Locked650 Rincon rear axle removal HELP
leed1315
2010/03/18 18:56:39 (permalink)
I have a rear differential that I'm trying to get the axles out of to sell to a member on here and i can't get them out. My question is, is there something special to removing axles from the rear diff on a Rincon. I don't need the response just jerk on them. I have tied the diff to a post at my dads shed and hooked my truck to it and have ben breaking wires and tie straps just jerking on it, and i have parted out many bikes and never had one like this. I have already broke one axle at the cup by trying to drive wedges beside it.
Bikes
07 400 Big Bear
08 650 Prowler
09 Polaris Sportsman 90
 I part bikes out on the side and have between 40-50 bikes on average. Feel free to ask me about parts if you need something.
9 Replies Related Threads
    gmcz71
    Re:650 Rincon rear axle removal HELP 2010/03/18 19:20:45 (permalink)
    RINMAN
    Re:650 Rincon rear axle removal HELP 2010/03/20 11:25:28 (permalink)
    There is a snap ring on the inside.  you need to place a pry bar between cv and the diff GENTLY PRY and then a pry bar between the bottom of frame and cv and bounce the bottom pry bar and then the other pry gently and all this while slowly spinning the opposite tire so the axle spins..  all your trying to do find the small gap in the snap ring and it will pop right out. hope this helps.
    08 RINCON
    28" ZILLAS
    26" MUDZILLAS
    2003 RINCON ( SOLD )
    UNI FILTER
    3'' RD LIFT
    JET KIT 170 MAIN
    27" MUDZILLAS
    30" MUDLITE XXLS
    MBRP EXHAUST
    TRD GEAR REDUCTION
    TOASTY A** HANDWARMERS
    Talkn_Wolf
    Re:650 Rincon rear axle removal HELP 2010/03/20 13:53:03 (permalink)
    I had this same problem, i had to leave for work and my dad messed with it he ended up busting the diff around the seal which some jb weld will fix but it also broke the gear in half that the axles run in... the opposite side ended up coming out with a single tap from a hammer bolt through the inside of the diff... try and get a slide hammer and get it clamped on there some how
    04 Rincon 650
    06 Rhino 660
    09 Brute 750 - Sold
    78 CJ7 Golden Eagle - Sold
    mac102004
    Re:650 Rincon rear axle removal HELP 2010/03/20 18:07:03 (permalink)
    Good luck. I could never get mine out, they got seized in the differential. Any time I had to remove an axle I would dismantle the inboard CV joint and leave the cup in the diff.
    2016 Renegade XMR on 31x11's
    2015 Honda Rubicon on 30" SB's
    1996 Honda 300 4x4
    1994 Honda 300 4x4
    2015 Ram 3500 CTD (Grocery Getter)
    CJ_rincon03
    Re:650 Rincon rear axle removal HELP 2010/03/20 20:15:28 (permalink)
    ok everyone, i was having the same difficulties this past week.  the post from gmc was from my thread, i had the most difficult time getting it out, what i ended up doing was dropping the subframe and completely pulling the rearend out and taking it to a local shop who  put it in a vise and spot welded a slide hammer to the axle cup and wham, one or two whacks and out, the other side i used  a 1/2" socket and extension as a punch, sprayed a small amount of wd40 and whack it came out in about 3 smacks.   when pulling out the axle do not pry on the diff, i did and i had to buy a new left side rearend housing and oil seal, (put it together this morning)   what you are trying to accomplish is a sudden jerk on the axle to pull the keeper ring out of the splines of the center of the ring gear.  i hope this helps, the shop only charged me 20 bucks so it was well worth it,
    '03 HONDA RINCON
    27x11x12 ITP Mega Mayhems. 2" LIFT + HL Lift springs
    Bluetooth Audiotube - SATV axles.-bed lined racks and custom paint. Handful of homemade goodies.
    04' Honda recon
    Bikes: 07' CRF100f & 70f:: 95' Kdx 200::03' YZ450F
    SOLD , NOT FORGOTTEN.
    '87 HONDA ATC250 BIG RED !03' rancher 350 '84 200m '84 250sx 81' atc250r 03' 250ex 83' DT100
    ________________
    C.J.
    "willjumper-
    Nah, we dont need brakes. We have "IM COMING IN HOT! *downshift downshift downshift neutral reverse*"
    ^lol.
    CJ_rincon03
    Re:650 Rincon rear axle removal HELP 2010/03/20 20:21:17 (permalink)
    Oh and by the way, on r i n c o n riders . c o m (no spaces) i posted a thread about this and the guys were very well informed and very helpful, obviously by the title the site is dedicated to rincons, so if you own one, and  by chance you cannot find an answer on here about it , surely it will be on the other forum, nothing at all against highlifter,  but that site is just specialized to help rincon owners.
    '03 HONDA RINCON
    04' Honda recon
    ________________
    C.J.
    "willjumper-
    ^lol.
    Guest
    • Status: online
    Re:650 Rincon rear axle removal HELP 2010/03/20 21:04:29 (permalink)
    No need to disassemble, no need to weld, no need to rip the bike apart.  Just use the proper tool on the inner CV joint and the axle will pop out easily every time.  Here is what you guys should be using.
    08 brute 650
    28 swamplites on rattlesnakes
    highliter springs
    2in lift
    dynatek cdi
    almond secondary
    Talkn_Wolf
    Re:650 Rincon rear axle removal HELP 2010/03/20 23:03:23 (permalink)
    That looks like something i needed and could use in the future... now where and how much?
    04 Rincon 650
    06 Rhino 660
    09 Brute 750 - Sold
    Talkn_Wolf
    Re:650 Rincon rear axle removal HELP 2010/03/20 23:04:58 (permalink)
    wow... never mind just searched for "cv slide hammer" pulled up quite a few results.
    04 Rincon 650
    06 Rhino 660
    09 Brute 750 - Sold
