Locked850 xp do i got enough to turn 3wides or go skinny wide
kellyp338
2012/05/26 10:51:17 (permalink)
Should i. get. skinny wide ....or all wides
17 Replies Related Threads
    Eleshufan
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/26 12:46:27 (permalink)
    Hmmmm. You should go all wide unless your running that tire. Then I would go skinny wide. The size should be right as long as you stick with what you need. You may need a lift if you go with a size bigger than that. Without the lift just do one wide, one skinny, and a couple Mombas. Thats really all I can say with the info given.  Hope this helps.
    2011 Polaris Sportsman 550xp
    Tires - 30" Backs (All Skinny)
    Wheels - MSA Crushers
    Exhaust - Loony Tuned
    Clutching - QSC
    (Just getting started)
    WeGetOurs
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/26 17:12:14 (permalink)
    HAHAHAHAHAHAHHHAHAHAHAH...lmfao
    one big ol' foreman
    and one little ol' 300
    05rancher3502wd
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/26 18:34:17 (permalink)
    post edited by 05rancher3502wd - 2012/05/26 19:51:29
    rajunxcajun55
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/26 19:40:02 (permalink)
    I run the 3 wide 1 skinny setup myself, all I had to do was add a k&n filter and it turned them great! But only in reverse :(
    1996 Honda Foreman 400
    450 suspension, 30" silverbacks, 2" wheel spacers, glasspack, snorkel, uni airfilter, light bar, custom system, big ole yeti, LEDs, start in gear mod, reverse lever delete, motor work, ect.
    Gone
    2008 Rancher 420
    2006 Brute 750
    2003 Grizzly 660
    2001 Rancher 350
    2004 300ex
    WeGetOurs
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/27 18:06:18 (permalink)
    Yea if you ride a Honda only 3 wheels pull anyway so mine as well save you some money and go with the 3 wides and one stock tire.
    one big ol' foreman
    kellyp338
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/27 23:19:49 (permalink)
    MEANT TO TYPE 31 INCH OUTLAW WIDES SHOULD I PUT WIDES OR SKINNY ON FRONT
    madppcs
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/28 03:09:31 (permalink)
    Lmao.
    Jason Kniesche
    Team Anytinggoes
    2010 Dodge Cummins (Mega Cab) Lifted, Modded, Deleted.
    12' Outlander Catvos XMR
    10' Outlander 800 XT-P
    2011 RZR XP900 LE (White Lightining)
    Gone but never forgotten:
    07 Outty 500
    09 Renegade 800
    80(ish) Suzuki 230
    J_Fred
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/29 18:29:57 (permalink)
    With the 850 you will be okay with any tire on the market.   I'm assuming you want a tire for mud, and other things are not so important to you (tread life/wear, ride, driving ability, etc...)
    I would initially suggest the Outlaw 2's over the 31's.  Then I would suggest 30 inch Silverbacks and/or Moto Monsters (effectively the same tire).  The 31 Outlaws, while being a smooth riding tire, don't clean out well at all compared to other 29-31 inch mud tires.   You will get more mud performance by going down to the 29.5 and 30 inch pure mud tires.
    However, if your mind is already made up on 31's (and they aren't a bad tire, just not as good in the mud as some others), I would suggest the 31x11's, as more tire will always net you more traction.  This evens the weight of the ATV and disperses it over more area, keeping you from sinking down as fast as if you had skinny 31's.
    Arctic Cat 650 V2
    RZR 800
    31 Outlaws, Highlifter Lift
    ProShopCustoms
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/29 18:34:32 (permalink)
    kelly i thought you were gettin some more of those "crappy ol2's"?????
    1994 Honda TreeHunnit 2 wheel pull
    Swamp Starz✯
    Past Rides: 99 Honda 300 4x4, 08 Sportsman 800, 08 RZR 800, 07 Can-Am 400ish, 07 Ranger 700xp, 2001 Quadrunner 500 4x4, 2010 Sportsman 550xp
    Hondaowner994
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/29 18:51:58 (permalink)
    WeGetOurs
    How do you figure the stock tire would turn and the other tire wouldnt because the stock has less traction, better off wraping a chain around a bare rim and chaining it to the a arm
     x-Sam's Towing-x
    "Just try and follow me, see how well that works out for you"
    If you don't have time to do it right, then you must have time to do it over.
    "Ol' Red"
    -1996 Honda Fourtrax 300 4x4-
    -27x10 Vamps Up Front-
    -26x12 Vamps In The Back
    -UNI Filter-
    -Cup Holder-
    -2000LB Winch-
    -2" Lift-
    -1" Spring Spacers-
    -Fully Snorkeled-
    -Rear Brake Delete-
    -Ammo Cans-
    -Front Brake Delete-
    -Audio tube-
    -EBC Dirt Racer Clutch Kit-
    -Extra Lights-
    -Bored .40 Over-
    kellyp338
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/29 20:16:16 (permalink)
    A 30 INCH SILVERBACK IS BETTER THAN OUTLAW 31 ?  I WILL HAVE A SET OF OL 2 S BUT THEY ARE NOT GOING TO BE READY FOR A WHILE ...NEED SOMETHING TO GET ME BY IN THE MEANTIME ALWAYS WANTED TO TRY 31 S....I GETTING AIRDAM CLUTCH IT SHOULD BE HERE IN A FEW DAYS CAN T WAIT
    Georgia Boy
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/30 09:45:23 (permalink)
    32's
    POWERED BY TIGER BLOOD
    A Huffy built to the max
    13 ranger 900
    Honda_PWNS
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/30 10:26:47 (permalink)
    Georgia Boy
    32's
    Enough said
    Foreman 500ish
    32.Five mambas coming soon!
    2011 Gade
    Dirty2s
    6mill stroker
    bla bla bla its fast
    Team Viagra...We play hard all day
    (I'm drunk and I'm proud of it!)
    WeGetOurs
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/30 11:49:12 (permalink)
    Hondaowner.... Just a joke man
    one big ol' foreman
    J_Fred
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/30 20:51:11 (permalink)
    kellyp338
    hmmm....  In mud, cleaning out and possibly climbing I would argue this to be a true statement.
    Arctic Cat 650 V2
    RZR 800
    reljp10
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/05/30 22:16:30 (permalink)
    32s
    09 850 xp
    CATVOS 3" Raked
    Viper Elite 4000#
    HL Springs
    Big gun Evo Full
    30-378
    Re:850 xp do i got enough to turn 3wides or go skinny wide 2012/06/04 00:25:03 (permalink)
    26's would do you right
    2012 850HO XP EPS Orange Madness LE
    Outkast 5"/2"   |  34" Terminators  | 15" Vision Lock Out  |   /// Airdam CVTech w/ Ranger Belt  | Custom Center Snorkel | Radiator Relocated  | HL Springs  | 1" Spring Spacers  |  Gorilla Axles  |  Full Ricochet Armor | Looney Tuned Exhaust  |  12" Light Bar  |  GURU Bumpers  |  ODI Grips
    Southern Mudd Junkies
    YouTube page:
    http://www.youtube.com/us...lson1986?feature=guide[font="ti
    Team SOLO YouTube page: http://www.youtube.com/user/30378AR?feature=watch
