LockedHow-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics)
Guest
  • Status: online
2008/01/28 17:34:52 (permalink)
TRX300 owners know how difficult it can be to remove the rear axle nuts, especially if they’ve never been removed before. There are two of these nuts on each side of the axle and they are often frozen to the axle, making them very difficult to take off. Rancher 420 owners have not experienced this problem yet as the bikes are still too new, but wait a few years and the axle nuts will be a nightmare to break loose. A large open-end or adjustable wrench does not provide enough torque to remove seized axle nuts and those wrenches can round off the nuts, making them even more difficult to remove. The solution is to build a long socket that fits over the axle to allow the use of a large breaker bar, or better yet, an air impact wrench.
Here are close-up pics of the nuts in question. These are from a TRX300 but the Rancher 420 setup is very similar.
To build your axle-nut socket, get yourself a 41mm impact socket and use a chop saw to cut it in half. Next, find yourself a length of pipe and weld both parts of the cut socket onto the pipe, one on each end of the pipe. Grind the welds, paint the modified socket, and you’re in business. The total length of the socket should be aproximately 12 inches. Here’s what it should look like (the lines show where the cut socket was welded to the pipe).
Here is the drive end of the socket.
This is the business end of the socket. Just remove the ATV’s hub, slip your new socket over the axle, and easily remove those stubborn axle nuts in a matter of seconds. It works incredibly well. It also makes rear brake maintenance a breeze as the right side axle nuts must be removed to access the rear brake assembly on the TRX300 and Rancher 420. If you don’t have the welding skills or equipment to fabricate this socket, ask a friend or family member who does. It is well worth it.
24 Replies Related Threads
    gmcz71
    RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2008/01/28 17:44:03 (permalink)
    YES, those bolts are **** to get off the siezed old 300!
    Thanks for the tip!
    Steve07
    RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2008/01/30 23:27:14 (permalink)
    Please put this in the sticky section. I have rounded off so many axle-nuts that I slapped myself when I saw this. Seems so easy it should have hit me before. Excellent idea Dynamo.
    '87 TRX70
    '03 TRX350FM
    '08 TRX420FM
    myk
    RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2008/01/31 00:00:37 (permalink)
    excellent tech!
    an air hammer also works great too.
    rancher12
    RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2008/01/31 01:19:34 (permalink)
    a large pipe wrench will also do the trick
    2008 Can Am Outlander 800 XT
    Ricochet Skid Plates
    In the words of Gunther from the Longest Yard,"She's fast, she's real fast!!!"
    MuddnMason
    Administrator
    RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2008/01/31 06:23:42 (permalink)
    ORIGINAL: Steve07
    Done. Remember guys, I may miss a thread like this, so please PM me and send a link to the thread.
    --Phillip--
    This message is posted "as is" and confers no rights. All opinions expressed are personal and do not represent those of Highlifter Inc.
    foreman400x
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/06/28 15:41:01 (permalink)
    what size is the axle hub nut on a the rear of a honda 400 foreman
    1993 Kawasaki Bayou 300, current project
    rancherMAN420
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/06/28 16:58:36 (permalink)
    ^^^a 400 foreman doesnt have a axle nut like shown above
    07 420 rancher
    custom snorkel
    rad. up top
    28 laws
    HL clutchkit
    bedliner on racks
    modded stock pipe
    3.5in custom lift
    bunch of black,
    and orange spray
    paint
    axle paddle
    custom wheel sacers
    ''REDNECK CUSTOMS''
    gmcz71
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/06/28 17:04:19 (permalink)
    but I think its hub nut will be either be 15/16 or 7/8" not sure
    foreman400x
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/06/28 17:06:41 (permalink)
    its bigger than that..ive tried both its over 1"
    rancherMAN420
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/06/28 17:12:40 (permalink)
    i just finished takin the rearend of a 400 apart  but cant remember wat size the hub nut was 4 nothin one was froze up the impact wouldnt take it off had to get a grinder and cut it
    07 420 rancher
    custom snorkel
    rad. up top
    28 laws
    HL clutchkit
    bedliner on racks
    modded stock pipe
    3.5in custom lift
    bunch of black,
    and orange spray
    paint
    axle paddle
    custom wheel sacers
    ''REDNECK CUSTOMS''
    350rancherboy
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/06/28 20:51:48 (permalink)
    mech. in town did that..good idea..i just bought a big wrench lol good tip i need to make one.... 41mm huh..weres a good place to get the socket?
    1968 Chevy C-10 DD 355/3OTT
    tacoma_2002
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/06/28 21:12:24 (permalink)
    1 1/16th IIRC
    '08 Honda Foreman 500 4x4 w/PowerSteering (Olive)
    26" Vamps on Rubicon rims
    26" Kenda Executioners
    1500# Winch
    Aluminum Stick Stoppers
    Drop Basket Rack
    Gun Boot
    1999 Honda 300
    "Project 300"
    1998 Honda 300FW
    "Second Chance 300"
    Lifted, Lawed, Locked and Ready to ROCK!
    WHY?
    CAUSE CHICKS DIG IT!
    foreman400x
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/06/28 21:28:05 (permalink)
    i found it its a 20 mm
    countryboytew
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/06/28 21:34:56 (permalink)
    u can also heat them with a tourch it will make the nut exspand and make it easy to get off ( dont burn them off just heat)
    2001 RANCHER 4X4
    2 IN LIFT
    25 DIRT DEVILS (FOR NOW)
    NEW TOP END
    WISECO HIGH PERFORMANCE .25 OVER SIZE PISTON
    WARN 2500 WINCH
    WARN FROUNT BUMPER
    MORE MODS TO COME
    XLCat
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/06/29 07:54:18 (permalink)
    "a large pipe wrench will also do the trick"
    That's what I use.  Of course the nuts don't look so mint when I get done either!
    07 700 GRIZZLY---Outlaw MSTs: 28x9.5, 28x12; Warn 3000 w Amsteel, (4) CEC 1" spacers, UNI filter, 1.25" bar relocation, removed shifter lockout, exhaust tip, 9003 SilverStars
    01 Cherokee, Rusty's Long Arm setup, 4.5" coils, 3.5" leafs w 1.5" shackles, Rusty's HD trac bar and mount, Rusty's steering linkage and steering box brace, no sway bars, 8.8 rear w discs, HP Dana 30 front, 4.10s, hardcore front bumper---it'll flex just a tad!
    "Don't move, he'll do it!"
    bryanmach1
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/06/29 08:05:33 (permalink)
    Thanks for the tip.  When you see a trick this simple that can make a difficult job easier you just want to slap yourself for not thinking or it yourself.  I have a whole drawer in my box full of custom home made/modified tools just like this....
    05 H1
    28" MUDBUGS ON MAXXIS WHEELS
    29.5" LAWS ON SERIES 7 ITP
    2500 WARN
    stilltippin863
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/07/02 21:42:01 (permalink)
    do you break the outside one loose first or do both at same time?
     07 HONDA RANCHER 420 (GREEN)
    30'S ****
    50. CAL AMMO CANS
    INTAKE SNORKEL
    HMF UTILITY PIPE WITH SNORKEL
    4TH GEN 8GB IPOD NANO WITH ARMOR OTTERBOX AND RAM MOUNT
    CUSTOM 8 SPEAKER SETUP
    KINETIK KHC600 BATTERY
    POLICE STROBE LIGHT BAR RED/BLUE
    stilltippin863
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/07/03 10:48:34 (permalink)
    stilltippin863
    i got it all of and new brakes on now i just can not get the drum back on what do i have to do to get thbe drum to fit?
    30'S ****
    50. CAL AMMO CANS
    INTAKE SNORKEL
    #19
    XLCat
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/07/03 15:20:09 (permalink)
    Break the outside separately.  The purpose of two nuts is to preload the threads (locks the nuts on) by jamming them together.  So if you spin them both off together, it's harder, and you'll be roughing up the threads most likely.
    #20
    Bama Trail Rider
    Re: RE: How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/07/05 08:42:34 (permalink)
    Great idea thanks for the info!
    2011 Max 800 XTP
    07 Rancher 2wd
    07 Rubicon
    Viper winch
    Extreme 2" lift
    K&N air filter
    HMF Utility
    Highlifter springs
    Soon to come, 27" Zillas
    Always do what is right because it is always the right thing to do!
    #21
    sportcoupe
    Re:How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/07/11 08:03:27 (permalink)
    Are these axle nuts right hand thread or left hand thread?
    #22
    chrisb76
    Re:How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/07/11 14:37:20 (permalink)
    man a 20mm is smaller than a 7/8 or 15/16.thought foreman400x said he tried a 1'' and it was too small so are you sure its a 200mm.i always use a pipe wrench,but this idea is much better,but the 41mmsocket will cost you $25-$30
    old school kodiak
    6''lift,brute diffs.,gorilla's
    big ol' piston
    lots of balls
    TEAM ALL JACKED UP
    #23
    moss420
    Re:How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/07/11 17:41:24 (permalink)
    A torch works fine on the 420's to get the nut's off. You need to burn the Loctite off to get the nuts to move easy. Just make sure that you put some RED Loctite back on the threads when you put them back because THEY WILL COME LOOSE, causing the plate that seals off the diff. to come loose and letting water and mud/grit in the diff.
    07' 420 RancherES IRS. Gear Red., 29.5 Laws Mudslinger, Uni,PCIII(myCustomMap),BlackSS108wheels,Warn/RT2500              Wife's Black 08' 420 Rancher-Mudslinger, UNI,               PCIII(myCustomMap), 28x10 MudLites, Black-MotosportTrooperWheels
    #24
    Down.South.Ga.Boy
    Re:How-to #2: Removing stubborn rear axle nuts from your TRX 300/420 (with pics) 2009/07/11 22:07:46 (permalink)
    4 foot long monkey wrench works good.. just make sure you dont strip them out haha!
    08 420 Rancher
    29.5s
    SS112s
    Snorkel
    Rad. Relocation
    Viper 3000
    PC111
    HMF
    K and N
    FOR SALE
    05 TRX 450r
    FOR SALE
    #25
