster Cam...2'' lift......EPI Clutch Kit...MSA Tork Wheels...HMF Utility series...Dyno Jet Kit...K&N Air Filter...Warn: 3.0 ci, bumper and 424 select...Detriot Gearless Locker...H/L Disc Brakes
    lsu_fan91
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 20:23:38 (permalink)
    its alot easier if you replace all of thoes clips with bolts and washers like i did...looks alot better and doesnt fall out or get loose [:)]
      TEAM BOGGY BAYOU BOYS
    Green 2012 honda 500 foreman.
    -30 zillas on diesel m12 wheels
    -spacer lift
    1998 Honda 300 4X4
    -30x11-zillas
    -30x9-zillas
    -14'' 112 chrome wheels
    -2'' inch wheel spacers
    -2'' highlifter lift
    -660 grizzly shocks in front and back cranked up
    -2''shock spacers
    -snorkel
    -locker
    -port an polished head
    -.75 weisco hc piston
    -'88 spec cam
    -jet kit
    -uni air filter
    -EPI clutch kit
    -HMF exhaust
    -re
    Steve07
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 20:29:04 (permalink)
    Bolts and washers? I am assuming also a nut? What are you supposed to do for the ones you can't get a wrench on?
    The modified pliers make a whole heck of a lot of sense and will save a lot of time.
    '87 TRX70
    '03 TRX350FM
    '08 TRX420FM
    lsu_fan91
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 20:32:52 (permalink)
    yea and nuts to....you can get to all of them...i got to all of mine...and all my buddies did to...on rincons 450, 500,rubi,and 300
    -spacer lift
    1998 Honda 300 4X4
    -30x11-zillas
    -30x9-zillas
    -2''shock spacers
    -snorkel
    -locker
    -'88 spec cam
    -jet kit
    -uni air filter
    -EPI clutch kit
    -HMF exhaust
    -re
    oldtrx
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/28 20:55:40 (permalink)
    ORIGINAL: lsu_fan91
    same here. and i used automotive (snap on) trim clip tools to get my old ones out and put them in my 200type1
    - www.gaorc.com
    ORIGINAL: ydopen
    "its not pretty, but its good enough for the girls we know."
    drew7693
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/29 08:00:49 (permalink)
    those plastic rivets are designed to fall out for a reason. The bolts, nuts, and washers will eventually make that plastic look like a badly beaten block of swiss cheese
    2008 yamaha Grizzly 700
    30x10x12 Silverbacks
    SS 108's
    2.5 warn XT
    DynaFS ignition
    Custom Radio "TUNES"
    HMF Utility
    HMF Optimizer
    K&N air filter
    Highlifter Lift springs
    Clutched!!
    Jake450s
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/29 17:34:23 (permalink)
    I made the same tool, but I started with a set of four inch oblique cutters (End cutting wire cutters).  Works good, but ONLY for the mudguard clips.  Yours is cooler, you're going to find so many things that those are good for that you'll forget why you made them in the first place.
    wlvrn
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/30 07:51:01 (permalink)
    slide a flat head screw driver into the clips notches and twist wrist
    i have never had a problem with any of them, except that one that holds the front brush gaurd on.
    but a very cool tool!
    #19
    MuddnMason
    Administrator
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/30 07:54:08 (permalink)
    Good write up! Looks like this is a candidate for the sticky! Please guys, help a brotha out and let me know when a thread of this type is posted. Threads like this need to be linked into the important threads sticky.
    --Phillip--
    This message is posted "as is" and confers no rights. All opinions expressed are personal and do not represent those of Highlifter Inc.
    #20
    TRX300man
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/30 08:30:49 (permalink)
    ORIGINAL: lsu_fan91
    Yeah ,and if you ever slip and hit something solid on the trail (like I did)  and you have nuts and bolts on your fenders (like I did) they cant pop out like the plastic ones do and the result will be a torn fender (like I did).  That made two times I had a nut and bolt in my plastic (the first AND last)
    Member of Harlan County Ridge Runners and Bell County Holler Crawlers
    http://www.flickr.com/photos/trx300man
    www.ridgerunnernation.com
    www.hollercrawlers.com
    1994 Honda 300 4X4
    2003 Honda Recon
    God does not believe in atheists!
    #21
    kodiak660
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/31 00:36:34 (permalink)
    Fantastic tips you are posting![:D]
    Thanks and keep them comming!
    I bet you could sell these as fast as you could make them.
    Videos
    07 Honda 420 Rancher ES 4x4
    06 Outlander 800 XT 2,900 miles (sold)
    03 Grizz 5,000 miles (sold)
    01 Rancher 5,800 miles (sold)
    00 Kodiak 7,500 miles (sold)
    94 Warrior 6,500 miles (sold)
    #22
    Disturbed Society
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/01/31 19:30:31 (permalink)
    Great idea, have used a flat blade without much problems, but that looks alot faster.  Taking a pair to work tommorow!
    2006 Honda Rincon (Camo), 25 inch Maxxis Bighorns For The Trails (Full of slime), 27 inch Outlaws on Black ITP SS 108's For The Mud,Big Red Gear Reduction, Custom Lift, FMF Powerline Exhaust, UNI Filter, Dynatek FI Controller, Kimpex Front Bumper, ATV-GURU.com Rear Bumper, ATV-GURU.com 2in Rear Hitch Reciever, Powermadd Handguards, Death Grips, Warn XT 30 with Amsteel Blue Line, AP Skid Plate Package, Radiator Spacers, Vent Lines Re-routed, 2" Stealth Snorkel
    My Vids http://www.youtube.com/user/lovechevy3
    #23
    rancher06.
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/02/28 09:48:27 (permalink)
    Being a former "Car Audio Installation Master" I have come across all types of specialty tools including home made. The Honda body clips are similar to a plastic clip found securing the trunk liner inside most BMW's.  Years ago I made a purchase on a "NONAME" tool truck with the perfect tool for the clips, It works extremely well on my Honda. they have  flat head (screwdriver) type ends and are spring loaded, I will post a pic tonight. I am currently contacting this particular vendor to find out the manufacturer.  I will keep you all posted.[8|]
    '06 Rancher 350FM
    27X12X12 Outlaws on 12X7 Stock Rears
    2.5" Spacers Rear
    2" Lift Front, Air Shock Rear
    Dynojet Kit w/132mm Jet, K&N, HMF & 1.5" Snorkel
    New Centrifigal with HL Clutch Kit
    Warn 3.0 RT, 3rd light, Fan Overide Switch
    #24
    John56_TMBz
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/06/13 20:43:56 (permalink)
    great tip!!!!!
    #25
    joel420trx
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/06/13 21:05:09 (permalink)
    good pics  they also sell pliers on the tool trucks same thing as you made but a little diff shape, works great on them clips , everyone i work with has a set
    http://www.myspace.com/joelamber80
    07 rancher 420 camo 4x4 es
    2" lift
    HL clutch spring kit
    26" sti mud trax, interco black alloys
    snorkel
    #26
    GeorgiaGrizz05
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/06/13 21:14:59 (permalink)
    those new pliers look like the thing of that movie "Tremors"
    2005 Grizz [SOLD]
    27" Mudlite XTR's (trail)
    Hauck Clutch Kit
    Ebay Power Tip
    K&N
    Dynojet Kit
    Relocated Radiator (fav. mod)
    Snorkeled
    #27
    talbtimber
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/09/15 17:46:30 (permalink)
    Catfish skinning pliers work good also.
    '06 Foreman 500
    26" Outlaws
    Warn Bumper (here but I don't like it)
    #28
    outlanderrider
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/09/15 18:49:24 (permalink)
    ORIGINAL: lsu_fan91
    Ditto. I replaced all of them.
    2007 Can-Am Outlander 400 H.O. Max Xt
    BRP Mirror
    T-M-2 Front pre-load adjusters
    BRP Rack Extension
    RCM Shift Knob
    BRP Fender Flares
    2001 Honda Rancher 350
    ITP Blackwaters
    PowerMadd Handguards
    Moose Precision Filter
    #29
    foreman4020
    RE: How-to #3: Removing those pesky Honda fender clips (with pics) 2008/09/15 20:51:13 (permalink)
    ORIGINAL: outlanderrider
    ORIGINAL: lsu_fan91
    me too  its just a hassle to take em out lol
    #30
