LockedCV Boot Band???
stevesgrizzly
2009/12/20 19:46:07 (permalink)
CV Boot Band???
I ordered new CV boots from ATVCVBOOTS, they came with new bands and I have no idea how to put these on and secure them. Can someone help me?
Thank you!
Steve
22 Replies Related Threads
    chrisb76
    Re:CV Boot Band??? 2009/12/20 20:01:58 (permalink)
    best way is with a band clamp tool,but a pair of needle nose pliers will do the trick if you know how to do it.put them around through the end with it on the boot then catch the end close to the boot,and turn it counter clock wise if you go the way you'd think they go it will not work go counter.then once its tight bend it back over,and tap the tabs down over the clamp.
    old school kodiak
    6''lift,brute diffs.,gorilla's
    big ol' piston
    lots of balls
    TEAM ALL JACKED UP
    stevesgrizzly
    Re:CV Boot Band??? 2009/12/20 20:08:31 (permalink)
    Still confused...
    chrisb76
    Re:CV Boot Band??? 2009/12/20 20:40:13 (permalink)
    yep i figured that would happen i can't explain it,but i bet if you look on youtube search installing cv boot bands it'll have a video.
    old school kodiak
    big ol' piston
    lots of balls
    TEAM ALL JACKED UP
    coonrat
    Re:CV Boot Band??? 2009/12/20 20:55:51 (permalink)
    go cheap and use big **** tie straps if u cant figure it out but i get em with pliers and a screwdriver
    2004 big bear custom
    28x10x12 front 28x12.5x12 rear outlaws ss rims
    2 inch lift
    full sound system
    skidplates
    toolbox on back
     modified warn rt2500 winch
    custom
    fully snorkeled
    homemade wannabe hmf exaust sounds awsome
    almost every part customized to work better
    """specilize in big bear modifications"""
    R.I.P. CC LYNN never forget 9-17-09
    stevesgrizzly
    Re:CV Boot Band??? 2009/12/21 18:16:35 (permalink)
    Nothing on you tube, anyone else???
    Cat2003
    Re:CV Boot Band??? 2009/12/21 18:18:21 (permalink)
    I use industrial tie wraps with metal clips.
    garagerat
    Re:CV Boot Band??? 2009/12/21 18:37:38 (permalink)
    Go to a parts house and order the CV band tool. Trust me it will make your life a lot easier. Tool is pretty self explanatory. The latest ones have a cutter built in so you don,t have to mess with trying to cut the band after you have it installed(common cause of nicked boots. The needle nose method will work, it will also expand your vocabulary considerably, and probably cost you a band or two, or a boot until you get the hang of it. Think I gave around 15 bucks for my tool. Just my opinion, hope it helps
              X treme  Missouri boyz
    Finding the holes and rooting them OUT
    If it ain't broke, you ain't tryin' hard enough!!!
    Afoot for the time bein!!!
    BigBadGrizz
    Re:CV Boot Band??? 2009/12/21 19:34:25 (permalink)
    Can you post pictures of the bands? The reason I ask is because the bands on my superatv axles can be removed or installed with needle nose pliers very easily. Theirs a spot where you squeeze the bands and then they just hook together after you have enough pressure on them.
    07 grizzly 700
    06 Rhino 660
    04 CRF 450R
    DixieMudderGrizz05
    Re:CV Boot Band??? 2009/12/21 23:12:26 (permalink)
    BigBadGrizz
    now i'm interested.... i wanna see a picture of YOUR clamps lol.
    here is the average cv boot clamp.
    Attached Image(s)
    [><]Dixie Mudders[><]
    2008 Can-Am Outlander 800
    1.5'' pipe lift on rear
    2" pipe lift on front with bracket lift
    Snorkeled
    Radiator Relocated
    HMF Penland Pro
    PCIII
    1.5" wheel spacers on the rear
    14" itp ss 212's machined
    30" Maxxis zillas
    Front and Rear Bumpers
    07' Yamaha Grizzly 700 Black / modded out  (SOLD)
    05' Yamaha Grizzly 660 Camo / modded out (SOLD)
    stevesgrizzly
    Re:CV Boot Band??? 2009/12/22 04:53:34 (permalink)
    Okay, thats the band I have! Now whats the next move?
    Thanks again!
    jrod_379
    Re:CV Boot Band??? 2009/12/22 09:17:30 (permalink)
    hose clamps will make your life easier lol
    2007 bb400
    black plastics
    29.5 outlaws
    2" hl lift kit
    k&n air filter
    dyno jet kit
    hmf exhaust
    competition clutch kit
    web cam
    custom snorkle
    gorilla axle
    C1iffBurton
    Re:CV Boot Band??? 2009/12/22 09:53:51 (permalink)
    ive used zipties,  and i actually still do have 2 zipties holding one of my boots on and no problems at all...the yamaha bands are easy to use, i didnt use them the first time cuz i didnt know how to get them to work and i forgot to put the small one on before i assembles the joint so it wouldnt work after that lol so used zipties cuz i needed the bike ready for the next day for a marengo ride
    anyhow here is a video of how to use the band tool
    http://www.youtube.com/watch?v=OQUTbcv6dqU
    also if you go on the gorrila axle site i think they have a video somewheres of how to do it also
      R.I.P. JAYSON MATTHEW PARKER
    doveman1
    Re:CV Boot Band??? 2009/12/22 14:26:57 (permalink)
    jrod_379
    EXACTLY!!
    Green 2015 Grizzly 700
    MuddyBuddy
    Re:CV Boot Band??? 2009/12/22 16:42:23 (permalink)
    The hose clamps are alotttt easier to remove in my opinion and are better for repeated use.
    2011 Can Am Commander 1000
    AIRDAM/// clutch
    VDP Stereo
    28' Radial Laws
    MSA Beadlocks
    Aftermarket tie rods
    Pro Armor Doors
    Its only the beginning.....
    Cat2003
    Re:CV Boot Band??? 2009/12/22 18:05:49 (permalink)
    Hose clames are ok for car boots but i find there alittle to wide for the grove.
    just need one large tie wrap with the little clip that holds pressure to be metal.
    cops use them when there big fights and stuff and not enough hand cuffs.
    stevesgrizzly
    Re:CV Boot Band??? 2009/12/22 18:48:11 (permalink)
    Think I've got it now, I need a band tool. Heres my next problem... I purchased a rebuild kit for my cv joint and the cage will not fit into the joint housing! This ever happen to anyone else, if so what did you do?
    doober
    Re:CV Boot Band??? 2009/12/23 17:03:01 (permalink)
    I used a hose clamp once and wont do it again, they pick up weeds and crap from mud holes, and cause a huge mess when all that crap gets twisted arround the axle. I always just use plyers and a screwdriver, works pretty good.
    DixieMudderGrizz05
    Re:CV Boot Band??? 2009/12/23 17:22:58 (permalink)
    you need to turn the cage completely perpendicular to the cup  (sticking it in sideways) and the windows on each side of the cage need to be lined up with a raised part of the cup  (not the groove where the bearing rides)  if that makes any sense.....
    if you have it lined up like that it will drop right in, then you spin it whichever way is is supposed to go.
    Snorkeled
    Radiator Relocated
    HMF Penland Pro
    PCIII
    30" Maxxis zillas
    #19
    Muddin_dude05
    Re:CV Boot Band??? 2009/12/23 19:24:23 (permalink)
    i either use hose clamps or preferably an automotive CV band, the style that you crimp on. I use horse hoof clippers to crimp them tighter than you can get any zip tie !
    '07 Green Grizzly 700EFI
    Snorkeled
    Clutched Greaseless
    Glasspack'd
    All Gorilla'd
    BA Tie rods
    Sittin' on 31" Outlaws
    Split-Tube tunes
    #20
    Swamp Star
    Re:CV Boot Band??? 2009/12/23 19:25:42 (permalink)
    go to Go-rilla's website and they have vids on installing boot clamps.
    SWAMP STARZ
    2010 White 800XP Ranger
    2-3" SATV/ +2 SATV arms
    29.5 Laws/ SATV bumper
    1/2 windsheild/ spacers
    LOUD radio/ bikini top
    Team That Guy
    #21
    chrisb76
    Re:CV Boot Band??? 2009/12/23 20:04:20 (permalink)
    yeah you gotta turn the cage sideways,and pretty much force it in then you put the star in,and then you put each ball bearing in 1 at a time.then grease it,and shove the axle shaft in with the boot on first.
    old school kodiak
    big ol' piston
    lots of balls
    TEAM ALL JACKED UP
    #22
    coonrat
    Re:CV Boot Band??? 2009/12/24 02:05:12 (permalink)
    remember to put the boot on before you put the axle in lol may have made that mistake once before lol
    2 inch lift
    full sound system
    skidplates
    toolbox on back
    custom
    fully snorkeled
    #23
