LockedArctic cat 650 h1 vs Arctic cat 650 h2
sinister1ca
2008/08/04 10:38:56 (permalink)
I'm new to the world of atv's, read about them for years, always new I would get one. Almost bought a 650 Brute force, but felt i needed a 2 rider atv. So I got  08 Arctic cat 650 h1 TRV, I know the same motor that is in the brute force is in the h2 what motor is the more superior. not that I had a choice going with the TRV, Just wondering.
08 Arctic cat 650 H1 TRV
stock
18 Replies Related Threads
    Jake450s
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/04 13:47:26 (permalink)
    That's a very subjective question with multiple answers, they're both good engines but with some differences, like any two other engines out there.  The grass is always greener on the other side of the fence.  You've got a nice ATV, enjoy it with no regrets.
    .02
    SkintBak
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/04 15:01:44 (permalink)
    I thought the only h2 was in the thundercat.  Anything that AC makes with an h1 behind it is an Arctic Cat engine, not a suzuki or kawasaki.
     AC 700 EFI -Gone but not forgotten
     2012 Teryx 4 aka "Iron Man"
    \\\Airdam///
    3" CATVOS
    STI C7's wrapped in 31 skinnys
    Custom Roof w/"chopd' and screwd' cage"
    Tunes
    Runnin on "Blueberry Juice"
    TEAM YO MONEY
    "FUN ON YO DIME"
    "Shut up and Ride"
    Administrator
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/04 20:42:25 (permalink)
    Yes AC put a 650 kawie (not a H2) motor in the cats for 3 year and they are pretty equal in power with a 650H1 stock to stock but the 650 Twin of the Kawie can be made to be alot faster.
    08 650H1 L.E.
    Custom tie rods ;
    29.5" Laws on ITP type 7s
    sinister1ca
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/05 14:39:04 (permalink)
    Here in Nova Scotia it was advertized as H2 got lots of canadian mags to prove it.
    Administrator
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/05 16:50:59 (permalink)
    Huh never heard it called a H2 before untill the 650H1 single came out then i have heard a few people call it that. guess i will not tell anyone its not called a H2 anymore..lol
    08 650H1 L.E.
    Custom tie rods ;
    sinister1ca
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/05 17:03:13 (permalink)
     Maybe just called that in Canada, We never got any Kawasaki's called praries, just KVF, now Brute force. Also had a Canadian trail edition of the Honda Rubicon, that was not avail in the states.
    LiveForMud
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/05 17:10:35 (permalink)
    the cats from 2004-2006 with the 650 kawi motor was called the "V2" for v-twin. arctic cat uses the "H2" callsign for the 950 v-twin in the thundercat and the H1 for the AC single cylinder 650 and 700 engines of theirs.
    i think it was in either '06 or '07 that kawi revamped the 650 and now it makes a good bit more power than the old prarie 650 (which is what was in the 04-06 V2 cats).
    i gave a pretty good comparison of the prarie-version of the kawi 650 V2 versus the AC 650 H1 in a post a while back (seen below). this post was more specifically for comparing the AC 650 V2 (04-06 models) versus the AC 650 H1 (05+).
    but in a nutshell, the kawi engine makes superior power with mods, but the cat will have the better belt system (and cat's new bevel gears make the secondary bulletproof) and front differential. both have VERY similar gearing. so mud performance will be very similar... the kawi will just get through the pit a bit faster when you open that v-twin up.
    http://www.highlifter.com/forum/m_2749241/mpage_1/key_reduction/tm.htm#2749313
    From a geometry standpoint, they're equal (ground clearance, suspension, weight, etc). The H1 has the better transmission since it uses a constant-tension belt with an internal wet clutch (the best, most durable kind of belt drive), while the kawi uses the old grab-n-go type system which is much more suseptible to slipping and burning the belt. But the V2 has a little more power stock, and a TON more power when modded since there's a huge aftermarket for this motor (up to 916cc big bore strokers!).
    Now, keep in mind that the prairie/brute 650s and 750s are geared almost identical to the cat 500 auto and H1, except that the kawis use very low 4.38 differential gears to achieve their gear ratios, while the cat/suzuki engines use lower transmission gearing and taller 3.6 differential gears. The problem with the kawi 650 in the cat frame is that cat doesn't offer deeper differential gears to give it the same overall gear ratios that kawi intended it to have. and since the V2 uses the grab-n-go style trans, it doesn't grip the belt strong enough for the taller axle gears of the cat (lower trans/axle gears take stress off of the belt). I'll show this in the next few bits of info:
    ___________________________________________
    Arctic Cat 650 H1 (37hp)
    Primary (V-belt): 2.876 - 0.703
    Secondary: 2.562 (41/16)
    Final:  3.6 (36/10)
    Range Reduction                     (Overall)
    High:  1.200 (30/25)             (31.831 - 7.781)
    Low:   2.500 (40/16)             (66.315 - 16.210)
    Rev:   2.000 (28/16x32/28)    (53.052 - 12.968)
    With 4.0s, the H1's gearing looks like this:
    High:  1.200 (30/25)             (35.368 - 8.646)
    Low:   2.500 (40/16)             (73.683 - 18.011)
    Rev:   2.000 (28/16x32/28)    (58.947 - 14.409)
    Arctic Cat 650 V2 (40hp)
    Primary reduction (V-belt):  3.122 - 0.635
    Final drive ratio  3.6 (36/10) [2004-2005]
    Range     Reduction
    High:  3.098 (30/26 x 29/18 x 20/12)
    Low:   4.833 (36/20 x 29/18 x 20/12)
    Rev:   4.028 (16/12 X 18/16 X 29/18 X 20/12)
    Overall Ratios
    High:  34.819 - 7.082
    Low:   54.319 - 11.048 (<- the reason you can go 45+mph in low)
    Rev:    45.271 - 9.208
    With 4.0 gears (stock on 2006 V2s)
    Overall Ratios
    High:  38.688 - 7.869
    Low:   60.354 - 12.276
    Rev:    50.301 - 10.231
    And so you can see how kawasaki intended the V2 to be geared, here's the kawi gears:
    Prairie/Brute Force 650/750
    Final drive ratio  4.375 (35/8)
    Range     Reduction
    Overall Ratios
    High:  42.315-8.607
    Low:   66.013-21.761
    Rev:     55.017-11.190
    The 2004 and 2005 cat V2s had the 3.6 gears, which you can see makes for a meager gear range (it's still geared better than the grizzly 660/700 and KQ 700/750, but the V2s belt setup can't handle this gearing very well). so even when the V2 has 4.0s, the H1 still has a good 10% advantage in gearing in low range and 8% advantage in reverse. Stick 4.0s in the H1 and the H1 jumps ahead by a lot.
    However, there are a couple of gear reductions (secondary gear set) for the kawi motors. the kawi V2 stock secondary is a 1.667:1 reduction (20/12), while the secondary out of a teryx is 1.909:1 (21/11), which is a 14.5% reduction (see this thread for more info: http://www.highlifter.com/forum/m_2692677/mpage_1/tm.htm ). the other reduction is a fully custom cut set from a guy in germany, who posts on here as richardulc42 and he said it takes the secondary from 1.667 (20/12) down to 2:1 (20/10), for a 20% reduction.... http://www.highlifter.com/forum/m_1845257/mpage_1/key_/tm.htm#1849613  http://www.highlifter.com/forum/m_1845257/mpage_1/key_/tm.htm#1850050 .
    so, if you were to put 4.0s and the teryx 14.5% reduction in the cat V2, you'll wind up with neary close to the gearing of a stock H1 (actually a slight bit lower). put 4.0s and richard's 20% reduction in the V2, you'll have almost identical gearing to an H1 with 4.0s (H1 w/4.0s = 73.683 low starting ratio, V2 w/4.0s & richard's 20% = 72.425 low starting ratio).
    the V2 will always sound better with a pipe, will pretty much will always have more power, and with the available reductions, can be geared pretty much just like the H1 with 4.0s. but the H1 will always have the better belt system and the engine won't self destruct the 1st time you drown it out (the kawi V2s are hideous when drowned out).
    hope this helps...
    FAR-FROM-STOCK
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/07 10:50:44 (permalink)
    nice write up [;)]
    Dirtbmw20
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/07 12:14:55 (permalink)
    Excellent write up LiveForMud.
    05' Sportsman 500 H.O.
    Rubber Down 3" Lift
    Lots of "goodies" I couldn't afford
    Dirtbmw20's Pics
    badtothebonehonda
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/07 21:34:39 (permalink)
    this is for all your articat lovers
    1 hondas are gear to gear no belts
    2 500s hav pull starts none of the articats due
    3 articats batterys die after  being left out[&:]
    all hondas rule!
    badtothebonehonda
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/07 21:40:03 (permalink)
    i told u guys hondas rule[sm=brutal_36.gif][sm=nopics.gif]
    all hondas rule!
    Administrator
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/07 21:57:43 (permalink)
    ORIGINAL: badtothebonehonda
    What does any of this have tio do with this thread..?  [&:]
    1. my AC 500m has no belt.
    2. It has a pull start..
    3. it has the same battery in it sence it was bought in 05.
    08 650H1 L.E.
    Custom tie rods ;
    Lawnboy1988
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/07 22:09:58 (permalink)
    lol pwned!
    2000 Honda Foreman S. Reverse Lights, 3rd light switch, Warn 2000lb winch, 26" Swampwitches. Homemade Audiotube. Air Horns. Strobes. Viper MX2000 Rear Winch. Disc Conversion
    BLACKCATT
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/08 13:16:30 (permalink)
    ORIGINAL: GWC
    Ditto!!!!!!!! [:D]
    My 05' 650 H1 has...
    1. A belt... I will never go back to manual!
    2. A pull rope.
    3. The original battery from 05'
    2005 650 H1 LE
    "Original H1 Kitty"
    29.5 x 12 laws
    type 5s
    4.0s
    rad/oil cooler up top
    sealed & snorkeled
    carb drilled & clipped
    secondary cage mod
    secondary spring mod
    3.63 mm shim
    rollers drilled
    stock muffler mod
    exhaust snorkel
    MudCrawler
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/08 14:04:05 (permalink)
    My 2003 500 is the same way.  Well not the battery thanks to a 3 year old.
    2003 Arctic Cat 500m
    28 12 12 outlaws all 4 corners
    3 gorilla-axles
    itp type 5
    Snorkeled
    jetted
    The Back Up Bike
    1994 Kodiak
    laws, BBK and other things
    www.undergroundatv.com
    bulldogmech77535
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/11 16:49:45 (permalink)
    My 06' still has a pull rope,  but with all the compression I have never  been able to start it with the rope.....  and atv batteries do not last on any quad...
    4man0822
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/11 17:23:34 (permalink)
    ORIGINAL: Lawnboy1988
    lol pwned!
         [sm=exactly.gif] Crazy Kid! LOL!              Brandon
    I'm just some dumb, not plumb dumb!!!
    My new ride= 08 750 King Quad Old, Slow & Woe Out!
    "STOLEN"--- 07 700 Camo King Perty loaded out!
    450 Kingquad=3" XPATV lift, lil clutch Luvin & motor Luvin
    250 Suzuki Ozark=Swamp lites on crush loks for racing! 25" Outlaw MST's for riding! !
    08 400 Can Am, 08 500 Gade= Pimp Ride, '13 400 Can Am= Wife's ride
    Sponsored by= Mud Diva, BitMore Performance,  ///Airdam Clutches, Twin Air, Suzuki City, Web Camshafts, Twin Air, Amsoil & Yoshimura
    Full Throttle Racing because Anything Less Will Get You Beat!!
    My new ride= 2011 800 Gade
    07bayoukitty
    RE: Arctic cat 650 h1 vs Arctic cat 650 h2 2008/08/11 17:25:03 (permalink)
    the only pull rope i ever needed was to pull honda.[:D][:'(]
    07 650 h1 29.5" laws custom snorkle more mods coming 00 500m 28" 589's custom 2" lift
    #19
