Hot!8 vs 10 inch wide front tires
mustangstephen
2017/12/26 17:17:30 (permalink)
Looking at maxxis mud bugs front tires and see they're available in 8 or 10 inch wide. Trying to decide which to go with.
Riding is any "trail" we can find. If it fits we'll try to ride up/down it. Washouts, gully, etc. Fairly regular mud/water. Lots of gravel bottoms.
4 wheeler is an old school ac 250 with the high low and stupid low. Rear tires are 27x12x12 gators. Replacing the 3.1 front dif with a 3.6 so need 27" fronts.
I'm also open to other tire recommendations but bugs are in the budget and I know exactly what to expect from them aside from what width.
15 Replies Related Threads
    doveman1
    Re: 8 vs 10 inch wide front tires 2017/12/26 17:47:44 (permalink)
    You'll be fine with either or.
    There's so many tire options out now days pick one you can afford and you're happy with and run with it.
    Green 2015 Grizzly 700
    2in HL lift
    N2deep battery relocation
    Wild boar radiator relocation
    Jeepwm69
    Re: 8 vs 10 inch wide front tires 2017/12/27 10:44:58 (permalink)
    I've got 10 wide Bugs on the front on my Foreman, my buddy has 8 wides on his.  Both are running 12" rears.  His is a little easier to steer.  I'd get the 8 wides unless you plan on riding in a lot of soupy mud where the flotation would help.
    The gator tread pattern is almost the same as the Bugs, so it should look good.
    mustangstephen
    Re: 8 vs 10 inch wide front tires 2017/12/27 11:01:35 (permalink)
    That's kinda where I'm at. I figure the 8s will definitely turn better but is there any other performance advantage with the 10s. There's a little soupy mud but I can't turn anything fast anyways.
    Do the 10s do any or much better climbing/ pulling?
    BUSHHOG
    Employee
    Re: 8 vs 10 inch wide front tires 2017/12/27 11:18:33 (permalink)
    post edited by BUSHHOG - 2017/12/27 11:26:05
    Dan Doughty
    BUSHHOG
    Employee
    Re: 8 vs 10 inch wide front tires 2017/12/27 11:23:53 (permalink)
    Don't give your front tire any more thoughts. Go with the 10". It's a no brainier. The 10" will give you more tread to the ground in 4x4 mode. More tread equals more traction and or flotation regardless of the surface.
    Dan Doughty
    Re: 8 vs 10 inch wide front tires 2017/12/27 15:10:07 (permalink)
    Yea I'd agree with Dan. More surface contact equals better pulling, climbing and stability. The 8's of course will steer the best but lack in surface contact. So at the end of the day it's all up to you. I been running big tires on my 300 Honda forever so double handing one side of the handlebars to turn sharp is just a normal day on the trails for me.
    mustangstephen
    Re: 8 vs 10 inch wide front tires 2017/12/27 19:44:07 (permalink)
    Thanks for the replys Bushhog and nutt. That's kinda been my mentality just wanted to make sure it was worth it.
    Re: 8 vs 10 inch wide front tires 2017/12/27 20:13:43 (permalink)
    No problem and come back anytime.
    mustangstephen
    Re: 8 vs 10 inch wide front tires 2018/01/26 19:10:53 (permalink)
    Got them on this week finally. Realized after posting this that the gators up front were 10" wide so got the 10" wide bugs. And they're an inch wider than the gators. 500 was a parts quad I got running. It's on 26" gators. Little musical tires but it was worth it.
    And without further delay pics of the 250 and 500.
    post edited by mustangstephen - 2018/01/26 19:21:18
    Re: 8 vs 10 inch wide front tires 2018/01/26 20:00:09 (permalink)
    Yea booooyyyyy those old Kitty's looking good!!!!
    mustangstephen
    Re: 8 vs 10 inch wide front tires 2018/01/26 20:51:38 (permalink)
    Thanks. The 500 was a $60 parts quad purchase. Made the mistake of squirting some b12 down the intake boot and pulling the pull rope. Motor hit about 6 times on that. Kept turning wrenches and it just snowballed from there. Hardest part was convincing the wife she was getting an upgrade from her 350 big bear and that i needed another parts quad. Luckily I found one without a motor (for twice what i paid for the 500) so there was no chance on me getting it running... and I finally got to do the 3.6 front dif swap I originally intended to do.
    So far I'm liking the 500 but I'm completely new to this engine. Anything i need to educate myself on with it?
    Re: 8 vs 10 inch wide front tires 2018/01/26 21:05:20 (permalink)
    You did good. Man Everytime I have worked on them was always the normal bearings in the rear and CV shafts and brake calipers. Besides that they always been pretty solid bikes.
    post edited by 00_NUTT - 2018/01/26 21:08:13
    mustangstephen
    Re: 8 vs 10 inch wide front tires 2018/01/27 09:40:55 (permalink)
    Good to know. Thanks.
    Re: 8 vs 10 inch wide front tires 2018/01/27 09:46:12 (permalink)
    No problem homie.
    mac102004
    Re: 8 vs 10 inch wide front tires 2018/01/30 20:15:37 (permalink)
    Looks good. Nice to see some old cats still going.
    2016 Renegade XMR on 31x11's
    2015 Honda Rubicon on 30" SB's
    1996 Honda 300 4x4
    1994 Honda 300 4x4
    2015 Ram 3500 CTD (Grocery Getter)
