Hot!Hondagade Build
jakem31_
2017/08/03 04:43:09 (permalink)
Hondagade Build
so i am starting a hondagade build and have already got some basic stuff done as seen in pictures motorwork, stretch, etc. i need some help guys. i am on a budget and need help for the lift i know basics and have the tools. i just need to know basics like the size of arms and what heims to use and angles and things like that. i will post pictures so far soon. i need to do few seals for shafts and what not but i am working on that any help would be appreciated. i dont have the funs to get +6 gorilla axles yet so im thinking of using sleeved stock axles as mockups until i get the money. like i said budget but good build. what yall guys got!
34 Replies Related Threads
    jakem31_
    Hondagade Build 2017/08/03 04:47:20 (permalink)
    jakem31_
    Hondagade Build 2017/08/03 04:48:59 (permalink)
    Re: Hondagade Build 2017/08/03 18:34:49 (permalink)
    38 degrees on the cv axle. Build lift around your axle while in jig to keep axle at 38 degrees. 3/4 inch pipe from Lowe's. Use Foreman hub's which will give you disk brakes. Turner axles are cheaper than gorilla but needs Foreman hub's for clearance. 1/2 heim joints. Rear drive shaft needs to be heavy and not sleeved. 1" round bar drilled for cut drive shaft to be pressed in. Needs to be welded and heat treated.
    jakem31_
    Re: Hondagade Build 2017/08/03 21:52:43 (permalink)
    thanks! where do i need to contact for pricing and stuff fot the turners??
    Re: Hondagade Build 2017/08/03 22:14:00 (permalink)
    Turner cycles. Google it. There are also cobra but I have heard mixed reviews on them.
    jakem31_
    Re: Hondagade Build 2017/08/03 22:47:45 (permalink)
    ok great ill keep updates what im doing i think i got to get some money saved up for axels so im gonna make mockups until i get them should be starting this weekend hopefully.
    Re: Hondagade Build 2017/08/03 22:54:00 (permalink)
    Good deal. Turner's are like $450. Gorilla's $900. Just to give u some insight.
    jakem31_
    Hondagade Build 2017/08/03 22:57:37 (permalink)
    450 for both? or each ?
    Sent from my iPhone using Tapatalk
    Re: Hondagade Build 2017/08/03 23:02:19 (permalink)
    Set
    jakem31_
    Hondagade Build 2017/08/03 23:11:36 (permalink)
    thats not too bad at all.
    Re: Hondagade Build 2017/08/03 23:16:00 (permalink)
    Nope. Been awhile since I checked so hopefully price hasn't changed. I need to call too cause I need a set for another bike.
    jakem31_
    Hondagade Build 2017/08/03 23:20:10 (permalink)
    aight sweet hopefully tmr im gonna start stripping mh bike and getting up high so i dont have to break my back working on it lol
    jakem31_
    Hondagade Build 2017/08/03 23:24:43 (permalink)
    any tips on axle paddles id rather not weld to the axel but how do you keep one from slipping if not?
    Re: Hondagade Build 2017/08/03 23:25:44 (permalink)
    I built a table so i can walk around it. Make sure to make you a jig to hold your axles and keep everything squared. Also you probably need some ball joint plates to give you a good base to weld to.
    jakem31_
    Hondagade Build 2017/08/03 23:39:22 (permalink)
    i have a parts bike and im thinking about cutting out the ball joint plates and grinding them and using them they come off a 350 and seem to be pretty durable looking. smart money saver move? or nah? lol
    Re: Hondagade Build 2017/08/03 23:52:31 (permalink)
    Plates give you more room to weld to and looks a little better
    jakem31_
    Hondagade Build 2017/08/04 00:03:54 (permalink)
    okay thanks
    jakem31_
    Hondagade Build 2017/08/04 18:54:11 (permalink)
    [IMG]https://uploads.tapatalk-cdn.com/20170804/407e422f97f25be59f038796911be967.jpg[/IMG this what i got so far lol
    #19
    jakem31_
    Hondagade Build 2017/08/04 18:55:39 (permalink)
    #20
    Re: Hondagade Build 2017/08/04 20:18:13 (permalink)
    Whatcha waiting for? Get to welding!!!
    #21
    jakem31_
    Hondagade Build 2017/08/05 16:37:11 (permalink)
    alright ran to first problem ball joints what kind should i buy
    #22
    Re: Hondagade Build 2017/08/05 16:51:12 (permalink)
    Use ball joints for whatever hub's your using
    #23
    jakem31_
    Hondagade Build 2017/08/05 16:59:29 (permalink)
    ok
    #24
    jakem31_
    Hondagade Build 2017/08/06 01:24:07 (permalink)
    well im slow but i have finished one upper arm lol i need to go quicker
    #25
    Re: Hondagade Build 2017/08/06 09:22:02 (permalink)
    Ain't true if we don't see a picture!!!!!
    #26
    jakem31_
    Hondagade Build 2017/08/06 12:26:38 (permalink)
    ill take one when i go to the shop all it needs is shock mount
    #27
    jakem31_
    Hondagade Build 2017/08/06 13:14:01 (permalink)
    #28
    Re: Hondagade Build 2017/08/06 16:46:56 (permalink)
    Yea boy!!! Why u didn't use a pipe bender to arch your a arm?
    #29
    jakem31_
    Hondagade Build 2017/08/06 18:00:37 (permalink)
    i dont have one haha
    #30
