Locked93 yamaha big bear 350 rear diff
dummernastump
2009/10/23 22:57:08 (permalink)
gentlemen,
    i am new to this forum and would greatly appreciate your help/experience. as stated in the subject line, i have a 93 yamaha big bear 350 (bone stock) bought for a song in tn.  I moved to nc. in 2007 and having no place to store my toys (74 cj5 and 93 bb) i took them to my in-laws for safe keeping. 6 months later my wife's nephew reluctantly informs me that the rear diff of my atv is tore up. he doesn't know a thing about an atv, but he proceeds to tear mine down. I am going up in december to get my toys, before anything else bad can happen. my question is what is the most likely failure in the rear diff and ballpark figure for repair/replacement.
8 Replies Related Threads
    chrisb76
    Re:93 yamaha big bear 350 rear diff 2009/10/23 23:08:48 (permalink)
    it really depends on what it was doing before he tore it down it could be a few different things or one thing.the gears could be chewed up,the axle could be stripped.thats the main 2 things that go out in a rear end.both can be fixed for a little bit of nothing if you shop smart.this is a pretty good site to find parts,but you'd be better getting used parts off ebay.
    old school kodiak
    6''lift,brute diffs.,gorilla's
    big ol' piston
    lots of balls
    TEAM ALL JACKED UP
    dummernastump
    Re:93 yamaha big bear 350 rear diff 2009/10/24 03:48:14 (permalink)
    thanks for the info, and i'll do that. I have a couple of atv salvage yards here that i will also check out.
    ObsessedATVr
    Dirt Monster
    Re:93 yamaha big bear 350 rear diff 2009/10/24 08:14:41 (permalink)
    yea I just had my axle go out on a 96 Kodiak...got a rear diff for 150 and an axle for 120....I could have just repaced the rng and pinions gears but they are just as expensive to replace as buying a used diff...but good luck with it all!
    Work in progress
    1996 Kodiak 400
    2001 Bear Tracker 250
    leed1315
    Re:93 yamaha big bear 350 rear diff 2009/10/26 21:34:08 (permalink)
    ring and pinion or worn out axle splines or both. That model is not that cheap to find parts for. You will be able to use the 88-95 but they can sometimes be hard to find. I looked and didn't see any on ebay. If the stuff is bad your only real option is to be patient and wait for good used parts. The rear axle and diff for those new will cost you probably upwards of $1000. The axle alone on bikebandit.com is $643 and thy don't show that they still carry  the rear diff.
    Bikes
    07 400 Big Bear
    08 650 Prowler
    09 Polaris Sportsman 90
     I part bikes out on the side and have between 40-50 bikes on average. Feel free to ask me about parts if you need something.
    chrisb76
    Re:93 yamaha big bear 350 rear diff 2009/10/26 22:12:26 (permalink)
    i'm thinking the kodiaks from early 90's-'99 have the same rear ends as the old big bear before '96.
    old school kodiak
    big ol' piston
    lots of balls
    TEAM ALL JACKED UP
    leed1315
    Re:93 yamaha big bear 350 rear diff 2009/10/27 10:02:46 (permalink)
    No actually they don't. They have the same as the 96+ big bear. The Kodiak started in 93 I know the 96 plus have the same as the 96 plus biug bear and from what I can tell and the 94 that I have parted out the 93-95 have the same axle and diff is the 96+
    Bikes
    07 400 Big Bear
    08 650 Prowler
    Fredilyin
    Re:93 yamaha big bear 350 rear diff 2013/05/30 09:29:54 (permalink)
    Which way does the axle come out in the rear of 1990 Yamaha big bear. If looking from the rear... The two lock nuts are off ... I bagged from both sides and no luck..... HELP please
    Fred
    PRESIDENTAIL GRIZZ
    Re:93 yamaha big bear 350 rear diff 2013/05/31 11:12:13 (permalink)
    Knock the threads thru the diff. The nuts are ther to hold it from going through the diff. Should be a big washer also?
    2014 RZR1000 Nuclear orange (his)
    33 Terms  on 15" MSA 21
    5" lift
    Lights
    Radio
    08 RZR sold
    09 MUD PRO (HERS)
    2.5 RDC LIFT
    32 BACKS
    TUNES
    BLACK & PINK
    PINK LEDS
    ~BIONIC REDNECKS~
