LockedAR15
doveman1
2017/10/06 23:03:59 (permalink)
AR15
Okay I'm getting serious about buying an AR. I am on a TIGHT budget. Looking into a Diamondback. Only reviews I can find are 3-4 years old, but my local shop usually keeps some around and they are picky about quality they put on the shelves.
I'm stuck between 5.56 and 300 blackout. Eventually I want both but really need to get the ball rolling on getting one, getting it set up, and beginning to stock up. What are yalls thoughts?
On last question is optics. When i get the 5.56 I want it more of a tactical set up. So I'm thinking short range optic of some sort but I believe iron sights are a MUST with it. Thoughts?
Here's what I'm looking at. Exact model for either caliber unless we dig up something more better.
Remember, pretty tight budget!
Green 2015 Grizzly 700
2in HL lift
N2deep battery relocation
Wild boar radiator relocation
34 Replies Related Threads
    Re: AR15 2017/10/06 23:34:15 (permalink)
    I personally had a Bushmaster that I threw plenty of lead through with no issues. I'd still have it but some a holes figured they needed my guns worse than me. So I have bought another which is a Rock Rivers Arms. It came built with everything I wanted except for the optics. My Bushmaster was a $550 gun and the RRA was a $1200. Now the Bushmaster I put probably another $200 changing stocks and what not. Then another $370 for and eotech optics. I have put the eotech with magnifier on my RRA. At the end of the day spend what you are comfortable with. An AR can always be upgraded later, buy plenty of mags, try not to get corrosive ammo cause it's cheap. Make sure to get the AR that's chambered for .223 and 5.56. I'd also get the .458 socom before the 300 blackout. The 458 is a door buster from hêll!!! My next big boy gun will be a .338 Lapua, I want to reach out and touch someone!!!! Remember good optics aren't cheap.
    doveman1
    Re: AR15 2017/10/07 19:33:12 (permalink)
    They say Diamondbacks are so cheap because they do all the machining in house, don't send it off to 3rd party.
    I'm not a range guy, usually if I'm shooting, I'm shooting at something I want to kill. So this thing won't get shot hardly at all.
    Really just need to know about a more tactical optic that would still let me use iron sights.
    I just don't really know much about these things.
    You keep trying to get me to buy a 458! You're gonna be responsible if I did and that thing knocked me out of the deer stand!!
    2in HL lift
    Jeepwm69
    Re: AR15 2017/10/09 15:06:46 (permalink)
    Look at PSA (Palmetto State Armory)
    Don't get a 300 BLK unless you plan on getting a suppressor.  Useless cartridge for anything other than shooting suppressed.
    If you're really on a tight budget, pick up an Anderson Arms stripped lower for $40-50, and buy a kit for the rest.  The lower is the "gun" and the rest are just parts that you can order online.  You will have to get the stripped lower from a dealer or find a private seller with one.  The lower is legally considered the gun (like the frame on most guns) so that's the only part that you can't order online.
    Top ends come already assembled and headspaced, so they just pin in place.
    Lower assemblies are like legos for adults.  https://www.ar15.com/forums/ar-15/Build-It-Yourself/4/
    Re: AR15 2017/10/16 19:35:41 (permalink)
    Ok Doveman what r u gonna get?!?!?!?!
    doveman1
    Re: AR15 2017/10/16 22:32:51 (permalink)
    Thinking one listed above but in 5.56.
    Still stuck on optics. But I haven't really looked.
    2in HL lift
    Re: AR15 2017/10/17 14:31:57 (permalink)
    Cool. Remember good optics will cost nearly as much or more than the gun itself.
    doveman1
    Re: AR15 2017/10/17 18:26:33 (permalink)
    Looking at the trijicon MRO for a close range set up
    2in HL lift
    Re: AR15 2017/10/17 20:52:52 (permalink)
    Yea that's a good one. I had eotech now I want an acog.
    doveman1
    Re: AR15 2017/10/17 22:00:22 (permalink)
    I do too! Why don't you buy 2 and I'll field test the other one for a while.
    2in HL lift
    Re: AR15 2017/10/17 22:35:15 (permalink)
    HAHAHA heck I'll be lucky if I can afford the mount for one after my house gets finished!!!!
    Monkey
    Re: AR15 2017/10/26 19:44:55 (permalink)
    Build it.
    09 420 IRS
    snorkeled
    racked rad
    epi economy clutch kit
    40% primary reduction
    32% secondary reduction
    gorilla stage 1 lift
    wheel spacers
    29.5 laws
    detroit gearless locker
    hmf performance series
    Gorilla axles
    spring spacers
    09 420 sra
    A cup of hot coffee ain't got
    nothin on a cold toilet seat :)
    Re: AR15 2017/10/26 19:57:45 (permalink)
    Monkey I bet if you built him one he'd take it!!!!!
    doveman1
    Re: AR15 2017/10/26 20:22:36 (permalink)
    I have 2 big issues with everything in my life- no money and no time lol
    2in HL lift
    Re: AR15 2017/10/26 20:48:35 (permalink)
    Know the feeling Doveman!!!
    doveman1
    Re: AR15 2017/12/05 06:57:26 (permalink)
    Got an idea on a build I’m going to do at the beginning of the year, waiting on my Yearly bonus and that Christmas money to start rolling in.
    What are y’all opions on long range scopes? Seems Burris and Vortex are the hot topic right now but I don’t know.
    2in HL lift
    Re: AR15 2017/12/05 07:16:35 (permalink)
    Like sniper long range?
    doveman1
    Re: AR15 2017/12/05 11:51:25 (permalink)
    1000 yards or so. Majority would be around 500 or less, but it's always nice to have the capability
    2in HL lift
    Re: AR15 2017/12/05 11:59:41 (permalink)
    Ok so what caliber ar you going with?
    #19
    doveman1
    Re: AR15 2017/12/05 12:04:16 (permalink)
    6.5 Creedmoor. I want an ar with a little muscle that’s still practical. As far as this one goes on sights want a good scope but still going to put iron sights on a 45 degree angle in case I need to John Wick some hogs in an emergency lol.
    I don’t plan to hunt at long distances but still fun to shoot steel far off. I don’t shoot a lot either so I’m not worried about the 6.5 eating away my barrel like they’ve been known to do.
    Still planning on building the 5.56 diamondback as stated earlier as a tactical set up but I’ve been watching too many videos of people shooting long range and I want some of it lol.
    post edited by doveman1 - 2017/12/05 12:22:14
    2in HL lift
    #20
    Re: AR15 2017/12/05 14:37:01 (permalink)
    Well vortex is good. Nikon has good scopes. Leopold uses Nikon optics FYI. Millet scopes make some long range that won't break the bank. You went the rifle type ar with the 18 plus barrel? Sometimes if you look hard you can find some good deals with people constantly getting in and out of long range shooting. One day I will have my ar-10 in a .338 Lapua !!!
    #21
    doveman1
    Re: AR15 2017/12/05 15:47:33 (permalink)
    I was looking at Millet but I’ve never heard of them and there were some questionable reviews of them on Optics Planet, but who knows.
    Here’s what I’m going with. seems people are liking it and can’t beat the price
    http://www.savagearms.com..earms/model/msr10hunter
    2in HL lift
    #22
    Re: AR15 2017/12/05 16:21:05 (permalink)
    Yea that's I pretty nice setup. Yea I seen that too on the Millet scopes.
    #23
    doveman1
    Re: AR15 2017/12/10 13:48:41 (permalink)
    Went to academy today and they had one on the shelf for $1299... was contemplating if missing one month on my house payment and no phone would be worth it. Lol
    I'm looking pretty hard to find good looking Christmas presents that are cheap so I can keep some of my money lol
    2in HL lift
    #24
    Re: AR15 2017/12/10 14:52:15 (permalink)
    Oh if you look on the net long enough you can find the deals. Slickdeals is a good site and Gosale.com is a very good item search engine.
    #25
    Jeepwm69
    Re: AR15 2017/12/12 11:25:49 (permalink)
    Palmetto State Armory is about the cheapest place to get decent AR stuff now.
    J&T distributing has quality stuff.
    #26
    BUSHHOG
    Employee
    Re: AR15 2017/12/12 12:11:48 (permalink)
    Remember this basic rifle truth. A rifle is only as good as the scope mounted on it. Don't short change yourself on optics.
    Dan Doughty
    #27
    Re: AR15 2017/12/13 07:06:06 (permalink)
    Very true Bushhog. Good optics always cost as much as the gun itself or more.
    #28
    doveman1
    Re: AR15 2017/12/24 19:34:49 (permalink)
    So uh picked up my Savage tonight. Academy had it marked down a $100. So I paid just hair over $1200. Went to the ammo and they were completely out of 6.5 so I can't even shoot the dang thing.
    As far as optics go I think I've decided on going with a Vortex Diamondback tactical. It's kind of in their mid quality of scopes and for the price it'll do everything I need it to do. Really wanting to upgrade to thermal eventually. What are your thoughts on 3-9x40 or 4-12x40? I'm not dead set on this scope I'm still looking but it's an option.
    2in HL lift
    #29
    Re: AR15 2017/12/24 19:38:55 (permalink)
    Merry Christmas Doveman!!!
    #30
