Hot!450 foreman rear end
muddy450es
2019/02/25 22:05:12 (permalink)
Is there a stronger rearend I can put in the foreman?i just bought one on 29.5 ol2s and the guy claimed he just put a new rearend in it but it’s making racket again and was wondering if this ones bad if there is another one I could buy or are they usually tough enough to hold up to 29.5s?
2003 foreman 450
Snorkeled
Lifted
29.5 outlaw2
35% gear reduction
3 Replies Related Threads
    Re: 450 foreman rear end 2019/02/26 06:39:49 (permalink)
    Usually they are tough enough. One the guy probably had bad thumb control. And two he probably didn't put grease and oil in the chunk. Also if your gonna change the diff change the seals at but wheels. If you gonna spend that much money do it right. Another thing is the guy said new but is it new used? Cause if it's used it could have had bearing that were going out already.
    muddy450es
    Re: 450 foreman rear end 2019/02/26 15:46:16 (permalink)
    It looked used I was just wondering before I bought one if they usually hold up or if they could withstand the laws. Really haven’t got to look at it yet to know for sure what’s going on it’s just kind of making a scratching noise that sounds like it’s coming from the back
    2003 foreman 450
    Snorkeled
    Lifted
    29.5 outlaw2
    35% gear reduction
    Re: 450 foreman rear end 2019/02/26 16:11:54 (permalink)
    Probably needs a rebuild. They do hold up but you need to put grease and gear oil in it. Oh and change the seals at the hubs. Basically refresh the whole assm and it will be good. And yes they do hold up when taken care of.
