Hot!Dual battery setup
doveman1
2020/05/12 08:01:35 (permalink)
Dual battery setup
Looking at doing a dual battery setup on my grizzly.
Thinking of using this isolator between the 2 batteries. The first battery would be for solely cranking and the 2nd would run to an aftermarket fuse panel to run all accessories.
https://www.d****a.info/product/true-utv-sbi-18/
If I’m reading this right, the bike should always charge cranking battery first then switch over to secondary right.
Any input on this?
Also what are some good batteries to buy these days?
Green 2015 Grizzly 700
2in HL lift
N2deep battery relocation
Wild boar radiator relocation
2 Replies Related Threads
    Re: Dual battery setup 2020/05/15 18:42:27 (permalink)
    Doveman your link didn't work. Anyway I like to run Motocross batteries. It's a Yuasa made battery. The haven't failed me yet and usually run half the price. Find them at your discount battery places usually.
    Foreman4504x4
    Re: Dual battery setup 2020/10/07 02:06:48 (permalink)
    I've had good luck with Deka AGM batteries.
    04.5 Polaris Sportsman 500 HO. 4x4
    27" Kenda Bearclaw HTRs, 2" HL Lift, Turner Cycles Axles, Polaris Front & Rear Bumpers, Dirtbmw20's Radiator Relocation Bracket, K&N Air Filter w/Pre-Filter, and a Warn Winch.
