LockedHonda 300 Fourtrax vs Honda 350 Fourtrax/Foreman
MikeHawk69
2011/06/27 13:17:18 (permalink)
I'm new to the forums and I'm just wondering which would be a better machine.
Here is what I know:
300:
Ind. front suspension
282cc engine (20 HP ish)
solid rear axle
extremely reliable (from what I hear)
Rear diff problems (lets water in)
limited slip front diff
350:
solid front axle
very heavy
supposedly rides like a tank.
also supposedly very reliable
If anyone here has ridden/owns one or both, please let me know what you think. *I do NOT ride HARDCORE mud* I mostly ride woods/trails, snow, and I use my quads for work.
20 Replies Related Threads
    gordo
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/27 13:27:55 (permalink)
    if you're a trail rider you'll get tired of the solid front axle in about 20 minutes of riding,,,,
    '00 Fourtrax (Goober) Warn 424/ HL Disk Brake/Snork
    '97 Fourtrax (Prissy) Warn 424/ HL Disk Brake/Snork
    '96 Fourtrax (Cooter) HL Disk Brake/Warn 424 /Snork
    '94 Fourtrax (Ghost) HL Disk Brake/Warn 424 /Snork
    '94 Fourtrax (Maverick) HL Diskbrake/Snork/Warn 424
    '94 Fourtrax (Slider) Extreme Diskbrake/Warn 424/Snork
    '90 Fourtrax (Baby) Warn 424/Viper 2500 Winch/ HL Diskbrake
    hopeulikit mudder
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/27 13:32:51 (permalink)
    well both are really reliable, the 350 seem to be tougher and very seldon have problems with rearends, like the 300, both are really good bikes id just like the lil better, not much but lil' better, ride of the 300 they seem to ride a little smoother than the striat axel up front on the 350. the 300's do pretty dang good in the mud, and if stuck they are "for the most part light and easy to get out." bthe 300's have a lack of power when u get up to a taller tire, either would do good for you and last a while. imo these where 2 of the best atv's ever made..
    I may not have the biggest or baddest but, i wont stay on the hill!
    97 Green 300 Honda 4X4 "lil gator"
    350 Rancher shocks
    27"  mud hawgs
    FO-14 tractor pipe
    Highlifter disc brake kit
    Installed a fan
    EPI Clutch Kit
    2000 red 300 Honda 4x4
    cobra exhuast, 2" lift, 26" wide vamps, snorkle, jet kit
    green 300 4x4 in the makings!! "BIG GATOR"
    red 01 foreman 450 es w 27" exicutioners
    89 350 foreman stock
    Honda380
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/27 13:33:04 (permalink)
    im working on a 87 foreman 350 right now and its a good machine i got it for free so naturally a little tlc is needed but it had water in everything motor and both differentials and all the brakes but drained water out of motor and diffs and works just fine and motor doesnt smoke at all. but a buddy of mine had a 88 300 2wd and he swamped the thing drug it out finally got it cranked and it ran just fine i dont think he ever drained the water out that i know of but it was a good quad cause it went through alot. but as far as weight the foreman is a heavy quad compared to the 300 but the 350 will go almost anywhere you want to go
    JPs300
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/27 13:40:12 (permalink)
    300 = 17ish hp
    350 = 26ish hp
    Both are "tanks" as far as reliability goes, but neither is a performance bike or smooth trail machine. I'd give the edge to the 300 for general riding, while the edge goes to the 350 for brute power.
    "In2Deep - our drinking crew has a mudding problem"
    '11 Max Limited -
    JPs Customs 4" lift, rad relocate, snorks, & audio tubes, 29.5 law2s on Pilots
    '08 Teryx -
    new build coming...
    http://s455.photobucket.com/user/JPShawgo/library/riding%20pics
    wes ranch 4x4
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/27 14:47:58 (permalink)
    350 is stronger but rides rougher nad handles like crap id go for the 300 if i was you and stick with 25-26" tires.
    2009 Grizzly 700 Wild Boar relocated Rad, SYATV snorkles, HMF optimizer, Wiseco 11.5:1 piston, power tip, 1.5" wheel spacers, ss rims, 30x9 backs, Highlifter signature series lift, Superatv axles, ODI grips, strobe lights, and EPI clutch kit.
    MikeHawk69
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/27 19:25:53 (permalink)
    Hi everyone, thanks for the quick replies. JPs300, are you sure that the 350 puts out almost 10 more hp than the 300?  Also, it seems that the general opinion is to go with the 300? Does the axle on the 350 move "independently" (like on a truck) at all?  I have a 300 Suzuki QuadRunner 4x4, how would the two Hondas compare to that? Again, thanks.
    Honda380
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/27 21:30:51 (permalink)
    the axles dont seems to move like independent suspention cause there no wiggle room for the axle to move side to side they just move up and down. but the ride is stiff  and the steering is like a long wheel base truck  it takes a acre to turn it around or to turn it period
    helmut
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/27 21:37:00 (permalink)
    The 350 just has a straight front axle. It basically just has two swing arms, front and rear. Here is an illustration that shows the swing arms on the 350.
    HoNdaNaStYrAnCheR08
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/27 21:53:21 (permalink)
    my 300 is right at abt 24 25 hpish.....lots of heavy modds
    Black 07 brute Clutch full big gun Jet snorkled hids
    29.5laws msa nukes....
    GOLD 05 brute clutch hmf jet 14in mas nukes on 26in mtc motos full skids
    RED 06 brute 840bbk 31s ****zload done to it
    smokey199
    Mud Slinger
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/27 21:55:17 (permalink)
    ^ where did you get this diagram Helmut. I got a 87 350 for free (sucker) but there was quite a few things missing or takin off Im trying to see where the stock fuel tank mounted to so i can have a frame of reference for the one im making its in ruff shape but im sure i kind turn this lump of coal into a diamond eventually
    Can Am Commander 1000
    87 Honda 350 4x4
    97 Honda 300 4X4
    Honda380
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/27 22:02:24 (permalink)
    fuel tank mounts under the seat on offset to the right if your sittin on the quad
    helmut
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/27 22:12:24 (permalink)
    Here's a link to my service manual. Rather than posting a diagram, you can just download the whole service manual.
    http://www.mediafire.com/?k1ny84u2ogohjk0
    JPs300
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/28 13:53:16 (permalink)
    The swing arm suspension does not allow any independant motion. Both front tires move together, just as both rear tires move together.
    Yes, the 350 make close to 10 more hp, it's a pre-emissions 4-valve motor. The 88-91 300's are around 17-18hp, the 92+ are closer to 15-16hp, while the 350's were rated at 25-26.
    '11 Max Limited -
    '08 Teryx -
    new build coming...
    JTugwell
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/28 14:24:19 (permalink)
    the 350's a tank for sure.  id go with that one.
    -Justin
    2012 Polaris RZR S 800 LE
    Viper Elite 4500 Winch
    SSV Works Sound System
    2011 Polaris Sportsman 850 XP EPS:  SOLD
    2009 Honda Rancher 420 ES EPS: SOLD
    [color=
    Hghgrad
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/28 19:31:01 (permalink)
    I've often considered building a link setup for the front of my 350 to allow some flex up front. It's a very solid machine, but its a rough'ish ride and has a huge turning radius.
    MikeHawk69
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/28 21:07:55 (permalink)
    Thanks everyone. Are there any major problems that you can think of with the 350? Will the suspension and ride compare to a 1986 250 fourtrax? I have one of those and MAN does it ride rough. The front suspension is about 2 inches and does't really move independently, and the rear is so stiff that it barely moves at all!
            Anyways, I'm going on thursday to look at a near mint 1990 (Canada, exact same as 1986) 350 with BearClaws and a 4000lb warn winch. Buddy wants $2400
    I have never ridden either the 350 or the 300. Do you guys think I should hold out for a 300 instead?
    Honda380
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/28 21:34:57 (permalink)
    the rear shocks on a foreman are supposed to be adjustable but mine are rusted so they dont adjust but it rides ok nothing like a 06 350 rancher but its better than a solid mount system that the older yamaha 200s had. and i had to pull my 350 foreman to the shop and it was pulling the back of my rancher sideways so its really heavy so just be prepared
    BigCountry222
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/28 23:12:36 (permalink)
    i have both. a 94 honda 300 fourtrax 4x4, an a 87 honda 350 foreman/fourtrax 4x4. my 300 was stock except new 26 inch dirt devils, and my 350 was completely stock, we went riding 1 day an the 300 was getin stuck everywhere, the 350 was following huge bruit forces through the mud. bot are very strong and reliable, but the 300s weak point is its rearend, and ive just tore my 3rd rearend up in the 300. so they are both good bikes but the 350 ive never had problems out of it
    #19
    codymcdow
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/29 00:12:17 (permalink)
    more 300 parts out there if it was me id get a 93 or newer 300
    2013 ranger 500
    #20
    kikdrincon
    Re:Honda 300 Fourtrax vs Honda 350 Fourtrax/Foreman 2011/06/29 17:38:35 (permalink)
    Only issues we have had with our  '86 350 is the starter. They tend to go but the ebay replacement is $70 and works well.
    The fuel pump is also a weak link but again look on ebay they are around $120.(ours still going strong after 25 years) Both items are easily replaced with basic tools.
    The 350 is definitely a rough ride but can plow through most anything and is light enough to work it's way out of most situations with a push or lift. A winch is always beneficial.
    With the limited slip in the front, when in the mud just give the brake a light grab(continuously) and it will send power to that front wheel not moving and get them both turning. Just a handy hint if you haven't rode one before.
    09 Honda Rincon/GPScape Camo
    27X12/12 Maxxis Mudbugs
    Black ITP ss212's
    2.5" RDC lift
    1.5" stealth snorkel
    2500lb warn winch XT
    BRGR with Autoshift module
    2" tip
    #21
