Hot!2013 Honda rancher 420
Gentry12
2017/05/07 21:15:37 (permalink)
Have a 2013 Honda rancher 420 with 3 inch stretch, tore the rear diff out of it today it has 30 inch tires and was wondering what you guys ran with yalls bigger tires to keep the gears from stripping out. I want something. Ore heavy duty
15 Replies Related Threads
    Re: 2013 Honda rancher 420 2017/05/07 21:29:04 (permalink)
    At what point are they stripping? The axle splines or the ring and pinion? Is this the first time?
    Gentry12
    Re: 2013 Honda rancher 420 2017/05/07 22:14:05 (permalink)
    Ring n pinion and yes since I've had it. Going to check and make sure the drive shaft is trued but it should be
    Gentry12
    Re: 2013 Honda rancher 420 2017/05/07 22:15:51 (permalink)
    Re: 2013 Honda rancher 420 2017/05/07 22:29:06 (permalink)
    Yea I don't think it's your drive shaft. How's the bearings. Sounds like you may have a bad or going bad bearing that allowed to much play between the gears causing your current problem.
    Gentry12
    Re: 2013 Honda rancher 420 2017/05/07 22:31:05 (permalink)
    It has all new bearings in it
    Re: 2013 Honda rancher 420 2017/05/07 22:43:17 (permalink)
    Did you put the ring shims back in on their correct side?
    Gentry12
    Re: 2013 Honda rancher 420 2017/05/07 22:44:30 (permalink)
    I didn't put them in myself. The guy I got the 4 wheeler did
    Gentry12
    Re: 2013 Honda rancher 420 2017/05/07 22:52:48 (permalink)
    I think I just need a heave duty rear diff but don't know where to find one other than stock
    Re: 2013 Honda rancher 420 2017/05/07 23:28:33 (permalink)
    The only option you have is stock. There's to many people running 420's with big tires that don't grenade their diffs. I think something was wrong with it especially if you don't know what the guy before you did. Did you inspect the diff as far as looking through the fill hole? What kind of tires do u have?
    Gentry12
    Re: 2013 Honda rancher 420 2017/05/08 17:24:38 (permalink)
    Not untill after, has 3 inch spacers and 30's
    Re: 2013 Honda rancher 420 2017/05/08 17:45:43 (permalink)
    Yep I think the rebuild was your problem.
    Gentry12
    Re: 2013 Honda rancher 420 2017/05/08 17:51:40 (permalink)
    Haha well where's the cheapest place to get a rear diff?
    Re: 2013 Honda rancher 420 2017/05/08 18:33:31 (permalink)
    I get all my OEM parts from him. Good guy, and cheaper than anybody else, including partzilla.
    Paulie@hondaeasttoledo.com is his email
    Another guy on here swears by the above guy. So email him and see.
    Gentry12
    Re: 2013 Honda rancher 420 2017/05/08 18:34:40 (permalink)
    Thanks man
    Re: 2013 Honda rancher 420 2017/05/08 18:37:45 (permalink)
    No problem!!!
