LockedHonda 300 Fourtrax rear differential rebuild ONLY $125
sierra53
2010/05/19 19:52:13 (permalink)
If you need someone to rebuild it I rebuild them for $125 and I will supply the bearings and seals. I also DO NOT cut, grind, or modify the housing to remove the pinion bearing. I will use a puller and get it out the right way. This price is only if the gears and housing are good. You can either ship it to me, drop it off, or I can rebuild it while you wait. PM ME if interested
I rebuild Honda ATV front and rear differentials for only $125, Labor, Bearings, and seals Included in price.
5 Replies Related Threads
    sierra53
    Re:Honda 300 Fourtrax rear differential rebuild ONLY $125 2010/06/15 13:17:24 (permalink)
    BUMP
    Solitude
    Re:Honda 300 Fourtrax rear differential rebuild ONLY $125 2010/06/15 13:19:04 (permalink)
    The bearings and seals are only $55 bucks.
    Built RZR 800
    sierra53
    Re:Honda 300 Fourtrax rear differential rebuild ONLY $125 2010/06/15 14:21:33 (permalink)
    I get the ALL BALLS bearing kit shipped to my house for $70 and charge $55 for labor to tear down, clean out, put back together and test it. If you have ever tried to do it yourself it is well worth the $55. If you don't like my prices go to a cycle shop and pay $70/ hour.
    Solitude, as far as I am concerned you can keep your mouth shut because I am giving a good service for a very fair price!
    Solitude
    Re:Honda 300 Fourtrax rear differential rebuild ONLY $125 2010/06/15 14:58:48 (permalink)
    Ok but still you can not promote on here.. Ive done it plenty of times and wasnt to hard.
    Built RZR 800
    sierra53
    Re:Honda 300 Fourtrax rear differential rebuild ONLY $125 2010/06/20 21:38:12 (permalink)
    BUMP
