Locked99 Polaris 500 stuck in low, cant shift
Schooner Tuner
2010/09/22 16:15:07 (permalink)
I just bought a 99 polaris 500 and I test drove it before I bought it and it was running and shifting fine, next day went to pick up and got it loaded into back of truck just fine and it was shifting in all gears just fine, got it home and it wont go to neutral, high or reverse. It seems like its stuck in low at all times, moved the shifter in the neutral position and started motor and hit throttle and it still was in drive. I adjusted idle, what can it be?
12 Replies Related Threads
    01mudslinginh.o.
    Re:99 Polaris 500 stuck in low, cant shift 2010/09/22 16:36:51 (permalink)
    clutches maybe out of alignment maybe have play in the linkage mine does that when it is time to change the belt you may have damage to the sheves of your clutches there maybe damage inside the transmission you may have a broken motor mount i would start with the easiest stuff to look at first and go from there
    2001 Sportsman 500 H.O.
    28" zilla's wrapped around ss108's
    HSP slip on
    EPI clutch kit
    EPI HD Springs
    UNI fliter
    2" Spring spacers
    Warn winch
    Water temp. gauge
    Hope for the best plan for the worse
    Poor planning or judgement on your part does not constitute an emergency on my part
    Schooner Tuner
    Re:99 Polaris 500 stuck in low, cant shift 2010/09/22 16:48:51 (permalink)
    Thanks!
    Schooner Tuner
    Re:99 Polaris 500 stuck in low, cant shift 2010/09/22 17:00:02 (permalink)
    Could water get in the transmission case and cause it to not shift? If so, where is the drain plug?
    southernmudder1
    Re:99 Polaris 500 stuck in low, cant shift 2010/09/22 18:22:25 (permalink)
    i had the same problem, check the shifter and hopefully thats it, otherwise your going to b e rebuilding a transmission or paying to have one rebuilt. i thing mine was estimated a $1000 to rebuild the transmission at a dealer.
    My baby: 2013 Polaris 900 XP
    '07 Honda Rancher 420 ES
    2010 Honda Big Red Camo
    2004 Bombardier Traxter Max
    Sold '03 Polaris Sportsman 500 H.O.
    jeff
    Re:99 Polaris 500 stuck in low, cant shift 2010/09/24 11:59:04 (permalink)
    Its very common on a older sportsmans.  The shifter gets wear in it and will try to hang between two gears.  Usually a little pulling on the linkage or a pry bar to pop one of the rails back into position will have you going again.
    14' RZR XP1K Titanium, 5" Lift, 32.5 Laws on M20's, personalized.
    05' Sportsman 800, 6" Gorilla, 31" Laws and a radio.
    01' YAMAHA IRS Wolvy, Someday maybe I will finish it, maybe not.
    Schooner Tuner
    Re:99 Polaris 500 stuck in low, cant shift 2010/09/25 18:18:14 (permalink)
    Could it just be a bad belt? I pulled the clutch cover off and I took the belt off with little to no effort. Is it supposed to be that easy? I also put it back on with no effort.
    lxman88
    Re:99 Polaris 500 stuck in low, cant shift 2010/09/25 19:50:38 (permalink)
    are the sides of the belt all aight up or kina burnt looking like the clutch has been slipping on the belt ?
    2006 sportsman 800 efi
    9 inch lift all gorilla axles
    gorilla prop shaft
    customs built speaker box with snorks
    bigger injectors
    viper #4500 winch
    heated hand grips
    29.5 outlaw2s on crushlocks
    gear reduction
    epi clutch kit
    blue metallic painted frame and silver a arms
    stainless steel air box
    2013 sportsman 800
    bone stock not for long
    Schooner Tuner
    Re:99 Polaris 500 stuck in low, cant shift 2010/09/26 11:42:57 (permalink)
    not ate up but kinda burnt looking and shinny like its been wearing on it, also the belt has alot of cracks in it
    HDsilverado
    Re:99 Polaris 500 stuck in low, cant shift 2010/09/26 13:54:11 (permalink)
    You might as well go ahead and put a belt on it while its tore down..   Did you look at the linkage and the shifter?
    2012 Camo 1000XT
    BRP Snorkle Kit
    Full HMF Swamp Series
    HMF Optimizer
    Dalton Clutch kit
    1.75 spring spacers
    Fan override switch
    29.5 OL2's S/W on SS 212's
    30" Zilla's on Black SS108's
    RAM cupholder
    2012 Sportsman 500
    1987 Foreman 350D all original
    2011 F350 CC 6.7L
    Previously Owned:
    2010 Camo Outty 800r
    09 Browning 850XP
    08 Camo 750 Teryx Camo
    07 Camo Rhino 660
    06 Camo Brute 750i
    05 Camo Grizz 660
    http://community.webshots.com/user/hdsilverado
    lxman88
    Re:99 Polaris 500 stuck in low, cant shift 2010/09/26 14:47:49 (permalink)
    for sure you need a new belt but i dought thats why it wont shift
    gorilla prop shaft
    bigger injectors
    viper #4500 winch
    heated hand grips
    gear reduction
    epi clutch kit
    2013 sportsman 800
    Schooner Tuner
    Re:99 Polaris 500 stuck in low, cant shift 2010/09/26 15:41:55 (permalink)
    linkage is fine and shifter is fine, getting a new belt and going to rebuild the clutches, hopefully that'll work, thanks
    01mudslinginh.o.
    Re:99 Polaris 500 stuck in low, cant shift 2010/09/26 21:16:58 (permalink)
    i would put the new belt on and see if that works before i rebuilt the clutchs my clutch was cracked from years of hard ridin and it cost me over 400 dollars for a new one and it is goin to cost some where between 300 and 350 to rebuild it i wouldnt mess with the rebuilding it if i didnt have to it was a pain in my butt to get it off just in case you didnt know if u squeeze the belt between the primary and secondary clutches it will loosen the belt up and it makes it easier to get it on and off
    post edited by 01mudslinginh.o. - 2010/09/26 21:19:31
    HSP slip on
    EPI clutch kit
    EPI HD Springs
    UNI fliter
    2" Spring spacers
    Warn winch
    Water temp. gauge
