Hot!Another flat tire
MichaelSmith
2018/05/28 10:29:41 (permalink)
Another flat tire
Hi,
In the 25+ years of driving I never had more than one flat tire until I moved to Lantana.......for which I have had to have tires plugged at least 6 times and bought two replacements tires over the past three years. I thought I was finally done since our neighborhood (Heritage) is about built out but no....got another flat today which required a new tire.
This time there was a large metal construction staple and I'm sure it is from the new house under construction at the end of the street. Fortunately the plugs were done free by Discount Tire in the past but today's staple holes could not be plugged and thus I ended up buying $190 worth of tire repair today.
For More Details:-
Thanks!
13 Replies Related Threads
    Re: Another flat tire 2018/05/28 10:33:55 (permalink)
    Hmmmmm you must be working for discount tire!!! Go on your way you bottom feeder!!!!
    doveman1
    Re: Another flat tire 2018/05/29 09:34:46 (permalink)
    Maybe you should put tracks on
    Green 2015 Grizzly 700
    2in HL lift
    N2deep battery relocation
    Wild boar radiator relocation
    Re: Another flat tire 2018/05/29 12:48:26 (permalink)
    What happens if your hovercraft has a flat? Will discount tire fix it for free?
    doveman1
    Re: Another flat tire 2018/05/30 20:02:00 (permalink)
    You just have to supply the air and rubber cement
    2in HL lift
    doveman1
    2in HL lift
    Re: Another flat tire 2018/05/30 20:32:40 (permalink)
    What if a have a no flat wheel barrow tire will they fix it for free?
    doveman1
    Re: Another flat tire 2018/06/02 11:40:38 (permalink)
    They’ll replace it and only trade you some grass clippings.
    2in HL lift
    Re: Another flat tire 2018/06/02 14:26:08 (permalink)
    My skid steer track is flat so what about that?
    doveman1
    Re: Another flat tire 2018/06/02 18:27:14 (permalink)
    If it’s flat then they recommend adding air
    2in HL lift
    Re: Another flat tire 2018/06/02 20:41:51 (permalink)
    Well I'm gonna have to bring it in cause I can't find the schrader valve. Hopefully I didn't break them off.
    doveman1
    Re: Another flat tire 2018/06/02 20:49:13 (permalink)
    Hope you don’t need it for a week. Them boys can’t even spell skid steer
    2in HL lift
    Re: Another flat tire 2018/06/02 23:14:35 (permalink)
    I have those new Michelin X Wheel tires and I can't figure out how to check the air pressure! Can they do that for free?
    doveman1
    Re: Another flat tire 2018/06/02 23:32:29 (permalink)
    That’s simple. You just run them into the curb as hard as possible, determine air pressure by how hard it hits. If something breaks, not enough pressure
    2in HL lift
