90 big bear 350 with 400 crank any body done it
Waynesys
2018/01/19 21:02:00 (permalink)
As the title says has any body actually taken a crankshaft from a big bear 400 or kodiak 400 and put it in a big bear 350 ive read all kinds of post about people saying it's possible but nobody that has actually done it
post edited by Waynesys - 2018/01/19 21:05:25
3 Replies Related Threads
    Re: 90 big bear 350 with 400 crank any body done it 2018/01/20 18:11:44 (permalink)
    Ok first why are you wanting to do this? Time to freshen up the motor? Want more power? Are something different? The cranks themselves are the same but it's the stroke that's the problem. 400 = 71.5mm and the 350 = 64.5mm.
    Waynesys
    Re: 90 big bear 350 with 400 crank any body done it 2018/01/20 22:12:27 (permalink)
    Well more power and I already have a crankshaft and rod from a storage buy from a 95 kodiak,as im told. My bb 350 is a 90. I know if it does work and I decide to do it I will also need a new cylinder and timing chain from said kodiak. Just seeing if anybody has actually done this before. Most posts I read just used a kit from hotrods or **** but im not inclined to spend 500+ for a little extra power when I can use used parts for less to get the same results
    Re: 90 big bear 350 with 400 crank any body done it 2018/01/20 22:38:33 (permalink)
    Well they both use the same piston which is an 83mm and knowing pump gas at 11:1 compression is about max. So I don't see anymore gains trying to use all 400 parts. So if it was me I'd just bore up on the stock setup since the 400 is basically the same as the 350.
