LockedHelp 05 Polaris Sportsman 700 efi twin
ellenson68
2009/08/15 15:24:52 (permalink)
My wheeler uses alot of antifreeze, but it  doesn't leak out anywhere and when i drive it for awhile or enough to get it warmed up it starts to knock by your feet and runs real ****.
2 Replies Related Threads
    bigbrute840
    Re:Help 05 Polaris Sportsman 700 efi twin 2009/08/15 16:49:34 (permalink)
    did u check and see if it was in your oil?
    2008 WHITE RZR
    SUPERATV CONVERSION W/ TURNER LIFT BRACKETS
    30'' SILVERBACKS ON MSA BLACK DIESELS
    LTE DUALS
    CUSTOM JAMS
    Dezz
    Re:Help 05 Polaris Sportsman 700 efi twin 2009/08/17 14:08:58 (permalink)
    MORE THEN LIKELY, the Cylinder Head gasket is gone.
    It could be leaking into the Oil passage jackets inside the cylinder/cylinder head, or it is leaking into the combustion chamber (on top of piston) and is being burned off.
    If you do the work yourself, make sure to get the cylinder head checked for warpage/cracks/etc....The best thing to do is to get  the cylinder head pressure tested. Any good engine shop or performance shop should be able to do this for you.
    If the head is warped/cracked/etc...then just replacing the gasket will do nothing. The problem will not be solved.
    Dezz
    2003 Yamaha Grizzly 660
    Dalton Clutch Kit
    2500 lbs. WARN
    High Strength Axles
    - SOLD - But not Forgotten
    1998 Grizzly 600
    ITP Delta Black Chrome Rims
    4 - Kodiak 450 Clutch weights
    Uni Air Filter
    Warn A2000 Winch
    Oxlite CV joint protectors
