LockedGrizzly 660 oil
jonb
2009/05/31 00:44:25 (permalink)
Grizzly 660 oil
I am changing oil for the first time since I bought the grizz. I am looking at two different kinds of oil. The valvoline atv oil or the Rotella conventional oil, I think it's 15-40 weight. Which one would ya'll choose? If you would choose the valvoline, what weight. they have 10w40, or 20w50? Thanks!!!
'05 Grizzly 660. 27"Swamplites. EPI Clutch kit. K&N filter. Dynojet kit. Viper Max 3500lb winch.
http://s616.photobucket.com/albums/tt249/jonpbarn/
10 Replies Related Threads
    FlybyGrizzly09
    Re:Grizzly 660 oil 2009/05/31 01:23:37 (permalink)
    i would run the valvoline 10w40
    DixieMudderGrizz05
    Re:Grizzly 660 oil 2009/05/31 02:08:42 (permalink)
    youre changing your oil for the first time ....? your bike is an '05 model.....................
    [><]Dixie Mudders[><]
    2008 Can-Am Outlander 800
    1.5'' pipe lift on rear
    2" pipe lift on front with bracket lift
    Snorkeled
    Radiator Relocated
    HMF Penland Pro
    PCIII
    1.5" wheel spacers on the rear
    14" itp ss 212's machined
    30" Maxxis zillas
    Front and Rear Bumpers
    07' Yamaha Grizzly 700 Black / modded out  (SOLD)
    05' Yamaha Grizzly 660 Camo / modded out (SOLD)
    jonb
    Re:Grizzly 660 oil 2009/05/31 08:55:16 (permalink)
    First time since I've had it. The oil looks brand new but I just want to change it for my peice of mind. I think it has the castrol atv oil in it. Keep the input coming please.
    DixieMudderGrizz05
    Re:Grizzly 660 oil 2009/05/31 13:28:34 (permalink)
    oooh ok.. i was about to say. any oil that does not say ENERGY CONSERVING on the back of the bottle will be sufficient..
    Snorkeled
    Radiator Relocated
    HMF Penland Pro
    PCIII
    30" Maxxis zillas
    StrokerAce
    Re:Grizzly 660 oil 2009/05/31 20:44:37 (permalink)
    Valvoline ATV.  I just put this oil in my bike and I'm very happy with it so far and it's not as expensive as Yamalube.  Pick up an oil filter while you are at it.  I run the Purolator Pure One oil filter filter # PL14610 or the Bosch 3300 or 3323.  The 3323 and the Purolator are a tad longer than the stock Yamaha filters and if they will fit in your bike I would run them.
    offroadin89
    Re:Grizzly 660 oil 2009/05/31 20:58:52 (permalink)
    i run yamalube 10w-40
    07 Brute Force 750
    2in HL Lift - 29.5 Laws - MSA Reaper Rims - Gold Primary/Red Secondary - K&N Air Filer - Radiator Relocated - HMF Swamp Series
    Dezz
    Re:Grizzly 660 oil 2009/05/31 22:56:17 (permalink)
    It depends on the weather climate as to what weight of oil to run.
    But for summer weather, 20W50 is what you should run....and that is stated right in the owners manual.
    10W30 is used during the winter.
    Dezz
    2003 Yamaha Grizzly 660
    Dalton Clutch Kit
    2500 lbs. WARN
    High Strength Axles
    - SOLD - But not Forgotten
    1998 Grizzly 600
    ITP Delta Black Chrome Rims
    4 - Kodiak 450 Clutch weights
    Uni Air Filter
    Warn A2000 Winch
    Oxlite CV joint protectors
    StrokerAce
    Re:Grizzly 660 oil 2009/06/01 10:53:13 (permalink)
    Dezz
    Dezz
    In my owners manual, 10W30 is good from about 10 degrees to about 110 degrees and 20W40 is good from about 40 degrees to about 120 degrees.  So really unless you live in the desert, 10W30 or 10W40 will work just fine for all year round use.
    2002 grizzly
    Re:Grizzly 660 oil 2009/06/01 13:31:51 (permalink)
    is the oil supost to be wet cluch compatable?
    Mine, 2002 Grizzly 686, Wiseco high comp piston, Mudbuster Hot Cam, 28" mud bugs, fliped rear hubs, 2" front lift, 12" black ss212s coming soon.
    Uncle's, 2008 brute force 750i, 27" excutioners, 12" black ss212s, warn 2.5,
    Aunts's, 2004 Grizzly 660, 2" lift, 27" xtr's, 14" ITP ss112
    http://s734.photobucket.com/albums/ww350/02grizz/
    StrokerAce
    Re:Grizzly 660 oil 2009/06/01 13:40:12 (permalink)
    Just as long as it's not energy conserving oil, it should work.  I don't use an oil unless it states that it is for wet clutch operation like Yamalube, Valvoline ATV or Royal Purple Motorcycle.  Those are the only ones I have used so I know they are for wet clutch applications.
