LockedArctic Cat Gear Ratios
LiveForMud
2009/02/14 14:20:51 (permalink)
AC 250/300 Manual (3-range transmission models)
Primary: 3.15 (63/20)
Secondary: 1.125 (18/16) [250 = 1.0625, (17/16)]
Final: 3.09 front / 3.647 Rear
Subtrans
High: 1.112
Low: 1.480
Super Low: 3.176
Trans
1st   3.083
2nd  1.933
3rd   1.388
4th   1.095
5th   0.913
Rev   2.833
Total Reductions
High Range
1st    44.309
2nd   27.781
3rd   19.948
4th   15.737
5th   13.122
Rev   40.716
Low Range
1st    58.972
2nd   36.974
3rd    26.549
4th    20.945
5th    17.464
Rev    54.190
Super Low
1st    126.548
2nd    79.344
3rd     56.973
4th     44.946
5th     37.476
Rev   116.286
AC 400 Manual
Primary:  2.392
Secondary:  1.133
Final: 3.6
Subtrans
High Range: 1.296
Low Range:  2.435
Trans
1st:  3.083
2nd: 1.933
3rd:  1.388
4th:  1.095
5th:  0.913
Rev:  2.833
Total Reductions
High Range
Gear   Total   (w/ 4.0s)
1st:   39.032  (43.369)
2nd:  24.472  (27.191)
3rd:  17.572   (19.524)
4th:  13.863   (15.403)
5th:  11.559   (12.843)
Rev:  35.867   (39.852)
Low Range
1st:  73.243   (81.381)
2nd: 45.922   (51.024)
3rd:  32.975   (36.639)
4th:  26.014   (28.904)
5th:  21.690   (24.100)
Rev:  N/A (reverse fix: 67.304:1 w/ 3.6s, 74.782 w/ 4.0s)
AC 400 Auto
Primary Reduction (V-belt): (2.938 - 0.813)
Secondary reduction ratio:  2.730  (42/19 x 21/17)
Final:    3.6 (36/10)
Range Reduction          (Total Reduction)
High:    1.375 (33/24)    (39.703 - 10.986)
Low:     2.5 (40/16)       (72.187 - 19.975)
Rev:     2.0 (32/16)       (57.749 - 15.980)
With 4.0s (Stock on 07+ 400 Autos)
High:    1.375 (33/24)    (44.114 - 12.207)
Low:     2.5 (40/16)       (80.208 - 22.194)
Rev:     2.0 (32/16)       (64.166 - 17.756)
2003+ AC 500 Manual
Primary:  2.032 (63/31)
Secondary: 1.133 (17/15) ("bevel gears")
Final: 3.6
Subtrans
Low Range:  2.419
High Range: 1.592
Trans
1st   3.090 (34/11)
2nd   1.750 (28/16)
3rd   1.200  (24/10)
4th    0.875 (21/24)
5th    0.724 (21/29)
Rev   2.636
Total Reductions
High Range
 w/ 3.6s |  w/ 4.0s |  w/ 18%  |  4.0s & 18%
40.770      45.300      48.109        53.454
23.090      25.656      27.246        30.274
15.833      17.592      18.683        20.759
11.545      12.828      13.623        15.137
 9.554      10.616      11.274        12.527
34.780     38.644       41.040        45.600
Low Range
61.949      68.832      73.099        81.222
35.086      38.984      41.401        46.001
24.059      26.732      28.389        31.544
17.543      19.492      20.700        23.000
14.515      16.128      17.128        19.031
52.848      58.720       62.361        69.290
AC/Vinson 500A, AC650 H1
Primary (V-belt): 2.876 - 0.703
Secondary: 2.904 (41/16 x 17/15)
Final:  3.6 (36/10)
High:  1.200 (30/25)             (36.080 - 8.819)
Low:   2.500 (40/16)             (75.167 - 18.374)
Rev:   2.000 (28/16x32/28)    (60.134 - 14.699)
With 3.1s (34/11)
High:  1.200 (30/25)              (31.069 - 7.594)
Low:   2.500 (40/16)             (64.727 - 15.822)
Rev:   2.000 (28/16x32/28)    (51.782 - 12.657)
With 4.0s (36/9)
High:  1.200 (30/25)             (40.089 - 9.799)
Low:   2.500 (40/16)             (83.519 - 20.415)
Rev:   2.000 (28/16x32/28)    (66.815 - 16.332)
Arctic Cat 700 H1
Secondary: 2.985 (33/13 x 20/17) [09+ secondary]
Final:  3.1 (34/11)
High:  1.200 (30/25)             (31.936 - 7.806)
Low:   2.500 (40/16)             (66.532 - 16.263)
Rev:   2.000 (28/16x32/28)    (53.226 - 13.010)
With 3.6s (36/10)
High:  1.200 (30/25)              (37.087 - 9.065)
Low:   2.500 (40/16)             (77.264 - 18.886)
Rev:   2.000 (28/16x32/28)    (61.811- 15.109)
With 4.0s (36/9, Mud Pro)
High:  1.200 (30/25)             (41.207 - 9.594)
Low:   2.500 (40/16)             (85.849 - 20.985)
Rev:   2.000 (28/16x32/28)    (68.679 - 16.788)
Arctic Cat 650 V2
Primary reduction (V-belt):  3.122 - 0.635
Final drive ratio  3.6 (36/10) [2004-2005]
                        4.0 (36/9)   [2006]
Range     Reduction
High:  3.098 (30/26 x 29/18 x 20/12)
Low:   4.833 (36/20 x 29/18 x 20/12)
Rev:   4.028 (16/12 X 18/16 X 29/18 X 20/12)
Total Reductions (3.6s)
High:  34.819 - 7.082
Low:   54.319 - 11.048
Rev:    45.271 - 9.208
3.6s w/ Teryx 1.909:1 secondary (21/11) [a 14.5% reduction]
High:   39.868 - 8.109
Low:   62.195 - 12.650
Rev:    51.835 - 10.543
With 4.0 gears (stock on 2006 V2s)
High:   38.688 - 7.869
Low:   60.354 - 12.276
Rev:   50.301 - 10.231
With 4.0s & Teryx secondary
High:   44.298 - 9.010
Low:   69.106 - 14.056
Rev:    57.594 - 11.714
AC 700 EFI (KQ DOHC Engine)
Primary (V-belt): 2.763 - 0.78
Secondary: 2.158 (40/21 x 17/15)
Final: 3.6 (36/10)
Range Reduction           [Overall]
High: 1.240 (31/25)    [26.617 - 7.514]
Low:  2.563 (41/16)    [55.015 - 15.531]
Rev:   1.882 (32/17)   [40.397 - 11.404]
With 4.0s
High: 1.240 (31/25)    [29.574 - 8.349]
Low:  2.563 (41/16)    [61.128 - 17.257]
Rev:   1.882 (32/17)   [44.886 - 12.671]
With 4.0s and Eiger 16% Reduction
High: 1.240 (31/25)    [34.306 - 9.685]
Low:  2.563 (41/16)    [70.908 - 20.018]
Rev:  1.882 (32/17)    [52.068 - 14.698]
(more to be added later?)
some of these have been updated since previous posts you've seen by me. still looking for the 366 and thundercat ratios. hopefully this info will help someone in their quest to pick the perfect tire/gear combo and set up your clutching for the right speed range.
if you use a gearing calculator like  http://www.f-body.org/gears/  , put in the size tires you want, then enter "1" for the axle ratio, put "8000" for the redline (most ute atv's rev limiter is here... i know the 400s and 500s are for a fact), then enter the total reduction ratio from above to get the speed range for that ratio. for you belt drive guys this should come in handy so you can more accurately modify the springs and weights to get the ratios/rpm you need in certain speed ranges for the hp you have to work with.
in general, 90% of ute atvs reach peak horsepower at around 6500rpm... so for you belt-drive guys to get the most power to the ground from 0mph to your top speed, you want to set the clutching up so when you go WOT the CVT holds ~6500rpm (or whatever your peak hp rpm is according to an engine dyno) and upshifts there the entire way. i've covered the calculations behind this in previous threads, so just do it and know you're getting the most bang for your buck. us manual guys just have to play with the gearing and shift as necessary.
7 Replies Related Threads
    squeak12
    RE: Arctic Cat Gear Ratios 2009/02/14 15:15:21 (permalink)
    Good info. I'm not sure that I will ever personally use it other than for comparisons, but I respect the time it took to gather all of this.
    jasongraham
    RE: Arctic Cat Gear Ratios 2009/02/14 18:03:04 (permalink)
    what about the 2000 500m straight axle i have one with a bad front diff and not sure what the ratio is i want to put a diff out of a 2007 so i can lock and unlock but dont want to put wrong gears in it
    "TEAM DO WORK"
    red rzr;31 laws,3in lift,front and rear bumpers,etc....
    green rzr; 27 xtrs,2in lift,cab,etc.....
    2008 Thundercat
    29 wide laws
    2007 renegade
    29 wide laws black 212s
    hmf, snarkles
    previous bikes
    2001 kodiak,all mods
    2005 650 vtwin arctic cat modded
    2007 can-am renegade modded
    2006 prowler modded
    2005 rhino stock
    many others,brutes,sportsmans etc
    squeak12
    RE: Arctic Cat Gear Ratios 2009/02/14 18:48:59 (permalink)
    I think we figured out that they had 3.1:1 until 03.  There's a thread somewhere on here in the last few pages.
    Administrator
    RE: Arctic Cat Gear Ratios 2009/02/15 11:50:04 (permalink)
    Good post  [:D] allways good info from you .
    Thanks[:)]
    08 650H1 L.E.
    Custom tie rods ;
    29.5" Laws on ITP type 7s
    WilliamBos
    RE: Arctic Cat Gear Ratios 2011/04/17 21:46:14 (permalink)
    What about the 450H1 ratio??
    Thanks,
    Will
    2012 Sportsman 400HO
    Polaris Hand & Thumb Warmers.
    Warn RT 25, Warn Hawse Fairlead, Synthetic Rope
    Glacier III plow.
    GSE Airfilter, Polaris Pre-Filter
    J_Fred
    RE: Arctic Cat Gear Ratios 2011/04/18 10:46:04 (permalink)
    Really good info to have.
    Does anyone know the details on the Teryx secondary swap on the 650 V2's?  That's lower than dropping 9t pinions in, and possibly a decent alternative for the V2 crowd.
    Arctic Cat 650 V2
    RZR 800
    31 Outlaws, Highlifter Lift
    awdcivic
    RE: Arctic Cat Gear Ratios 2012/11/26 11:39:19 (permalink)
    thank you very much now i know what i can put in my 300s front end without searching google forever.
    2004 Arctic cat fis 400 4x4.
    Custom rear winch mount with viper 4000.
    Custom fabbed manual 4x4 select.
    Racked oil cooler
    belt snorkels
    1.5 inch custom lift
    26x10 gators
    2008 arctic cat 650h1.
    2002 honda recon with my 97 footshift motor
    Some Awesome Memories:
    03 rancher 350 4x4
    2012 rancher 420 4x4 foot shift
    2003 Arctic cat 300 4x4.
    2005 Yamaha blaster 2 stroke.
