LockedGrizzly 660 axle clips
Sailorman3
2007/12/22 19:14:25 (permalink)
I just replaced my rear axle clips with the "New and Improved" yamaha clips. My axle popped out again today. My question is do the clips look any different than the old one, because the new clips looked exactly the same. Did I get the wrong clips? Also can I use the Gorilla clips on a Yamaha axle or will I have to use the "O" ring fix. I am tired of fixing this problem. Thanks in advance.
Sailorman31999 Kodiak2004 Grizzly with-Kimpex rear TrunkFull Armordillo Skid Plate3000lb Warn WinchCustom Front and Rear Tow HooksHot GripsKimpex Front BumperKimpex Back BumperKimpex Gas Can CarrierFender Protectors/Foot
4 Replies Related Threads
    Boxslinger
    RE: Grizzly 660 axle clips 2007/12/22 19:27:10 (permalink)
    You should be able to use the gorilla clip on the factory axle. Back in the day you used the stock clip from a stock axle on the gorilla axle. Then if they still popped out you put the o'ring under the clip. Now they have the square clip. If you use the square clip and the axle does not want to pop in, take the clip off and close it up with plyers so it is not so loose on the axle. Then it should pop in. Remember don't close it up to much, if you do then you are defeating your purpose.
    '08 Outlander 800 XT, camo.
    CATVOS 6" lift
    30" Backs on SS312
    HMF Penland
    Brassart's custom snorkles
    cvtech clutch kit
    Ricochet skids
    Desert dog through shaft
    Brassart's custom radiator mount
    Highlifter Radiator on rack w/ temp. gauge
    '09 Special Edition Grizzly 700, 27" ITP 589 on SS112
    swerve
    RE: Grizzly 660 axle clips 2007/12/23 17:13:16 (permalink)
    The new clips should be different, they have a hooked end on the newer/updated ones. Check out www.grizzlyowners.com There is a big post in there about the problems a guy called Beast was having, it has pics as well as the part number. Good luck...........Irv
    Swerve, 05 Black Grizz S.E
    27" 589's On ITP type 4's
    Quadrax elite seat
    Hand and Thumb warmers
    2.5 Warn Winch
    Power tip
    Twin-Air Filter and Flange
    HL(EPI) Clutch kit
    Ontario site eh!
    www.mudhole.ca
    Another great site
    http://www.flickr.com/photos/24530195@N08/
    undisputedattitude
    RE: Grizzly 660 axle clips 2007/12/23 17:17:28 (permalink)
    Is your bike lifted at all?
    07 Grizzly700,Warn Winch,EHS PowerTip,Pod Mod,HID lights,shockwears,27"zillas on ss212s,full Ricochet skids.
    Sailorman3
    RE: Grizzly 660 axle clips 2007/12/23 17:41:44 (permalink)
    No not at all.
