LockedGotta replace my through shaft, any advice?
lugnut1009
2011/03/28 13:06:34 (permalink)
I broke my through shaft at Nat's and have a Gorilla through shaft in hand, I've also ordered all new bearings and seals for it. Anybody got any good advice for me before I start on it?
'07 Can-am Outlander 800 XT  SOLD
'07 Can-am Outlander 800 MAX XT  SOLD
'05 Bomb 400 MAX XT  SOLD
14 Replies Related Threads
    red river rider
    Re:Gotta replace my through shaft, any advice? 2011/03/28 15:46:58 (permalink)
    i broke mine and i pulled the clutches and inside of the clutch cover then pulled the exhaust off. after that i unbolted the trans from the motor and separated them an then pulled the front drive shaft and after that just turned the motor side ways in the bike and its easy from there . just pull the caps pull it out and put it back
    post edited by red river rider - 2011/03/28 15:48:57
    2006 arctic cat 400 m.... oil cooler racked, snorkled, 27 in laws, stock exhaust mod
    2009 can am outty 800.... 6 inch CATVOS, CATVOS lift springs, custom floorboards, 14in motosport alloy troopers wrapped in 32 monkey backs, dalton clutch kit, power comander, snorkled, hmf slip on, and full aluminum skids
    la77chevy
    Re:Gotta replace my through shaft, any advice? 2011/03/28 16:11:43 (permalink)
    You're gonna need a clutch puller, aside from that basic tools will suffice. The way I change em is to remove both fenders, drain fluid from motor and trans, loosen airbox from frame and from throttle body, remove exhaust, remove clutches and housing, remove driveshaft bolts, remove motor bolts (1 up front on the bottom, 2 on left side up top, 1 in the back on the trans), remove shift linkage from trans, unbolt 4x4 actuator, unplug wires from trans  ( they're color coded), remove the 3 bolts holding the motor and trans together,wiggle motor forward and backward to get the drive shafts loose then slide the motor forward enough to get the trans loose. Once the trans is off and out of the way there's a cap around the shaft that holds the bearing and seal that will need to be removed. Remove the front cap also and the shafts will come right out. Be easy with the caps, they're kinda brittle. When reinstalling the caps use some high temp silicone or they will leak. The seals have different ID's so be sure and remember that the seal with the bigger ID goes on the back of the motor. Really not a hard job, usually takes me about 2 hours. Use either the Can am trans fluid or chain case oil, don't use gear oil. I think that covers it all
    post edited by la77chevy - 2011/03/28 16:13:41
    lugnut1009
    Re:Gotta replace my through shaft, any advice? 2011/03/28 19:09:51 (permalink)
    Thanks guys! And I have a clutch puller. Doesn't sound too bad
    bar5721
    Re:Gotta replace my through shaft, any advice? 2011/04/01 07:44:26 (permalink)
    Hey I have changed 3 of them and not far from u like right down the road if u have any problems give me a holla
    2013 Polaris Ranger 900.
    Outkast 3 inch full kit.
    31 inch outlaws skinny all around. Rear outlaw dht axles.
    Super ATV front Bumper.
    Triangle ATV Snorkel Kit.
    5000 pound promark synthetic.
    12inch double row combo light bar.
    some otrattw switches.
    ftd cabs exhaust sheild.
    More coming.
    SOLD. 07 Can am 800 outlander...yellow
    DIED after given to Father.  04 Honda foreman 450
    lugnut1009
    Re:Gotta replace my through shaft, any advice? 2011/04/01 08:17:55 (permalink)
    Really? Where are you located?
    bar5721
    Re:Gotta replace my through shaft, any advice? 2011/04/01 11:56:49 (permalink)
    Just down the road from u culkin rd area when u going to change ur shaft I actually have two shafts at the house not any gorilla ones though
    More coming.
    lugnut1009
    Re:Gotta replace my through shaft, any advice? 2011/04/01 13:14:47 (permalink)
    I went to Mud Nat's this past weekend, which is where it broke, and I picked up a Gorilla through shaft while I was there.  I'm thinking about starting on it tomorrow.  But, I've got a soccer game I've gotta go to and some other stuff, so I may not get too in depth with it until next week sometime.  It will be ready by April 9th though!  We're planning on a bunch of us going to Copiah Creek!
    joshua99ta
    Re:Gotta replace my through shaft, any advice? 2011/04/01 14:09:43 (permalink)
    ^^ I'll see ya there!!! lol
    Team Outta Kontrol
    09 Renegade X
    FCP, ///Airdam and some Wild Boar love
    08 Rzr-beer mobile
    DWH 11 LOST BUT NEVER FORGOTTEN
    bar5721
    Re:Gotta replace my through shaft, any advice? 2011/04/01 14:43:49 (permalink)
    I broke my prop back u joints and yoke on mine at red creek and just haven't had the money to buy another prop shaft assembly yet bc I just bought a house and having to throw all my time and money on it right now
    More coming.
    lugnut1009
    Re:Gotta replace my through shaft, any advice? 2011/04/01 15:25:45 (permalink)
    It won't be long and I'll be in the same boat!!!  I probably ought to go on and trade my 31's for something less aggressive so I won't have to take a chance of tearing up something when that time comes......
    joshua99ta
    Re:Gotta replace my through shaft, any advice? 2011/04/02 17:14:10 (permalink)
    ^^ ya just gotta watch that throttle man!!!!
    Team Outta Kontrol
    09 Renegade X
    08 Rzr-beer mobile
    lugnut1009
    Re:Gotta replace my through shaft, any advice? 2011/04/02 17:15:06 (permalink)
    I'm gonna try my best!  I just can't let go of them dirty ones!!!
    parkerparkerm
    Re:Gotta replace my through shaft, any advice? 2011/04/02 17:37:39 (permalink)
    dude, its a v-twin, why let off and hear teh clutch whine about how much better the exhaust sounds? plus throttle = fun, thats why im only going with 27" outlaws, little bit harder to break axles on them smaller, lighter tires
    2010 Can-am Outty 650XT  -Snorkles, 29.5" Outlaw, 15" Glasspack, Radiator on the racks
    1985 F250 4x4 300/T18
    1977 f250 4x4 parting out now.
    lugnut1009
    Re:Gotta replace my through shaft, any advice? 2011/04/02 17:43:49 (permalink)
    If money wasn't a factor, I'd have a 4" lift and skinny 29.5's!!! Plus, since I added the blue EPI secondary spring, my belt don't whine much at all anymore!
