Locked550 wont start. what next?
idneverownahonda
2011/08/08 18:38:52 (permalink)
my buddy dropped his 2010 550 off at the house and it wont start. it cranks over fine and you can smell gas after a few seconds of trying to start it.  Where should i start? I told him to go pick up a new spark plug to try it. then was going to change out the gas. anything else?  He doesnt abuse the bike at all.   Thanks for the help
2009 Black 700 Grizzly FI
14" Vision Buckshot Wheels
30'' Backs
2'' HL Lift
1.5'' Spacers
E.P.I. Mudder Clutch
Custom Snorkles
HMF Swamp Series
PCV
Dynatek CDI
H.I.D. Conversion Lights
2500lb Warn Winch
http://photobucket.com/Mats_Pics
6 Replies Related Threads
    1 Bad Bear
    Re:550 wont start. what next? 2011/08/16 09:48:14 (permalink)
    Just wondering if you had found what was wrong with Ur buddies bike? My 07 700 is doing the same thing. Just turns over but won't crank. No codes on the display either. I'm thinking its either the tps or not a good spark. I already checked the fuel pump and cleaned the throttle body. Hope this gives you some ideas if u haven't figured it out
    2013 Renegade 1000
             Past Rides-
    07 GRIZZLY 700-SOLD
    08 GRIZZLY 700-SOLD
    04 BIG BEAR-SOLD
    03 Dodge 2500- Cummins "Nough Said"
    r6realtor
    Re:550 wont start. what next? 2011/08/17 18:08:27 (permalink)
    i think your on the right track with a plug, my dads does the same once it takes a crap on him and the plug looks fine but its fouled out.
    2011 Polaris Ranger 800 H.O
    2" EMP lift
    27" Radial Outlaws and Black sixr wheels/spacers
    4500# winch with multi mount
    rigid industries lights
    Axia Alloy handles
    FTD roof in black
    EMP stereo system
    Custom Rear seat
    2009 Yamaha Grizzly 550
    2009 Yamaha Raptor 700
    2009 Yamaha Grizzly 700 EPS
    sscard
    Re:550 wont start. what next? 2011/08/22 14:42:02 (permalink)
    not just fouled out, the plugs on the 550s are known to fail
    replace the spark plug, dont pull it and say, it looks good
    change it out
    Can Am Outty 800 MAX
    Can Am 800r Black
    its got options
    Texas Mud Hole Patrol
    http://www.facebook.com/pages/Texas-Mud-Hole-Patrol-Atv-Club/312120687051
    TPR_outback
    Re:550 wont start. what next? 2011/08/30 21:25:26 (permalink)
    This happened to mine. i went to start it one random day and it took a bit to turn over and then when it did it would not stay running, seemed almost like it would idol but die no matter how much throttle i gave it. After it died twice then it would turn over just not start. i was running regular unleaded, went and got premium and replaced the spark plug at the same time and it ran great, the plug didn't even look that bad. but it was one or the other and imma guess plug.
    2011 Grizzly 700
    ~ 2.5" SLC Lift
    ~~ 30" Silverbacks Skinny/Wide combo
    ~~~ 14" ITP 312 Rims
    ~~~~ Gold EPI spring
    ~~~~~ 8- 16g greaseless rollers
    ~~~~~~ Warn #3000 Winch
    ~~~~~~~ YU-TRAX ATV Backrest
    ~~~~~~~~ Audio Pipe
    ~~~~~~~~~ 360 Degree Stobes
    ~~~~~~~~~~Performance Atv Parts Snorkle
    ~~~~~~~~~~~HMF Performance series pipe
    [font="comic sa
    BigPuck
    Re:550 wont start. what next? 2011/09/06 21:00:34 (permalink)
    Mine did this exact thing. It was running rough so I thought I may have bad gas. I put new gas in and it was fine until I turned it off. When I went to recrank it did not want to crank but eventually did. It died when I got to may garage and would not recrank. The neighbor and I took it down. We had spark, getting fuel, and no obstructions in the intake. I read the above posts and changed the plug, runs grat now. I talked with the dealer while I was there, he said the plugs in these are easy to foul. Thanks to the above posters for helping me fix my problem.
    03 Popo Sportsman 700, 27" MudLites, Warn 2500--SOLD
    05 Suzuki KQ700, 27" MST's, Ramsey 2500, full skid plates, 2" HL lift--SOLD
    07 Rhino 660 SE, 27" Bugs, Viper 4000lb winch, diamond plate roof, offroad lights, stereo--SOLD
    09 Yamaha Grizz 550, camo, Mooose Diplomat pack, more to come
    sscard
    Re:550 wont start. what next? 2011/09/09 14:32:10 (permalink)
    a dealer telling you fouling is the issue is misinformed dealer
    there is some type of heat issue or something cracking the coil in the plugs, I have had them so bad they would not crank at all
    actually know a guy who owns a 550 and a 700 and both have done it two or three times each
    Im not sure what the fix is other than to carry one with you
    maybe try a different plug other than the stock ngk
    just an idea, I dont own one so I cant try it
    but when you see this many fail, this should be a recall issue, oh wait they only recall it if they know how to fix it lol
    and all the 660s I owned never had one plug fail
    Can Am 800r Black
    its got options
