Hot!Foreman 450 IRS
Page: 123 > Showing page 1 of 3
toms99tj
Mud Slinger
2018/04/17 16:20:18 (permalink)
Foreman 450 IRS
I finally got the rear out of my foreman and found that the rincon drive shaft fits on the shaft coming out the motor. I take it sense the shaft fits i dont need to cut and weld shafts now?
post edited by toms99tj - 2018/04/18 08:08:12
Attached Image(s)
1998 Foreman 450
30 inch Zillas on MSA M12
2 inch Highlifter Lift
Highlifter springs
Highlifter disc brakes
14% Gear Reduction
Snorkle
Stereo
__________________________
2000 Foreman 400
30" Zillas on 14" MSA Elixers
Viper 3000lb winch
DG muffler
Highlifter Disc Brakes
14% Gear Reduction
450 rear shocks with spacer lift
Foreman 400 rear adjustable shocks and 450 a arms
Warn 424
Home made snorkel
6" Audio Tube
ES Floorboards
71 Replies Related Threads
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/18 08:25:20 (permalink)
    second picture
    Attached Image(s)
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    Re: Foreman 450 IRS 2018/04/19 07:23:04 (permalink)
    I think your still gonna have to cut it to make it long enough to fit from motor to diff once everything is fabed. Also give yourself a nice soft angle. Nothing sharp or it's not gonna turn smooth cause it will feel like it's in a bind.
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/19 07:30:21 (permalink)
    The rincon shaft is a little longer than the foreman shaft. Right now i have it almost straight across. So i should tilt it down a hair?
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    Re: Foreman 450 IRS 2018/04/19 07:42:53 (permalink)
    Is your diff centered to the frame?
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/19 07:49:12 (permalink)
    Everything is centered i measured from multiple spots. I still have to weld the tabs on for the other 2 bolts for the subframe so i can adjust up and down.
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    Re: Foreman 450 IRS 2018/04/19 07:54:14 (permalink)
    So the diff input isn't offset compared to the transmission output.
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/19 07:56:21 (permalink)
    It is only cause the rincon rear diff has a slight bend to it. I will see if i cant attach a picture.
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/19 08:06:39 (permalink)
    Here is what I am talking about
    Attached Image(s)
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    Re: Foreman 450 IRS 2018/04/19 08:15:27 (permalink)
    Yes correct, so the shaft has an angle going across to make the connection. Just make sure you have good length so the u joint doesn't feel stiff.
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/19 08:17:46 (permalink)
    I put it in four wheel drive and spun the front wheel and the rear spun smooth. Right now i have the subframe level with the foreman frame. Should i keep that or tilt the subframe down?
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    Re: Foreman 450 IRS 2018/04/19 08:22:17 (permalink)
    Keep it level
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/19 08:26:05 (permalink)
    Ok. Thank you for the help. My next thing tonfigure out isnthe upper shock mount and how to get it level with the front.
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    Re: Foreman 450 IRS 2018/04/19 10:01:34 (permalink)
    Man you can make it anyway you want.
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/19 10:06:40 (permalink)
    I was meaning getting the thing to sit level without having tonredo it 35 million times. Lol
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/24 18:02:51 (permalink)
    Now im up to figuring out the upper rear shock mount. My question is should the back sit a little higher than the front?
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    Re: Foreman 450 IRS 2018/04/25 14:13:04 (permalink)
    I'd say a little higher to account for riders weight
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/25 14:18:55 (permalink)
    Thats what i was thinking. Thanks again
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    Re: Foreman 450 IRS 2018/04/25 14:25:16 (permalink)
    No problem, post some good pics when u get it all done!!!
    #19
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/25 14:28:01 (permalink)
    I have a couple of stuff done as i been working. I just have to shrink them down to post them but i will for sure post pics.
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    #20
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/25 16:14:24 (permalink)
    I think my axle angle might be much? The four wheeler sits almost level. Its a little higher in the back
    Attached Image(s)
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    #21
    Re: Foreman 450 IRS 2018/04/25 21:28:21 (permalink)
    Looks good. 37-38 degree is where you should be around.
    #22
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/26 05:58:05 (permalink)
    Ok thanks. I will check the angle after work for the **** of it. This really isnt that hard of a project if you know how to weld. I dont know how to but my friend does and luckly he keeps his welder here. Lol
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    #23
    Re: Foreman 450 IRS 2018/04/26 06:35:35 (permalink)
    Hey as long as your happy with the outcome is all that matters.
    #24
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/26 06:38:26 (permalink)
    I just dont wanna snap axles left and right. Thats what im concerned about.
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    #25
    Re: Foreman 450 IRS 2018/04/26 06:46:05 (permalink)
    What kind of axles do you have?
    #26
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/26 06:49:27 (permalink)
    I got these ones from sixity.
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    #27
    Re: Foreman 450 IRS 2018/04/26 06:52:23 (permalink)
    I have run those but on a stock application. My gorillas I run at a 38-39 degree angle and had to do a break in procedure. So I'm not sure how the sixity ones will do but for stock they we're fine.
    #28
    toms99tj
    Mud Slinger
    Re: Foreman 450 IRS 2018/04/26 06:56:43 (permalink)
    This is all trial and error. I guess i will see when its all welded together how it rolls. It should be only a 2 inch lift cause thats all the front is.
    1998 Foreman 450
    Highlifter springs
    14% Gear Reduction
    Snorkle
    Stereo
    2000 Foreman 400
    Viper 3000lb winch
    DG muffler
    14% Gear Reduction
    Warn 424
    Home made snorkel
    6" Audio Tube
    ES Floorboards
    #29
    Re: Foreman 450 IRS 2018/04/26 07:12:41 (permalink)
    Then you should be fine. I'm running a 6" on my 300's and they fit in the back of a truck so the angle has to be steep in order to do that. Haven't had a problem except for a torn boot. So if your angle isn't to bad I think you will be fine.
    #30
