LockedBrute force?
Page: < 12 Showing page 2 of 2
muddy450es
Re:Brute force? 2013/02/21 21:19:51 (permalink)
and the water wheelies are what worry me
1987 Suzuki samurai
Lifted 9"
33" Boggers
Stage 2 clutch
HID's
Custom side pipe
#31
r350mudder
Re:Brute force? 2013/02/21 21:55:59 (permalink)
Ok correct me if I'm wrong but the crankshaft in a vtwin runs perpendicular to the frame. Which means there wouldn't be "front" rod bearing. They are side by side, but yes one goes for the front cylinder and one for the rear cylinder. So if you could starve your front cylinder, but it would cause front cylinder damage and scarring... but doesn't it have an oil circulation system of some sort to prevent that?? And to take a rod bearing the oil has to be either really hot, or of course not enough of it. So i don't really see how wheelies will take out rod bearings unless your really low on oil. I've never had a problem in 2700 miles with wheelies on my brute.. i always did run it close to full so i didn't have to worry about running it low. Brutes are definitely awesome for the price and accepts one of the widest ranges of accessories and aftermarket parts.
2012 shocker yellow Can Am Outlander 800r
28" Outlaw² on HD3's
Can Am handguards
SYATV Snorkels
XT Bumper
LTE s/o
Tunes
Halos
UNI
#32
KC
Re:Brute force? 2013/02/22 06:16:28 (permalink)
Have you ever been inside the engine on a Brute? I have. The way the bottom end is design when the bike is sitting flat level on the ground the rear half of the bottom end already holds a lot more oil than the front half of the bottom end. So imagine what happens when you ride wheelie and pick that front end up?
2014 Can-am Commander 800R
- 32" Terminators
- 14" MSA M20 Kores
- 2" Highlifter Sig. Series lift
- 2" Spring spacers
- 2" Stretch
- S3 Titan HD axles (rear)
- EMP Metal Roof
- HMF Swamp Series XL
- 2-6.5" and 2-8" MCM Waketower Speakers
- JBL 600watt Marine Amp
Sold
99 Honda 300
02 Foreman 450
06 BruteForce 750
07 Renegade 800
09 Outlander 800R
#33
KC
Re:Brute force? 2013/02/22 06:19:26 (permalink)
Like I said before I'm not trying to knock a Brute, they're definitely a good bang for their buck. Just stating facts. If your buying used tho no matter what bike you get check it out very careful from top to bottom, front to back and run a fine tooth comb through. Make sure your not getting someone else's headache..
- 32" Terminators
- 14" MSA M20 Kores
- 2" Spring spacers
- 2" Stretch
- EMP Metal Roof
Sold
99 Honda 300
02 Foreman 450
06 BruteForce 750
07 Renegade 800
09 Outlander 800R
#34
840 Brute
Mud Slinger
Re:Brute force? 2013/02/22 06:38:07 (permalink)
you can run the catch can and the drain to the front valve cover and that will help with any no oil issue when riding on the rear tires,I have never had crank issues on a stock brute or stoke bore built brute,I know alot have but I dont know what other do with there bikes.
05 Brute 650 SRA F/S/T 840
Slammed/Stretched/Fast!!!
2012 Brute Force 750
all stock trail bike!!!
#35
ford97
Re:Brute force? 2013/02/22 10:40:03 (permalink)
you can buy a nice used grizzly 700 or 550 for 5500. just saying.
2014 rzr 570
-5in outkast
-32 terms
-snorkel
06 big bear 400-SOLD
2011 grizzly 700-SOLD
2011 big bear 400-SOLD
2010 rancher 420-SOLD
99 big bear 350-SOLD
#36
Sherman10
Re:Brute force? 2013/02/22 11:33:59 (permalink)
I have a 09 650 4x4i for sale it has everything on it 5000 Obo
#37
muddy450es
Re:Brute force? 2013/02/23 22:39:09 (permalink)
Where are you located^^^^?
1987 Suzuki samurai
Lifted 9"
33" Boggers
Stage 2 clutch
HID's
Custom side pipe
#38
mud PRO 700
Re:Brute force? 2013/02/23 23:00:25 (permalink)
I'd so recommend the efi brutes over the carbureted ones. There really is no comparison between the two. Get one with low miles and is stock. That's what I'd look for.
2009 Can-am outlander XT
#39
KC
Re:Brute force? 2013/02/24 07:40:01 (permalink)
Look for low miles and low hours, make sure its clean, check the engine oil, check diff oils as well and I would recommend also checking in the airbox just to see if it ever had oil puked in the airbox from riding wheelies and they never cleaned it out , this will be another good sign as to how hard the bike has or hasn't been rode.
- 32" Terminators
- 14" MSA M20 Kores
- 2" Spring spacers
- 2" Stretch
- EMP Metal Roof
Sold
99 Honda 300
02 Foreman 450
06 BruteForce 750
07 Renegade 800
09 Outlander 800R
#40
muddy450es
Re:Brute force? 2013/02/27 21:03:42 (permalink)
Would it be a good trade mine (in my sig.) for this http://greensboro.craigsl..org/mcy/3634826489.html ?
1987 Suzuki samurai
Lifted 9"
33" Boggers
Stage 2 clutch
HID's
Custom side pipe
#41
KC
Re:Brute force? 2013/02/28 04:27:14 (permalink)
Idk man that is a carb'd bike, it looks pretty weathered like its been left sitting out, the engine looks mud stained, and 350 hours is a lot ! Personally I would but use your better judgement
- 32" Terminators
- 14" MSA M20 Kores
- 2" Spring spacers
- 2" Stretch
- EMP Metal Roof
Sold
99 Honda 300
02 Foreman 450
06 BruteForce 750
07 Renegade 800
09 Outlander 800R
#42
Bamabrute85
Re:Brute force? 2013/02/28 06:07:45 (permalink)
If I had a budget of $5500 I wouldn't even consider the 650. I'd go with the 750 all the way. They don't put fuel injection on any of the 650's for some reason. Me personally, I've had 6 years of nothing but great luck out of my Brute Force. I don't care to get on it pretty hard but I don't abuse it. I still have the factory belt on it. The first 1200 miles it had 27 inch Vampires. The past 800 miles it had 29.5 Outlaws on it.  I ride wheelies on it a lot too but usually not for more than 30 or 40 feet.
However, if I were in your shoes I would try to find an Outlander 800r. You might have to go up to a $6000 budget but I believe you'll have a more reliable, more powerful, better, bike in the long run.
06 Brute Force 750.
29.5 Outlaws,
Maxxis 4x4 rims,
HL 2" lift.
HMF full exhaust.
K&N and jetted
Moose Module
HL Radiator Relocator
05 Big Bear
stock as a rock for now.
#43
KC
Re:Brute force? 2013/02/28 14:50:22 (permalink)
X2/ That's what I have been trying to say all along..
- 32" Terminators
- 14" MSA M20 Kores
- 2" Spring spacers
- 2" Stretch
- EMP Metal Roof
Sold
99 Honda 300
02 Foreman 450
06 BruteForce 750
07 Renegade 800
09 Outlander 800R
#44
840 Brute
Mud Slinger
Re:Brute force? 2013/03/01 06:39:01 (permalink)
you dont want that 650,get a good clean EFI there are plenty in VA and NC for sale
#45
