Hot!450 Swingarm on a 500 Foreman
Jeepwm69
2017/06/22 10:09:46 (permalink)
Doing the 450 Swingarm on my 06 500 (this is the one I'm having to swap do a different frame after the pivot bolt threads were destroyed)
I see some people say to pull the swingarm over using the bolts, some say to cut the swingarm, bend it to the side, then weld it, and I though I saw someone who said to use the right tube off of a 450 Foreman and it would bolt right up.
Anyone know if the right tube for a 450 is plug and play?  I can get one of those cheap.
1 Reply Related Threads
    Jeepwm69
    Re: 450 Swingarm on a 500 Foreman 2017/06/27 10:09:32 (permalink)
    To answer this question for anyone searching in the future, a 450 right axle tube did allow me to bolt the rear end up to the 450 swingarm without having to bend/cut/weld anything.  There was maybe a 1/8" gap between the plate and the swingarm but when I tightened the bolts down the gap disappeared.
    Got my stretch put on this 500 to make room for my 28x12x12 Mudbugs on the rear.
