LockedArctic Cat code sheet to help you guys out
holman0169
2011/11/26 23:25:26 (permalink)
i noticed that some of the ac codes were not in the stickies so figured id put some pics up of the rest of them. maybe someone will add this to stickies for us.
this is the 450 1000 code sheet
ARCTIC CAT
09 Mud Pro
SLD Welded
Temp gague in the pod
30" Backs
14" ITP beadlocks
Custon fiberglass speaker pods
Ape Axles all around
REAL STEEL custom paint
12" crush locks with 29.5 laws for the pits
B&J 2.5 inch lift
stage 5+ ///airdam
  AIRDAM WET CLUTCH DELETE
98 Yamaha Big Bear aka the aquatic bear
KC daylighters
billet phantom grill
www.myspace.com/bruceholman
13 Replies Related Threads
    THEmisfit
    Re:Arctic Cat code sheet to help you guys out 2011/11/27 00:29:25 (permalink)
    if there is a fault code thrown would it show up on the pod or just a chck engine light show up? what do i do to chck for these?
    Balls Deep
    *** Renegade- Race Ready
    Clutch'd and Motorwork'd
    PC3
    HMF
    Crushed 29.5 OL2's
    holman0169
    Re:Arctic Cat code sheet to help you guys out 2011/11/27 02:11:43 (permalink)
    on the mud pro, look under the seat for the diagnostic plug. using a paper clip or piece of wire, jump the blue and black wires. turn key on and it will read you any stored codes that have been set.
    ARCTIC CAT
    09 Mud Pro
    SLD Welded
    30" Backs
    14" ITP beadlocks
    B&J 2.5 inch lift
    stage 5+ ///airdam
    KC daylighters
    PRESIDENTAIL GRIZZ
    Re:Arctic Cat code sheet to help you guys out 2011/11/29 09:07:17 (permalink)
    Nice...I can't clear my stored codes? I've tried but they are still there. Any suggestions?
    2014 RZR1000 Nuclear orange (his)
    33 Terms  on 15" MSA 21
    5" lift
    Lights
    Radio
    08 RZR sold
    09 MUD PRO (HERS)
    2.5 RDC LIFT
    32 BACKS
    TUNES
    BLACK & PINK
    PINK LEDS
    ~BIONIC REDNECKS~
    holman0169
    Re:Arctic Cat code sheet to help you guys out 2011/11/29 13:09:06 (permalink)
    Leave jumper in diagnostic port. Be sure bike is In 4x4. Hold override button, turn key on and wait about 5-10 seconds.
    ARCTIC CAT
    09 Mud Pro
    SLD Welded
    30" Backs
    14" ITP beadlocks
    B&J 2.5 inch lift
    stage 5+ ///airdam
    KC daylighters
    PRESIDENTAIL GRIZZ
    Re:Arctic Cat code sheet to help you guys out 2011/11/29 13:33:52 (permalink)
    K thanks!
    5" lift
    Lights
    Radio
    08 RZR sold
    09 MUD PRO (HERS)
    2.5 RDC LIFT
    32 BACKS
    TUNES
    BLACK & PINK
    PINK LEDS
    ~BIONIC REDNECKS~
    Donut
    Re:Arctic Cat code sheet to help you guys out 2011/11/29 17:21:44 (permalink)
    So this will work for my 2010 thunder cat?
    PRESIDENTAIL GRIZZ
    Re:Arctic Cat code sheet to help you guys out 2011/11/29 17:41:38 (permalink)
    yup
    5" lift
    Lights
    Radio
    08 RZR sold
    09 MUD PRO (HERS)
    2.5 RDC LIFT
    32 BACKS
    TUNES
    BLACK & PINK
    PINK LEDS
    ~BIONIC REDNECKS~
    Donut
    Re:Arctic Cat code sheet to help you guys out 2011/11/29 17:45:41 (permalink)
    Cool. Thanks alot man
    abrady
    Re:Arctic Cat code sheet to help you guys out 2011/11/29 18:36:20 (permalink)
    i did this to my bike after it stated to mess up an got 4 SC codes and one AC code. the AC code was AC00 witch is no fault
    then for the SC codes crank shaft position , #1 coil , tilt, and fuel pump relay.
    After seeing all of that i took it to the shop still waiting to here back from them on what the problem was. also all of the codes i got will cause the bike not to start.
    post edited by abrady - 2011/11/29 18:37:22
    09' 550H1 LE
    holman0169
    Re:Arctic Cat code sheet to help you guys out 2011/11/29 18:50:53 (permalink)
    sounds like your harness is gonna have some damaged areas. or someone unplugged some stuff while the key was on.!!
    ARCTIC CAT
    09 Mud Pro
    SLD Welded
    30" Backs
    14" ITP beadlocks
    B&J 2.5 inch lift
    stage 5+ ///airdam
    KC daylighters
    abrady
    Re:Arctic Cat code sheet to help you guys out 2011/11/29 18:52:09 (permalink)
    the **** if i know i just took it to the shop for them to play with glad i have the extended warranty.
    09' 550H1 LE
    SixOhh
    Re:Arctic Cat code sheet to help you guys out 2011/11/30 20:01:21 (permalink)
    holman0169
    i also would like to note this is the mode where you adjust the TPS as well.  there will be a horizontal line by the gear position indicator.
    If there are no EFI/ ECU codes in the help section we need to get this pinned... good job
    -Marcus
    --2013 RZR 570--
    5" outkast, custom hydro dip
    32" Terms, S3 axles, SMD lighting,Strobage
    UTV INC switches,JL Audio /Memphis, PRP 5050 seats
    01' AC300
    crushed 29.5 OL2's by MyTater
    Strobes, snorks and a taste for water.
    --- Follow Me To Void Your Warranty ---
    H-Town Off-Road
    PRESIDENTAIL GRIZZ
    Re:Arctic Cat code sheet to help you guys out 2011/12/01 05:26:46 (permalink)
    How do you reset the oil change or service light?
    5" lift
    Lights
    Radio
    08 RZR sold
    09 MUD PRO (HERS)
    2.5 RDC LIFT
    32 BACKS
    TUNES
    BLACK & PINK
    PINK LEDS
    ~BIONIC REDNECKS~
