Locked*BIG PROBLEMS* 2004 Grizzly 660
HuxGrizz
2010/02/02 22:57:43 (permalink)
I have a 2004 Grizzly 660 and at the end of last year i started having trouble when getting into the throttle on it so ever since then i have cleaned the carb out multiple times, replaced the drive belt with a new one and put a new air box on it. After all this, i put the carb back on the rourwheeler and got the same results, so i took the jet kit out and moved the needle back to stock. Still the same, so I took the head off and sent it off and got it polished and the valves seated, had no bent valves or nothing like that. I put it back on thinking i may have fixed the problem, but not a bit of differnce. I have checked the timing and i feel like i have it right and i have been double checked by a friend. So last week i got it back out and tried to see if i was missing something and the same stuff. I can put the carb on the engine and hook everything up and it will fire up with the choke on and the throttle closed, blocking all air off, but when i push the choke down it starts running raspy and if i hit the throttle any it will bogg the engine down and shut it off instantly. Today i took carb off to try and elimate some problems and i think i eliminated the carb because even when it is off the intake to the engine, i can take my hand and put it over the intake and the motor will turn over but as soon as i lift one finger it will stop turning over and the battery starts straining and whinning and pulls it down big time to where my LCD screen even shuts down! So im at this point and im not sure where to go from here, im at my witts end! Any help or advice on what to look for would be very much appreciated! Thanks yall, Matthew
12 Replies Related Threads
    sscard
    Re:*BIG PROBLEMS* 2004 Grizzly 660 2010/02/03 08:27:22 (permalink)
    ok, give us a list of mods for the bike, snorkles, pipe filter, etc
    if it was mine I would start by cracking the lid of the gas tank to make sure its not in a vacuum
    take the carb off and and verify that the choke is working properly
    and if all that is fruitless, then its time to seriously work on timing,
    im assuming you have verified that it has good gas, not water and that it has a good spark
    and plug
    Can Am Outty 800 MAX
    Can Am 800r Black
    its got options
    Texas Mud Hole Patrol
    http://www.facebook.com/pages/Texas-Mud-Hole-Patrol-Atv-Club/312120687051
    Hutch
    Re:*BIG PROBLEMS* 2004 Grizzly 660 2010/02/03 08:44:58 (permalink)
    Part of the issues sound like a clogged slow jet.  ( ie: will run with choke, stumbles when choke is off)  Where are you located?  Go to your local dealer or atv store and order a 45 slow jet.
    ATV WORKS
    HuxGrizz
    Re:*BIG PROBLEMS* 2004 Grizzly 660 2010/02/03 09:33:59 (permalink)
    I have drained the fuel and replaced with new, the spark plug seems to be throwing good fire. The choke has been looked at and is working properly. I have come to conclusion that it may not be in the carb because if i pull the carb off the intake of the engine completely it will not turn the battery over until i put my hand over the boot and shut off all air completely to the engine but if i lift one finger the battery starts struggling and the engine will not turn? so it sounds to me that it may be internal or maybe even electrical? thanks for the help guys! Matthew
    sscard
    Re:*BIG PROBLEMS* 2004 Grizzly 660 2010/02/03 10:10:50 (permalink)
    not electrical
    but really sounds like timing
    may be 180 degrees out
    will show lined up but be completely opposite on timing
    Can Am 800r Black
    its got options
    Hutch
    Re:*BIG PROBLEMS* 2004 Grizzly 660 2010/02/03 10:29:23 (permalink)
    HuxGrizz
    Two different issues going on at the same time.  Your engine was already running,  it just wont run off of choke.  Put a fresh battery in it and REALLY clean the carb and/or replace the pilot jet (slow jet) with a 45.    Enjoy riding your bike this season.
    ATV WORKS
    ALPHA_GRIZZLY
    Re:*BIG PROBLEMS* 2004 Grizzly 660 2010/02/04 10:11:01 (permalink)
    sounds like water in the carb bowl or the tank vent is clogged.   check for water in the bottom of the tank and drain the bowl, take the gas cap off too and give it a try.
    MY MONEY PIT!!!
    • 28" Mud Gears with HL 1 1/2" Spacers
    • XPATV  2" lift, 10000K   HID's
    • Wireless Venom 3000 Winch
    • Raptor Stage II Cam,K&N,Dynojet,HMF,
      Wiseco 11.1 piston, .40 over
    • Extreme Clutch Kit, Snorkeled out
    • Custom Skids,Coil Spacers
    • Gorilla GIS rear Axles\Flipped hubs
    • Overfenders, custom radio and a few other things
    Dukeboy88
    Re:*BIG PROBLEMS* 2004 Grizzly 660 2010/02/17 14:50:32 (permalink)
    I just found this post with a google search, I have a 2004 660 with almost the exact symtoms, the LCD blanking and starter struggling, poor throttle response, no top end etc.  Sorry if this is a Hijack but how would you know if the timing is 180 out? how would it run?   there may be other problems, but sscard's reponse caught my attention.
    AC500iM
    Re:*BIG PROBLEMS* 2004 Grizzly 660 2010/02/17 15:00:51 (permalink)
    ^^both (all) valves should be closed when timing marks are lined up.
    ....I had a similar issue with one of my machines and it turned out to be a itty bitty tiny seed stuck in pilot.
    Good luck, I'd listen to SSCARD.
    2011 Grizz 700
    "Big Blue"
    2011 550XP (Sold)
    Great ride...not built to last :(
    06 500ES (Sold..g'bye my friend)
    w/some stuff......
    DAllen68
    Re:*BIG PROBLEMS* 2004 Grizzly 660 2010/02/17 19:21:53 (permalink)
    if you have a friend that has a 660 , see if he will take his carb off and let you put on your bike and see if it still acts up, if it don't act up and runs fine then you need an new carb . a friend of had the same thing happein to his 660 he had to put a new carb on it to fix it or rebuild it ,but if you rebuild it you may still have the problem  because if you don't replace everything on the carb you have done nothing and why i know this is because we tried rebuilding it frist waste of money and time
    post edited by DAllen68 - 2010/02/17 19:56:41
    2004 limited stroker
    Truservon
    Re:*BIG PROBLEMS* 2004 Grizzly 660 2010/02/17 21:40:43 (permalink)
    if you still have the hose on you tank lid check that. if clear, pull tank and take out the fuel petcock with the 2 phillips head screws and clean tank really well,might wanna get an external filer. take carb and go through that. if still having issues check plug for any type of water/moisture.The reason i say that is....mine is doing the same thing, i have a blown head gasket! Also check your compression.
    Adam Ladner-MudNutZ-MudNutZRacing
    www.msmudnutz.com
    www.facebook.com/MudNutZ
    Competition Sports
    Mud Life Magazine
    Back2Productions
    AMRacing
    ///AIRDAM
    Cycra Racing
    Dayco
    Performance Lube and Filter
    Vision X
    Utopia Optics
    GoPro
    Dixie Signs
    LJ Customs
    Dukeboy88
    Re:*BIG PROBLEMS* 2004 Grizzly 660 2010/02/23 12:55:52 (permalink)
    I'll try all suggestions and get back to you when I get the time, thanks again.
    Bennie
    Mud Slinger
    Re:*BIG PROBLEMS* 2004 Grizzly 660 2010/02/25 21:12:13 (permalink)
    Make sure that your float does not have a hole in it.
    '04 Kodiak 450
    26 mudlites
    ITP c-series rims
    Big Gun exaust
    2" Moose lift
    '95 Foreman 400
    28 laws
    SS212 Black ITP
    HMF pipe
    '04 Shocks
    2" Moose lift
    K&M filter
    09' Polaris 550XP
    Mossy Oak edition
    30" Mudlites XXL
    OFFROAD ADDICTIONS
    "Going Deep aint Cheap"
