LockedEPI Heavy Duty Ball Joint Failure - both uppers on the first ride!
hbchad
2011/02/26 15:22:26 (permalink)
I shelled out the $ for some EPI heavy duty rzr ball joints...one ride, 6 hours later, this is what I had...
I'll be contacting EPI on Monday for a refund on the parts and I am going to ask them to cover the installation labor for replacing them - I'm leaving town for work this monday and won't be home until the day before Nats...no way i'm gonna have time to put the new ones in myself.
This is a big time safety issue and they need to do a recall...
2012 rzr-s
31" outlaws
bunch of other stuff...
2012 Ranger Crew
6" Outkast
34" Terms
even more other stuff...
Going deep on TheNattyBoys youtube channel
13 Replies Related Threads
    Brady84
    Re:EPI Heavy Duty Ball Joint Failure - both uppers on the first ride! 2011/02/26 17:36:47 (permalink)
    wow! keep us posted on their response.  They definitely wear out but never seen anything like that!  I'm still running stock with one SuperATV (which the rubber boot fell off of before getting it installed)
    birdmanf250
    Re:EPI Heavy Duty Ball Joint Failure - both uppers on the first ride! 2011/02/27 10:49:44 (permalink)
    Dang. I shelled out the $ for all four epi hd. No problem but I hope I just didn't jinx myself. Most def update!
    Ghost RZR
    FTM 6" Arched Lift
    Gorilla Axles
    Speed Werx/Hot Seat Performance Custom Clutching
    UTV Inc. Intake/Donaldson Filtration
    Burke Moto Pro HID's
    Wet Sounds w/J Strong Top
    hbchad
    Re:EPI Heavy Duty Ball Joint Failure - both uppers on the first ride! 2011/02/27 11:18:52 (permalink)
    I'll keep yall posted...they had a 30 day warranty which expired Feb 23...Hopefully they will goodwill them.  All my dealings with EPI so far have been great so I expect this to be the same...
    we'll see...
    2012 rzr-s
    31" outlaws
    2012 Ranger Crew
    6" Outkast
    34" Terms
    Kaw Kaw 650
    Re:EPI Heavy Duty Ball Joint Failure - both uppers on the first ride! 2011/02/27 13:59:36 (permalink)
    yep i have superatv's upper and lower and the boots came off before i got them installed. They told me they are Polaris part but you can clearly tell they arent.
    Polaris RZR 800
    11 Outlander 800R XT Camo
    Dozer600
    Re:EPI Heavy Duty Ball Joint Failure - both uppers on the first ride! 2011/02/27 19:22:58 (permalink)
    Had a buddy shear an aftermarket one off after riding a small water wheelie on his 700.  I know they arent made for an 800lb machine with huge tires in mind, but the things were brand new and werent 30 minutes into a ride.  Ive just used OEM every since and replace them every 6 months or so regardless as added insurance.
    Outlander 1000 - S3, Gorilla, QSC, STM, RDC, LTE
    RZR 600 - Outkast, SuperATV, EMP, SideByInnovations, UTVinc, Big Gun, Alba, Highlifter, Gorilla, Dobeck
    Stealth 800 - Parting Out
    Big Bear 400 - Ressurection Almost Complete
    Honda 300 - Project
    '10 F-350 - Spartan, AFE, Flo-Pro, MBRP, DE
    Boomer5
    Re:EPI Heavy Duty Ball Joint Failure - both uppers on the first ride! 2011/02/28 15:17:57 (permalink)
    I drilled and tapped my stockers for Zerks and never have had an issue. Been running 6" CATVOS for 2 years and still on original set.
    2010 Ranger Crew 800 - 2" Pro Lift, Gorilla Axles, Fox Shocks, 40" Rigid LED Bar, Rackzilla, 30" Radial Laws on ITP SS 312s, 4000lb Viper, Extreme Front Bumper
    birdmanf250
    Re:EPI Heavy Duty Ball Joint Failure - both uppers on the first ride! 2011/02/28 16:30:04 (permalink)
    How in the heck you'd do that?
    Ghost RZR
    FTM 6" Arched Lift
    Gorilla Axles
    Boomer5
    Re:EPI Heavy Duty Ball Joint Failure - both uppers on the first ride! 2011/02/28 18:59:44 (permalink)
    Real easy. I just drilled the center while using compressed air to keep shards out of joint. Then tapped threads and installed zerks I got from autozone. I then put rubber caps on them to keep mud out. I did this at the first hint that the ball joints were feeling worn. Pumped the grease and then they instantly firmed up.
    I know that y'all are worried about ripping the zerk out of the joint if something hits it, but I have never had the issue.
    birdmanf250
    Re:EPI Heavy Duty Ball Joint Failure - both uppers on the first ride! 2011/02/28 19:07:43 (permalink)
    Thanks. U drill and tap the big part of the joint?
    Ghost RZR
    FTM 6" Arched Lift
    Gorilla Axles
    Boomer5
    Re:EPI Heavy Duty Ball Joint Failure - both uppers on the first ride! 2011/02/28 19:20:32 (permalink)
    yep, directly in the center on the flat part of the joint, but make sure the rubber boots don't have any tears, rips, etc or it's useless to do.
    birdmanf250
    Re:EPI Heavy Duty Ball Joint Failure - both uppers on the first ride! 2011/02/28 19:50:48 (permalink)
    Thanks.
    Off the topic... What angle are your rear axles at? I recently took out my rear spring spacers and now I'm at 26 degrees (was 34) and at 18 1/4" clearance at rear.
    I'm just curious as to what others are set up with a big lift?
    And do u have stock springs or any spring spacers?
    Thanks
    Ghost RZR
    FTM 6" Arched Lift
    Gorilla Axles
    hbchad
    Re:EPI Heavy Duty Ball Joint Failure - both uppers on the first ride! 2011/03/01 10:57:21 (permalink)
    Hey guys, an update:
    The guys at EPI were great!  They made it right for me.
    They're about to start a new production run and are going to have the engineers look at things to determine why mine failed and make sure that the new batch is perfect.
    2012 rzr-s
    31" outlaws
    2012 Ranger Crew
    6" Outkast
    34" Terms
    birdmanf250
    Re:EPI Heavy Duty Ball Joint Failure - both uppers on the first ride! 2011/03/01 11:17:58 (permalink)
    Good news.
    Ghost RZR
    FTM 6" Arched Lift
    Gorilla Axles
    © 2022 APG vNext Commercial Version 5.5
