LockedBrute Force wont stay running
TGD600
2010/05/24 12:27:03 (permalink)
Hey  yall i was wondering what would cause my buddies brute force to start up but die if you dont give it constant throttle?
2007 Grizzly 700 EPS
29.5 Laws
SS212's
Snorkeled
PCIII
Axia Alloys 2" tip
/// Airdam Stage 3
Wild Boar Radiator kit
Viper Max 3000
HID 10,000K High kit
Angel Eye Low Beams
Aluminum Products A-Arm Guards
2001 Grizzly 600 (Sold)
2' Lift
2' spacers
White Secondary
Competition Stall Springs
12 gram weights
28' silverbacks
Snorkeled
2001 Ford F-150
3' lift and 35' Grapplers
11 Replies Related Threads
    scarface300
    Re:Brute Force wont stay running 2010/05/24 12:34:14 (permalink)
    could be a slow jet clogged in a carb, has it been sitting for awhile or did it just start doing this? what was he doin?
    A couple of 300s
    A couple of brutes
    TEAM DO WORK: OAK PARK CHAPTER!
    TGD600
    Re:Brute Force wont stay running 2010/05/24 12:38:06 (permalink)
    Im not totally sure what happened it will run fine if your going down the road but the minute you stop it will sputter and die. im pretty sure its never been sunk but im not definite on that.
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    scarface300
    Re:Brute Force wont stay running 2010/05/24 12:41:39 (permalink)
    id pull the carbs and clean them and see if that helps. plus id check the plugs and make sure they arent fowled. could also be an issue with the choke plungers not releasing all the way and making the bike flood and shut off at idle when it warms up if its a carbed model. guess i shoulda asked what year is it? is it even carbed? if its fi it could be the throttle position sensor
    A couple of 300s
    A couple of brutes
    TGD600
    Re:Brute Force wont stay running 2010/05/24 12:44:06 (permalink)
    yea my bad its carbed and its an 07
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    TGD600
    Re:Brute Force wont stay running 2010/05/24 12:46:15 (permalink)
    an how hard is it to take off the carbs on a brute? dont they have two or something like that?
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    TGD600
    Re:Brute Force wont stay running 2010/05/24 14:25:44 (permalink)
    anyone know how hard they are to take off?
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    Resquedude
    Re:Brute Force wont stay running 2010/05/24 14:28:32 (permalink)
    Not that bad... i've done mine several times to jet etc..  could try some seafoam first??
    2007 Black Brute Force 750
    lifted  -  Swamplites/SS212's
    Carb stuff - Clutch stuff - CDI stuff
    Submarine Snorkel
    4000lb Viper Winch
    HMF Swamp Series
    Pro X tie Rods
    "That there's an ATV Clark"
    TGD600
    Re:Brute Force wont stay running 2010/05/24 14:30:05 (permalink)
    how much of the plastic do you have to take off before you can get to them?
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    Resquedude
    Re:Brute Force wont stay running 2010/05/24 15:00:35 (permalink)
    You will need to pull the battery and battery box.. if your creative that's all but it makes it much simplier to pull left side palstic as well.
    Submarine Snorkel
    4000lb Viper Winch
    HMF Swamp Series
    Pro X tie Rods
    TGD600
    Re:Brute Force wont stay running 2010/05/24 18:10:48 (permalink)
    ok thanks for the info man
    29.5 Laws
    SS212's
    Snorkeled
    PCIII
    Axia Alloys 2" tip
    /// Airdam Stage 3
    Viper Max 3000
    Angel Eye Low Beams
    2' Lift
    2' spacers
    White Secondary
    12 gram weights
    28' silverbacks
    Snorkeled
    2001 Ford F-150
    scarface300
    Re:Brute Force wont stay running 2010/05/24 22:03:56 (permalink)
    i just pull the air box and left side the carbs are right there but i would probably try seafoam 1st if you havent done it b4
    A couple of 300s
    A couple of brutes
