Change Page:
< 123 > | Showing page 2 of 3, messages 31 to 60 of 64
devildog12210
Total Posts
4209
Reward points
Re:How to make PVC catch can
Saturday, April 18, 2009 9:03 AM
( #31 )
I am glad it helped you then! If you don't mind could you snap a few pictures of your setup and post them up here. I am sure others would like to see it.
wpatout
Total Posts
125
Reward points
Saturday, April 18, 2009 9:19 AM
( #32 )
Ill try and get them today. After putting all the plastics back on I started wondering why my biks was hard to start when cold. LOL So back off the plastics go and off to autozone for a gauge.
devildog12210
Total Posts
4209
Reward points
Saturday, April 18, 2009 9:42 AM
( #33 )
Have you adjusted your valves lately. That is the number 1 reason for hard starting.
wpatout
Total Posts
125
Reward points
Saturday, April 18, 2009 10:19 AM
( #34 )
Thats what I was going to attempt. Its not that hard to start but always needs full choke and it takes for ever when its really cold. It has 580 miles and I have had it since 250 but havent adjusted them. I doubt the original owner did either. He was running stock spring with the 30" mudlites since the day he bought the bike and kept warning me how fast it was. I wish he could ride it now with the lime green and 28 Backs. LOL
wpatout
Total Posts
125
Reward points
Saturday, April 18, 2009 2:19 PM
( #35 )
Catch can is under pod because I ran it back to air box. I got the valves done. It wasnt that bad after reading all the post on here about how to line up marks on comp stroke. It also helped to take off both covers to make sure both were closed. Back cylinder both intake and exhaust were very tight. Front the intake was fin spec. but exhaust was a little tight. It starts without the choke. So I cant wait to see how it runs. Waiting on EPI backorder. At least got everything done. MIMB snorkels, Devildog Catch can, cheap tie-rod fix, upper a-arms drilled and tapped with grease fittings. Traded 30 ML's for 28 Backs. Left in Lime green secondary instead of putting if red primary. AGAIN THANKS FOR THE HELP
<message edited by wpatout on Saturday, April 18, 2009 2:21 PM>
devildog12210
Total Posts
4209
Reward points
Saturday, April 18, 2009 2:37 PM
( #36 )
That looks awesome man!!! I really like how that turned out! Make sure you check those valves pretty often. Lots of damage can occur if they go unchecked! Glad you got it all taken care of though!
Metal Man
Total Posts
987
Reward points
Saturday, April 18, 2009 5:26 PM
( #37 )
wpatout thats alright right there. I like the T you used. Making the catch can out of PVC looks simple enough. Good idea devildog
08 Brute Force 750 FI MIMB Snorkels with 2 1/2 Air Intake 28 Zillas n ITP SS112's 6k HID's Temp Gauge VDI CopperHead VFJ Stage 3 Clutch HMF Swamp XL
Butch
Total Posts
853
Reward points
Saturday, April 18, 2009 8:40 PM
( #38 )
Devildog, can you not simply use a 3way fitting instead of the PVC pipe? Or do you need the space when it pukes oil?
2007 Brute 750 Team Green 2" HL lift, 2" snorkel, 29.5 Laws, Outlaw clutch kit, HMF Pipe, a bunch of stickers. 03 Rincon Sold! Joins us for a ride! www.southernmudslingers.com
nats39056
Total Posts
60
Reward points
Sunday, April 19, 2009 11:46 PM
( #39 )
The catch can has three fittings. does the vent hose from the crankcase go into the side fitting and the bottom fitting goes into the valve cover and vent the fitting on the top? Does this sound right? Thanks
2007 lime green brute force 750I custom radiator relocation MIMB snorkels w/3'' elbow Big Gun full system dynatek cdi 2'' SS ATV Plus lift kit 30'' sback w/ss212 red epi secondary spring Thermal Heat Sleeving water temp gauge dynojet jet kit air filter minder pvc catch can
devildog12210
Total Posts
4209
Reward points
Monday, April 20, 2009 6:23 AM
( #40 )
You are correct my friend.
nats39056
Total Posts
60
Reward points
Monday, April 20, 2009 12:48 PM
( #41 )
Cool, I have been wanting to do this mod but hadn't seen very much info on it. Thanks for the write up bro!
devildog12210
Total Posts
4209
Reward points
Tuesday, April 21, 2009 1:46 PM
( #42 )
devildog12210 Well I tore everything back down again to see how everything was looking. I ended up having to re route the return along side the airbox instead of along the frame. There was a slight dip in the line on the frame that was allowing oil to collect. I re ran it over my ptrap for my snorkel and beside the air box. All is good now. I realized after posting this I never posted the pictures. I found them while going through my cell phone. Here are a couple more for you guys. That last one is the somewhat finished product. I now have used hose clamps to attach it to the snorkel and I wrapped the clamp in electrical tape so it is black. I know my rad bracket is ghetto but after rolling it and braking my last one I whipped that one up from crap I had lying around.
devildog12210
Total Posts
4209
Reward points
Monday, April 27, 2009 11:27 AM
( #43 )
Bump530
Total Posts
3508
Reward points
Monday, May 04, 2009 8:55 AM
( #44 )
after having to remove my YFZ can to seal it up (always check them to make sure they dont leak around the seal), i decided to try the PVC tee fitting to elimate the need for reducing the size of the lines. now after installing the PVC can, i am getting more oil in my airbox than before. i lost enough oil that it wont read on the dipstick. anyone know why this is? my Tee is mounted straight up and down (maybe a lil forward). i have the crankcase vent ran to the middle, the drain on the bottom (to the front cylinder), and the airbox vent out the top. after having these issues, i might be goin back to the YFZ can. i just wanted to eliminate having to have splices in my line to reduce and increase the size.
Team BS - Bayou Slingers '94 Honda 300 4x4 27x9.5 Laws / XL2's FO-14 / K&N / Jet Kit '88 Cam / Clutch Kit 424 / Lock'd / GR Snork'd / 1.5" Spacers HIDs / Disc Brakes 2009 YZ450F - White http://www.myspace.com/Bump530
devildog12210
Total Posts
4209
Reward points
Monday, May 04, 2009 8:59 AM
( #45 )
I have no idea what happened there? I have about 200 miles on my bike with this setup and I have had great success. What size "T" did you use. Maybe the 1" wont work? I am not sure. I have the crankcase filter on top of mine but it would have turned black if oil was getting on it. It is just a standard paper filter. Maybe the "can" itself wasn't big enough and was creating a vacuum to the air box?
Bump530
Total Posts
3508
Reward points
Monday, May 04, 2009 9:34 AM
( #46 )
i am using the 1". i took the airfilter off and there is alot of pressure coming out of the line.
devildog12210
Total Posts
4209
Reward points
Monday, May 04, 2009 9:37 AM
( #47 )
Try bumping up to the 1.5"? I have no idea. It seems to be creating a vacuum. Maybe that is due to the smaller diameter tube. I know I can actually see the oil run down through mine. The guy that originally used the T hasn't reported back with ill results yet. Not sure what went wrong with yours. It really has me scratching my head.
Bump530
Total Posts
3508
Reward points
Monday, May 04, 2009 9:45 AM
( #48 )
i dunno what the deal is either. im thinkin bout switchin back to a YFZ can lol
devildog12210
Total Posts
4209
Reward points
Tuesday, May 12, 2009 1:37 PM
( #49 )
bump to get catch can threads on front page.
Dodge39180
Total Posts
77
Reward points
Monday, May 25, 2009 1:19 PM
( #50 )
I don't know if everyone is making these or buying them somewhere but we used to use these r.cing go karts. www.tbrwins.com has aluminum 1 vent catch tanks for 15.00 and personally they look alot better than the PVC.
devildog12210
Total Posts
4209
Reward points
Monday, May 25, 2009 1:56 PM
( #51 )
I looked at the site. They didn't have a picture. After googling it I finally found a pic and it will not work for this application.
east tx
Total Posts
420
Reward points
Monday, May 25, 2009 2:02 PM
( #52 )
devildog12210 Try bumping up to the 1.5"? I have no idea. It seems to be creating a vacuum. Maybe that is due to the smaller diameter tube. I know I can actually see the oil run down through mine. The guy that originally used the T hasn't reported back with ill results yet. Not sure what went wrong with yours. It really has me scratching my head. Would not be to the differance of you having an 07 and bump having an 08? Any differences or same principal.
devildog12210
Total Posts
4209
Reward points
Monday, May 25, 2009 2:04 PM
( #53 )
The motors are the same. The method of fuel delivery doesn't affect it any.
Dodge39180
Total Posts
77
Reward points
Monday, May 25, 2009 3:31 PM
( #54 )
devildog12210 I looked at the site. They didn't have a picture. After googling it I finally found a pic and it will not work for this application. Why wouldn't it work?
devildog12210
Total Posts
4209
Reward points
Monday, May 25, 2009 3:47 PM
( #55 )
Dodge39180
Total Posts
77
Reward points
Monday, May 25, 2009 3:57 PM
( #56 )
I know what it looks but why wouldn't it work. all you need to do is take the petcock out of the bottom and get a barb fitting for the return line. Or am i missing something
honda 680
Total Posts
275
Reward points
Friday, May 29, 2009 10:47 AM
( #57 )
I need all the info I can get mine is pukiing up oil
08 Black 750 brute backup bike 2006 700 efi cat 29.5 outlaws on ss212 epi clutch kit 2 inch lift snorkeled HL springs PCIII 2nd motor out of a 2006 brute
WoodBoy
Total Posts
1698
Reward points
Friday, May 29, 2009 11:01 AM
( #58 )
devildog.. be careful with that small filter on top.. a buddy of mine did the same thing and the filter didnt let the air flow good and cause his to pressurize
YELLER BRUTE,???cc's,AMRacing Motor,39mm Carbs, VFJ Stage 3, 31 Laws,Crushlocks,Twin Airbox Snorkels and Belt snorkels,ASR Pro Rods and Ends,Relocated radiator,Full Big Gun,Lift,Spacers,few more mods SCROGGIN' & BOGGIN'!!! 2010 F250 FX4 Lariat w/ Sync.. Recession is when your neighbor loses his job, depression is when you lose yours, recovery is when Obama looses his.
devildog12210
Total Posts
4209
Reward points
Friday, May 29, 2009 11:31 AM
( #59 )
I have been running this one for a while. I have extended the line to the filter and put it up underneath the pod. Other than that is has been working great.
hubbard1506
Total Posts
59
Reward points
Monday, March 08, 2010 9:31 PM
( #60 )
How would you make the catch-can waterproof? Im concerned that the small filter on top would get water/mud in it and make the oil milky, right? I just snorkeled the brute and plan to do waterwheelies, so I wont it done right the first time! x) Also I am still confused where to run the return, I've read the threads but many ppl have different opinions. Don't wont to mess it up worse!
