Hot!BIGBEAR
JKBIGBEAR
2019/02/09 17:11:05 (permalink)
BIGBEAR
have a big bear 400 timing was off so set timing but now I have no compression it sucks in not blowing out before I had 123# compression WHATS the  problem
9 Replies Related Threads
    Re: BIGBEAR 2019/02/09 17:21:44 (permalink)
    I believe at some point you bent a valve my friend. So just go ahead and pull the head off and you will find your problem.
    JKBIGBEAR
    Re: BIGBEAR 2019/02/09 21:27:59 (permalink)
    OK PULLED HEAD OFF VALVES ARE GOOD PUT WHEN TIMING MARK IS ALINED PISTON IS DOWN
    Re: BIGBEAR 2019/02/09 21:45:52 (permalink)
    Something is allowing the compression to escape. So valves, rings, gaskets, cam, cam gear. I'd say make sure your piston is moving up and down but I believe you would have already checked that. Also if you have the head off flip it over and fill it with break clean on the valve side and make sure it doesn't drain out when they are closed.
    JKBIGBEAR
    Re: BIGBEAR 2019/02/09 22:22:49 (permalink)
    BRAKE FLUID DOESNT LINK OUT GOING TO CHECK KEY ON FLY WHEEL
    Re: BIGBEAR 2019/02/10 10:55:57 (permalink)
    Yea that definitely could be it as well!!!! How did the timing get off?
    JKBIGBEAR
    Re: BIGBEAR 2019/02/10 12:26:20 (permalink)
    pulled it apart the keyway was broke
    Re: BIGBEAR 2019/02/10 13:00:28 (permalink)
    There you go.
    JKBIGBEAR
    Re: BIGBEAR 2019/02/16 14:04:45 (permalink)
    its running now
    Re: BIGBEAR 2019/02/16 14:23:04 (permalink)
    Awesome!!!!
