Locked660 wiring schematic
etexemt
2007/04/01 15:41:07 (permalink)
Does anyone out there have the wiring schematic for the 660? This is a continuation to the post "Need some serious help"... I have tracked down the short to the fuse labeled "ignition" now I just need to find out where that lead goes.. If anyone has anything I would appreciate it...
J. Young
06 Yamaha Grizzly 660
ITP Delta Series Black Wheels
26" Swamp Witch Tires
Warn 2.5i
4 Replies Related Threads
    whygriz
    RE: 660 wiring schematic 2007/04/01 16:19:43 (permalink)
    [8D] I BOUGHT A CD ROM OFF EBAY FOR 10$ AND IT HAS IT ON IT, ITS A SERVICE MANUAL LIKE THE DEALER HAS, ITS WORTH THE $10[sm=143.gif]
    "THE WIRES MAKE THE FIRES"..LINEMAN CREED
    03'green grizzly,mostly stock,upgrades inc.k-n air filter,26in bearclaws,driving lites,moose hand guards,ramsey 2500lb winch, custom made rear hitch,moose front&rear bags,moose c-v & skids throughout!!reverse & diff-lock overides,heated grips (wife) 04' kodiak 400,jr lt 80, lil sis eton 90
    WillyD2114
    RE: 660 wiring schematic 2007/04/01 19:07:24 (permalink)
    I've got the paper service manual and it has all you could ever need to know in it.... It's well worth the cost.  I ordered mine off yamahas website.  Cost more than the CD ROM but I can have it beside the bike with me when I'm working on it and look at it.  Might find the paper copy on ebay or somewhere cheaper though. I think I paid 40 bucks for mine and I'm sure you could find it cheaper but I think its been well worth the 40.
    mud_dog450
    RE: 660 wiring schematic 2007/04/01 20:22:00 (permalink)
    Disconnect the negative battery wire. Then...
    Disconnect the electrical connecter that plugs into the starter relay.  The bottom left terminal on the connector (Blue/White wire) goes to the CDI box so when you hit the start button the CDI sends voltage through the Blue/White wire to the starter relay which energizes it.  Well, it doesn't sound like the voltage is getting to the relay, instead it is grounding before it gets there which is blowing the fuse.
    Grab an OHM meter and put one lead on the Blue/White wire terminal on the connector and the other lead to the ground wire that goes to the battery.  The OHM meter should read OL or Infinite.  If it has a reading, then the Blue/White wire that goes from the CDI box to the start relay has shorted to ground.
    If it has, then you need to find where and fix it.  Start by looking where the wires bend around the frame and such.  [;)]
    post edited by mud_dog450 - 2007/04/01 20:37:14
    The Mud Brothers
    Goin' Deep Since 2004!
    02 Grizz 660...umm...7??
    Everything Snorkeled
    Clutch Work
    29.5 Laws on Vision Buckshots
    Muddin Videos
    Angus
    RE: 660 wiring schematic 2007/04/02 09:53:14 (permalink)
    2002 660 wiring diagram.
    Attached Image(s)
    • 2005 Yamaha Kodiak 450
    • 2005 Toyota Tacoma DC SR5
