Hot!Foreman 450 Carburetor Repair (Thanks Ethanol !)
YellowDog02
2018/02/17 09:15:00 (permalink)
Hey Guys,
I'm sure a lot of y'all have experienced this in the past, but for those a little unsure of tearing into your carb..
Here a little video of what it takes to get one cleared out and back to normal.
 http://youtu.be/1z4Bdd2uyZA
post edited by YellowDog02 - 2018/02/17 09:28:55
2008 Honda Rincon
Outlaw MST's 28-9.5-12's Front 28-12-12's Rear
Tusk 30mm Rear wheel Spacers
 2500 lbs Super Wench
BIG RED GEAR REDUCTION + Auto Shift Correction Module
__________________________
2009 Honda Rancher FM 4x4
Maxxis  Zillas 28-10-12's Front 28-12-12's Rear
12in STI XB40 Wheels
4 Replies Related Threads
    Re: Foreman 450 Carburetor Repair (Thanks Ethanol !) 2018/02/17 09:46:43 (permalink)
    Don't use ethanol or at the least run seafoam in the gas if using ethanol!!!
    YellowDog02
    Re: Foreman 450 Carburetor Repair (Thanks Ethanol !) 2018/02/17 12:24:20 (permalink)
    Well, there are a few stations around here that sell 100% gas, non-ethanol blend. Best route in my opinion, however I am a little suspect of some of the stations claiming it, and not truly selling it..
    2008 Honda Rincon
    Re: Foreman 450 Carburetor Repair (Thanks Ethanol !) 2018/02/17 16:39:53 (permalink)
    I hear you brother. You can always tell the ones running ethanol too, cause water always pouring out the tail pipe!!!
    YellowDog02
    Re: Foreman 450 Carburetor Repair (Thanks Ethanol !) 2018/02/18 20:41:34 (permalink)
    Speaking of water,,, After we got the Carb back on the 450, it did give us some grief starting...so we check the gas.. Guess what was in it... WATER... Go figure?
    2008 Honda Rincon
