Locked!!!!! HELP!!!!! RZR EXHAUST TURNING CHERRY RED
emc
2010/11/07 17:32:03 (permalink)
RZR IS COMPLETLEY STOCK. RUNS FINE. EXHAUST ONLY TURNS RED WHEN RIDING IT, DOES NOT DO IT WHILE IDLEING. DOESN'T SEEM TO BE RUNNING HOT & WATER SYSTEM IS CIRCULATING FINE. I PUT MY HAND IN FRONT OF THE MUFFLER & IT HAS PLENTY PRESSURE, SO IT DOESN'T SEEM TO BE STOPPED UP. ANY IDEAS?
T M H P
7 Replies Related Threads
    zillaman450
    Re:!!!!! HELP!!!!! RZR EXHAUST TURNING CHERRY RED 2010/11/07 22:28:58 (permalink)
    Thats normal
    Boudreaux Customz
    09 Camo RZR
    Oem s suspension
    Turner lift brackets
    Custom tunes & snorks
    Looney tuned duals
    PCV-Custom Map
    HIDs
    30’’mudlites on black ss108s
    emc
    Re:!!!!! HELP!!!!! RZR EXHAUST TURNING CHERRY RED 2010/11/08 00:07:25 (permalink)
    No, hasnt been doing it. Replaced the tranny & pulled the fuel tank & cleaned it out in the process. Now the exhaust is turning red. No snorkels, pipe or programmer on the bike.
    T M H P
    zillaman450
    Re:!!!!! HELP!!!!! RZR EXHAUST TURNING CHERRY RED 2010/11/08 00:17:53 (permalink)
    check the spark plugs
    Boudreaux Customz
    09 Camo RZR
    Oem s suspension
    Looney tuned duals
    PCV-Custom Map
    HIDs
    emc
    Re:!!!!! HELP!!!!! RZR EXHAUST TURNING CHERRY RED 2010/11/08 00:47:48 (permalink)
    To see if its running lean? I did put new plugs in it. A little hotter plug.
    T M H P
    zillaman450
    Re:!!!!! HELP!!!!! RZR EXHAUST TURNING CHERRY RED 2010/11/08 00:56:04 (permalink)
    yes, prolly the problem if u put a different plug in it than what is called for. What plugs did u use?  There is a tab on the frame where the serial # is and it also has the spark plug # also.
    Boudreaux Customz
    09 Camo RZR
    Oem s suspension
    Looney tuned duals
    PCV-Custom Map
    HIDs
    Boomer5
    Re:!!!!! HELP!!!!! RZR EXHAUST TURNING CHERRY RED 2010/11/08 09:39:13 (permalink)
    Check your fuel pressure too at the rail while you are at it. Should be 39PSI (+-3psi). I had a lean condition with the pipes glowing and it was reading 24PSI. I had to install a new feul pump.
    2010 Ranger Crew 800 - 2" Pro Lift, Gorilla Axles, Fox Shocks, 40" Rigid LED Bar, Rackzilla, 30" Radial Laws on ITP SS 312s, 4000lb Viper, Extreme Front Bumper
    LEPOPO
    Re:!!!!! HELP!!!!! RZR EXHAUST TURNING CHERRY RED 2010/11/09 09:11:02 (permalink)
    Mine has done it from day one. These engine run extremly high exhaust temps anyway. I wouldnt worry too much with it. And just because it glow doesnt always mean it lean. A rich engine will glow just as bright as a lean one. Let us know what you find if you find anything.. Good luck
    2011 Can Am Outlander XTP!!
    /// SNEAKY SNEAKY ///
